Brewer versus Passon Performance #3053681
06/26/22 11:13 PM
06/26/22 11:13 PM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
Need to purchase a new flywheel, and various back of engine and transmission related parts. Which is better to deal with? Brewer or Passon Performance?
And if I have a B body with a hemi 4-speed, it should be an 11", 143 tooth flywheel, right?
Re: Brewer versus Passon Performance [Re: GTXMEX] #3053688
06/26/22 11:50 PM
06/26/22 11:50 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
What year and engine B body? 66-69 Hemi equipped 4 speed cars used a 172 tooth flywheel.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Brewer versus Passon Performance [Re: Hemi_Joel] #3053692
06/27/22 12:07 AM
06/27/22 12:07 AM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
1969 Plymouth GTX w/440. New engine will have a 8 bolt crank flange, 4.25" stroker. I remember years ago trying a factory aluminum bell housing. But flywheel would fit, so figured it'd be an 11". 143 flywheels mention. "neutral balance crank". 172 tooth gear mentions "hemi motors using original direct drive starter". I have and will use a mini starter for header clearance. Please advise.
Re: Brewer versus Passon Performance [Re: GTXMEX] #3053702
06/27/22 01:54 AM
06/27/22 01:54 AM
Look at the casting number on the lower right hand side of the back face of the bell housing facing the trans. and post it on here if you can't find that casting number application.
I'm assuming it is a cast iron bellhousing and not an aluminum one, correct?
The casting number will tell you the year and clutch and flywheel size that fit into it stock: scope:
Re: Brewer versus Passon Performance [Re: GTXMEX] #3053705
06/27/22 05:54 AM
06/27/22 05:54 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Brewer's IMO up I have dealt with both!
Re: Brewer versus Passon Performance [Re: RATTRAP] #3053709
06/27/22 07:04 AM
06/27/22 07:04 AM
VA
dragon slayer Offline
VA
69 440 B body would use the 143 tooth flywheel. Not normally a hemi flywheel, but I do think the aftermarket supports one with 8 bolts.
In 1970 mopar went to the 513 Alu Bell house for the 130 tooth flywheel for all BB motors including hemi.
But as stated, the actual Bell housing determines the flywheel size so that the starter engages.
Re: Brewer versus Passon Performance [Re: GTXMEX] #3053715
06/27/22 07:38 AM
06/27/22 07:38 AM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
I have spoke with both and used brewers when I did my 4 speed, my good friend also used brewers on his hemi box. Great parts, great people, and they are kind enough to help you through any issues you may have. They are my choice Hands down
Re: Brewer versus Passon Performance [Re: twayne24365] #3053770
06/27/22 11:25 AM
06/27/22 11:25 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I've bought several items from Brewer's and have been happy with them every time.
Knowledgeable, reasonable, correct and quick works for me !
Re: Brewer versus Passon Performance [Re: RATTRAP] #3053781
06/27/22 11:57 AM
06/27/22 11:57 AM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree I’ve dealt with both. Brewer’s is my choice, bought a complete 727 to A-833 swap from themdrive
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Brewer versus Passon Performance [Re: GTXMEX] #3053825
06/27/22 02:06 PM
06/27/22 02:06 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Both Brewers and Passon are experts for the Chrysler 4-speed hardware.
But U need to check closely product availability, in today's market things can change very quickly.
We have bought from both vendors, as they valuable supporters for our select Mopar cars.
Just my $0.02... wink
