Vintage Air fast idle solenoid #3053302
06/25/22 03:37 PM
06/25/22 03:37 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
My buddy has a Vintage air in his ‘67 Belvedere. There’s a solenoid that’s wired to the compressor clutch that pops out to bump up the idle engine idle speed while in gear at a stop sign. He needs a few more RPM than what is set. We cured the problem with 4 layers of duct tape on top of the plunger.
The question for you guys is, will this plunger turn in or out to adjust the idle speed? I didn’t want to start trying to turn it until I got some more information. It appears to have a 1/2” or 9/16” size head on it.
Thx
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Vintage Air fast idle solenoid [Re: cdstl] #3053305
06/25/22 04:02 PM
06/25/22 04:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, turn it out (counterclockwise) to raise the idle speed.
Re: Vintage Air fast idle solenoid [Re: John_Kunkel] #3053306
06/25/22 04:04 PM
06/25/22 04:04 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Thanks John, that's exactly what I thought.
Re: Vintage Air fast idle solenoid [Re: cdstl] #3053447
06/26/22 10:39 AM
06/26/22 10:39 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
just a heads up, They didn't used to have enough push to overcome the return springs without blipping the throttle. But that may have changed or be dependent on your setup beer
Re: Vintage Air fast idle solenoid [Re: TJP] #3053503
06/26/22 01:15 PM
06/26/22 01:15 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Mine is a few years old and it too has to have the throttle "blipped" to be able to hold open the throttle linkage.
Re: Vintage Air fast idle solenoid [Re: YO7_A66] #3053536
06/26/22 03:15 PM
06/26/22 03:15 PM
BDW Offline
BDW  Offline
This was a pleasant benefit when I switched to fuel injection.
Car would always dip the RPMs and almost die when the AC was clicked on with a carb.
The fuel injection compensated to keep it where needed.
Re: Vintage Air fast idle solenoid [Re: YO7_A66] #3053668
06/26/22 10:18 PM
06/26/22 10:18 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Adding a short lever and remounting the solenoid may help as would a lighter return spring if possible. Would be nice if they could just sell a flippin product with enough force though. It's not ROCKET science.
I may have read somewhere that a mid 70's or so GM solenoid had more grunt shruggy beer
Re: Vintage Air fast idle solenoid [Re: TJP] #3053806
06/27/22 01:14 PM
06/27/22 01:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In a system that cycles the compressor clutch to control evaporator temperature, the low-strength idle solenoid is a PITA because you have to blip the throttle after each clutch release/reapply cycle but Mopar systems with the RV compressor don't cycle the clutch, so the solenoid works better on them.
Re: Vintage Air fast idle solenoid [Re: John_Kunkel] #3053964
06/27/22 09:28 PM
06/27/22 09:28 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Here's a smoking deal on one of the GM solenoids CHEAP A TWICE THE PRICE
whistling beer
Re: Vintage Air fast idle solenoid [Re: TJP] #3054069
06/28/22 11:21 AM
06/28/22 11:21 AM
moparx Offline
moparx  Offline
whistling beer
eek eek eek
beer
Re: Vintage Air fast idle solenoid [Re: moparx] #3054113
06/28/22 02:40 PM
06/28/22 02:40 PM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
The seller doesn't have a whole lot of items from his "museum" selling. Wonder why.
-->www.ebay/ravjudge/completed sales<--
Probably thinks his chit doesn't stink either.....
