Vintage Air fast idle solenoid
#3053302
06/25/22 03:37 PM
06/25/22 03:37 PM
Posts: 1,487 STL
cdstl
STL
My buddy has a Vintage air in his ‘67 Belvedere. There’s a solenoid that’s wired to the compressor clutch that pops out to bump up the idle engine idle speed while in gear at a stop sign. He needs a few more RPM than what is set. We cured the problem with 4 layers of duct tape on top of the plunger.
The question for you guys is, will this plunger turn in or out to adjust the idle speed? I didn’t want to start trying to turn it until I got some more information. It appears to have a 1/2” or 9/16” size head on it.
Thx
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Vintage Air fast idle solenoid
[Re: cdstl]
#3053305
06/25/22 04:02 PM
06/25/22 04:02 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Yes, turn it out (counterclockwise) to raise the idle speed.
[Re: John_Kunkel]
#3053306
06/25/22 04:04 PM
06/25/22 04:04 PM
Posts: 1,487 STL
cdstl
STL
Thanks John, that's exactly what I thought.
[Re: TJP]
#3053503
06/26/22 01:15 PM
06/26/22 01:15 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
Mine is a few years old and it too has to have the throttle "blipped" to be able to hold open the throttle linkage.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: TJP]
#3053806
06/27/22 01:14 PM
06/27/22 01:14 PM
John_Kunkel
Rio Linda, CA
In a system that cycles the compressor clutch to control evaporator temperature, the low-strength idle solenoid is a PITA because you have to blip the throttle after each clutch release/reapply cycle but Mopar systems with the RV compressor don't cycle the clutch, so the solenoid works better on them.
[Re: moparx]
#3054113
06/28/22 02:40 PM
06/28/22 02:40 PM
Posts: 1,820 South Bend
John Brown
South Bend
The seller doesn't have a whole lot of items from his "museum" selling. Wonder why. -->www.ebay/ravjudge/completed sales<--Probably thinks his chit doesn't stink either.....
