Re: Rear end dilemma ...
[Re: Stanton]
#3053176
06/24/22 11:09 PM
06/24/22 11:09 PM
Posts: 18,085 in a cattle trailer down by th...
Guitar Jones
If you have a choice I would go with less backspacing. It saves some weight if nothing else.
I raise chickens, so I am literally a chicken tender.
The Scamp is sold, now just two old trucks and one new one. '92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Stanton]
#3053177
06/24/22 11:19 PM
06/24/22 11:19 PM
Posts: 4,287 Moved to N.E. Tennessee
GomangoCuda
Narrower rear end is lighter and stronger. On the other hand a centered wheel is probably the strongest and least flexible.
[Re: Stanton]
#3053190
06/25/22 01:22 AM
06/25/22 01:22 AM
Posts: 39,615 Bend,OR USA
Cab_Burge
The deeper the offset the easier they are to remove, usually  work:: up:
[Re: Sniper]
#3053270
06/25/22 01:08 PM
06/25/22 01:08 PM
Cab_Burge
My race car had a set of Monoque that were 15 inches wide with 3.0 offset from the back side  I have two other sets of drag race wheels, a set of Centerline 15 inch wide with 5.5 offset and a set of Welds 13.5 with 4.0 offset. I think Weld offers offsets in half inch increments and Centerline use to only offer 3 1/8 and 5 1/4 inch offset regardless of the wheel widths, I think: work:
[Re: Cab_Burge]
#3053281
06/25/22 01:42 PM
06/25/22 01:42 PM
Posts: 4,384 nowhere
Sniper
nowhere
My race car had a set of Monoque that were 15 inches wide with 3.0 offset from the back side  I have two other sets of drag race wheels, a set of Centerline 15 inch wide with 5.5 offset and a set of Welds 13.5 with 4.0 offset. I think Weld offers offsets in half inch increments and Centerline use to only offer 3 1/8 and 5 1/4 inch offset regardless of the wheel widths, I think: work: 7 1/2 inches? on a 10" rim?
[Re: BDW]
#3053352
06/25/22 08:01 PM
06/25/22 08:01 PM
Posts: 8,164 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
7 1/2 inches? on a 10" rim? Not uncommon on later vehicles - Mustangs in particular.
[Re: Sniper]
#3053401
06/26/22 02:21 AM
06/26/22 02:21 AM
GomangoCuda
My race car had a set of Monoque that were 15 inches wide with 3.0 offset from the back side  I have two other sets of drag race wheels, a set of Centerline 15 inch wide with 5.5 offset and a set of Welds 13.5 with 4.0 offset. I think Weld offers offsets in half inch increments and Centerline use to only offer 3 1/8 and 5 1/4 inch offset regardless of the wheel widths, I think: work: 7 1/2 inches? on a 10" rim? The original poster was talking about 12" wheels.
[Re: Sniper]
#3053793
06/27/22 12:38 PM
06/27/22 12:38 PM
Cab_Burge
