5.9 gas compression ratio- how high on pump gas?
#3053861
06/27/22 04:03 PM
06/27/22 04:03 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
What is the upper limit of compression ratios on street builds you have done with a small cam? 87 or 93? Custom tune or stock ECM? Steel or aluminum heads? Stock stroke or stroker?
I am considering building a dual fuel motor to run primarily CNG which is 125-130 octane, and want to push the limit on the compression I could get by with when forced to switch back to pump swill.
Re: 5.9 gas compression ratio- how high on pump gas?
[Re: mgoblue9798]
#3053876
06/27/22 04:30 PM
06/27/22 04:30 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I ran 11 to 1 in my iron head 410 magnum stroker. 230@.050 cam and pump premium gasoline. Ran fine with a stock ECM and incredible with a tune.
I have also run 10 to 1 on a 318 magnum with a stock cam and tight quench distance and 87 octane. Stock ECM
CNG is hard to get much range in a fuel storage container, propane is much better choice.
[Re: mgoblue9798]
#3053885
06/27/22 05:01 PM
06/27/22 05:01 PM
Posts: 20,841 A collage of whims
topside
A collage of whims
My 406" LA motor - Duster, AT, 3.21 gear, AC, street car, iron heads - was right at the limit @ 9.5:1 measured static compression, on Calif 91 octane. Cam was 214/224 @ .050, .470/.504 lift on 110 CL. Had to pull timing out of it. Car ran great, though, and would pull 17MPG @ 70-75. Aluminum heads would allow that CR and more.
[Re: topside]
#3053893
06/27/22 05:16 PM
06/27/22 05:16 PM
mgoblue9798
Atlanta, GA
My 406" LA motor - Duster, AT, 3.21 gear, AC, street car, iron heads - was right at the limit @ 9.5:1 measured static compression, on Calif 91 octane. Cam was 214/224 @ .050, .470/.504 lift on 110 CL. Had to pull timing out of it. Car ran great, though, and would pull 17MPG @ 70-75. Aluminum heads would allow that CR and more. Did you run an open chamber factory LA head with your combo? Was it set up for quench?
[Re: mgoblue9798]
#3053904
06/27/22 05:54 PM
06/27/22 05:54 PM
HotRodDave
Kalispell Mt.
the stroker was in a regular cab dakota R/T I never drove easy and never bothered to check MPG
