Re: Fancy ignition issues
[Re: GY3]
#3053865
06/27/22 04:11 PM
06/27/22 04:11 PM
Posts: 4,689 On the parachute mount
n20mstr
keep track of your time, and money spent on this....... MSD id never use again.... get a used EFI ecu and never look back....put coil on plug and your timing can swing as far as you want and be ROCK SOLID.... MSD snafus will eventually cost you pistons or more, then what will the cost be ??? YOu can coil on plug it for very little, if you want get a used LS harness and coils....
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3053915
06/27/22 06:09 PM
06/27/22 06:09 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
keep track of your time, and money spent on this....... MSD id never use again.... get a used EFI ecu and never look back....put coil on plug and your timing can swing as far as you want and be ROCK SOLID.... MSD snafus will eventually cost you pistons or more, then what will the cost be ??? YOu can coil on plug it for very little, if you want get a used LS harness and coils.... For sure, the LS coils are cheap, easy, and powerful.
68 Barracuda Formula S 340
[Re: n20mstr]
#3054094
06/28/22 01:29 PM
06/28/22 01:29 PM
Posts: 2,928 A shed in England
Tig
A shed in England
This is disappointing to hear, after getting a grid and all the fancy doo-dads, we were likely going to go to a big fogger kit on the 655ci. It's been as reliable as a stone so far, the only thing that's "broke" is a crank trigger sensor going bad and causing a misfire but I suppose if that went west while on the gas things would go bad in a tick... What issues have you had with MSD stuff ? TIA
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3054104
06/28/22 02:11 PM
06/28/22 02:11 PM
Posts: 43,241 Bend,OR USA
Cab_Burge
I've used MSD race boxes, 4040B,404C,MSD7,7A, 7AL2 and now have a grid that I have not used yet. I had one 7C box fail years ago at the Mopar race in Las Vegas, it ran fine and then quit I sent it back to MSD before they got bought out and they told me they couldn't fix it due to not having a correct harness for inside the box Me thinks they wanted me to buy a new modern race box I know bunch of NHRA racers that have used the race boxes since they came out, I don't remember any of them griping or complaining about them I have two 7C and one 7AL2 boxes that I will continue to use in the future on motors needing them, same thing on the little red coils and the older Mallory/MSD race coils I bought the grid to use with a future EFI build, I called MSD last year or the year before to ask them about using it with the 7AL2 box and they said it would work, I'm hoping their correct I've also thought about using a coil on plug ignition for high compression race motor on E 85 but that may be overkill I'm also looking at building a building a big C.I. Pro Charge motor that will make north of 2000 HP on E85, I will definitely use a grid on it to control the timing
[Re: Tig]
#3054117
06/28/22 02:48 PM
06/28/22 02:48 PM
n20mstr
This is disappointing to hear, after getting a grid and all the fancy doo-dads, we were likely going to go to a big fogger kit on the 655ci. It's been as reliable as a stone so far, the only thing that's "broke" is a crank trigger sensor going bad and causing a misfire but I suppose if that went west while on the gas things would go bad in a tick... What issues have you had with MSD stuff ? TIA Unless your using the Large Ford style cap on a belt drive distributor, the mopar dist cap is not that good at large amounts of retard. SO when your using a 400+ or bigger amount of nitrous you run into rotor phase issues. Specifically i ran into some misfires and when nitrous ignites at the wrong time it does some damage. In my case i was cracking exh ports on a few occasions and pushing head gaskets out.
[Re: n20mstr]
#3054119
06/28/22 03:21 PM
06/28/22 03:21 PM
Tig
A shed in England
This is disappointing to hear, after getting a grid and all the fancy doo-dads, we were likely going to go to a big fogger kit on the 655ci. It's been as reliable as a stone so far, the only thing that's "broke" is a crank trigger sensor going bad and causing a misfire but I suppose if that went west while on the gas things would go bad in a tick... What issues have you had with MSD stuff ? TIA Unless your using the Large Ford style cap on a belt drive distributor, the mopar dist cap is not that good at large amounts of retard. SO when your using a 400+ or bigger amount of nitrous you run into rotor phase issues. Specifically i ran into some misfires and when nitrous ignites at the wrong time it does some damage. In my case i was cracking exh ports on a few occasions and pushing head gaskets out. Ahh I see...... Thanks for the heads up , I'm going to fit the Indy reverse flow kit ('cause I already have it) and was considering the belt drive dist but I guess it's a must now Do these work OK together anyone ? Edit: Sorry for the hijack Chip, hope this is OK.
[Re: Tig]
#3054123
06/28/22 03:36 PM
06/28/22 03:36 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
No problem Tig. You can use the MSD cap-a-dapt to fit the large ford distributor cap onto your existing distributor. If it will clear your cylinder head and valve cover. The belt drive deal is probably better, but the cap-a-dapt deal would be a lot cheaper. In my case, the big ford cap won't clear my valve cover. I know I can pull at least 14° w/o any phasing issues w/ the small cap. If I run into issues later, I'll take some base timing out.
