Re: Source and # for 70 B body upper radiator hose
[Re: dragon slayer]
#3054280
06/29/22 08:22 AM
06/29/22 08:22 AM
Posts: 6,241 nowhere
Sniper
nowhere
I have been to the RA site. All economy are the ribbed flexible and the rest are AC or HD cooling which are 26" passenger side. Other than cut to fit.
The Dayco 70352 is 1 9/16" vice 1.5" but probably could be made to fit.
I guess the reproduction are the only custom fit options out there? I did search on google, I just could not find any good options, and some of the hose seem to be mis marked in application based on actual photo of the hose. I went there and saw several without AC molded upper hoses. GATES 20370 CONTINENTAL 60291 ACDELCO 24003L
[Re: dragon slayer]
#3054333
06/29/22 11:43 AM
06/29/22 11:43 AM
Posts: 744 Almost Heaven
Bob Stinson
Almost Heaven
I just put a hose on my BB Duster, 22" radiator, driver's side inlet, and used a 71 340 hose and cut it to fit. It was about twice as long as it needed to be, and they all come out of the center of the engine so the only real difference is the side you need to connect on, and the distance between the engine and the radiator. If you're in a bind where you need a hose and don't care how original it is, it would be worth a try to check one out. Gates 20602 or Dayco 70975.
69 road runner A12 ex-racer 71 Duster w/ a 400
Shiny paint causes stress.
[Re: dragon slayer]
#3055329
07/02/22 07:26 PM
07/02/22 07:26 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
I have used that Dayco 70352 on multiple 22" Upper radiator hose driver side on 70 - 71 B E Bodies 383 / 440 Big Block with great success It’s your choice other then reproduction with numbers stamped
Peace
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: dragon slayer]
#3055333
07/02/22 07:48 PM
07/02/22 07:48 PM
bee1971
Sobieski Wi
I guess the reproduction are the only custom fit options out there? I did search on google, I just could not find any good options, and some of the hose seem to be mis marked in application based on actual photo of the hose. The reproduction numbers is also 1 9/16" on both Peace
