5.9 gas compression ratio- how high on pump gas? #3053861
06/27/22 04:03 PM
06/27/22 04:03 PM
Atlanta, GA
mgoblue9798 Offline OP
Atlanta, GA
What is the upper limit of compression ratios on street builds you have done with a small cam? 87 or 93? Custom tune or stock ECM? Steel or aluminum heads? Stock stroke or stroker?
I am considering building a dual fuel motor to run primarily CNG which is 125-130 octane, and want to push the limit on the compression I could get by with when forced to switch back to pump swill.
Re: 5.9 gas compression ratio- how high on pump gas? [Re: mgoblue9798] #3053876
06/27/22 04:30 PM
06/27/22 04:30 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I ran 11 to 1 in my iron head 410 magnum stroker. 230@.050 cam and pump premium gasoline. Ran fine with a stock ECM and incredible with a tune.
I have also run 10 to 1 on a 318 magnum with a stock cam and tight quench distance and 87 octane. Stock ECM
CNG is hard to get much range in a fuel storage container, propane is much better choice.
Re: 5.9 gas compression ratio- how high on pump gas? [Re: HotRodDave] #3053880
06/27/22 04:46 PM
06/27/22 04:46 PM
Atlanta, GA
Atlanta, GA
Thanks for your input sir.
What kind of mileage were you able to get out of your stroker combo?
Was it a truck or car engine?
As far as tank capacity goes I have all kinds of room under my van so no worries there.
Tanks are purchased and sequential injection kit is on the way for cng at any rate.
Re: 5.9 gas compression ratio- how high on pump gas? [Re: mgoblue9798] #3053885
06/27/22 05:01 PM
06/27/22 05:01 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
My 406" LA motor - Duster, AT, 3.21 gear, AC, street car, iron heads - was right at the limit @ 9.5:1 measured static compression, on Calif 91 octane.
Cam was 214/224 @ .050, .470/.504 lift on 110 CL.
Had to pull timing out of it. Car ran great, though, and would pull 17MPG @ 70-75.
Aluminum heads would allow that CR and more.
Re: 5.9 gas compression ratio- how high on pump gas? [Re: topside] #3053893
06/27/22 05:16 PM
06/27/22 05:16 PM
Atlanta, GA
Atlanta, GA
Did you run an open chamber factory LA head with your combo? Was it set up for quench?
Re: 5.9 gas compression ratio- how high on pump gas? [Re: mgoblue9798] #3053904
06/27/22 05:54 PM
06/27/22 05:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the stroker was in a regular cab dakota R/T I never drove easy and never bothered to check MPG
Re: 5.9 gas compression ratio- how high on pump gas? [Re: HotRodDave] #3053916
06/27/22 06:26 PM
06/27/22 06:26 PM
A collage of whims
A collage of whims
Just regular J heads.
