Re: Carb to Scoop Clearance
[Re: dizuster]
#3053748
06/27/22 09:43 AM
06/27/22 09:43 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
FWIW I was told by a reputable carb builder that 3/4" above the vent tubes is all that is required.
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Plumb Wired]
#3054432
06/29/22 03:57 PM
06/29/22 03:57 PM
Posts: 4,567 Motor City
6PKRTSE
Motor City
I have 2" from my carbs to my Super Shaker.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Plumb Wired]
#3054716
06/30/22 03:46 PM
06/30/22 03:46 PM
Posts: 1,142 Loudoun County, VA
Brad_Haak
Loudoun County, VA
FWIW I was told by a reputable carb builder that 3/4" above the vent tubes is all that is required. I wonder if there's both a minimum clearance above the vent tubes and a minimum clearance above the venturis needed to ensure sufficient airflow...
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3054857
07/01/22 08:43 AM
07/01/22 08:43 AM
Brad_Haak
Loudoun County, VA
FWIW I was told by a reputable carb builder that 3/4" above the vent tubes is all that is required. I wonder if there's both a minimum clearance above the vent tubes and a minimum clearance above the venturis needed to ensure sufficient airflow... FWIW, I asked this because the vent tube heights can vary significantly from one carb company / builder to another, so I figured there are likely two dimensions to take into account
[Re: John_T_Brown]
#3054861
07/01/22 08:47 AM
07/01/22 08:47 AM
Posts: 679 COLUMBUS, OH
Whompin_Wedge
COLUMBUS, OH
1/2" above the vent tubes is all that is needed. I've been running the car that way for over 30 years! I have probably ran a little less than that even (use tubes on the vents to route to the valley). Car has always ran fine. Thank you, Casey FJ
