Re: Rear end dilemma ...
[Re: Stanton]
#3053176
06/24/22 11:09 PM
06/24/22 11:09 PM
Guitar Jones
If you have a choice I would go with less backspacing. It saves some weight if nothing else.
[Re: Stanton]
#3053177
06/24/22 11:19 PM
06/24/22 11:19 PM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
Narrower rear end is lighter and stronger. On the other hand a centered wheel is probably the strongest and least flexible.
[Re: Stanton]
#3053190
06/25/22 01:22 AM
06/25/22 01:22 AM
Posts: 43,193 Bend,OR USA
Cab_Burge
The deeper the offset the easier they are to remove, usually work:: up:
[Re: Sniper]
#3053270
06/25/22 01:08 PM
06/25/22 01:08 PM
Cab_Burge
My race car had a set of Monoque that were 15 inches wide with 3.0 offset from the back side I have two other sets of drag race wheels, a set of Centerline 15 inch wide with 5.5 offset and a set of Welds 13.5 with 4.0 offset. I think Weld offers offsets in half inch increments and Centerline use to only offer 3 1/8 and 5 1/4 inch offset regardless of the wheel widths, I think: work:
[Re: Cab_Burge]
#3053281
06/25/22 01:42 PM
06/25/22 01:42 PM
Posts: 6,261 nowhere
Sniper
nowhere
My race car had a set of Monoque that were 15 inches wide with 3.0 offset from the back side I have two other sets of drag race wheels, a set of Centerline 15 inch wide with 5.5 offset and a set of Welds 13.5 with 4.0 offset. I think Weld offers offsets in half inch increments and Centerline use to only offer 3 1/8 and 5 1/4 inch offset regardless of the wheel widths, I think: work: 7 1/2 inches? on a 10" rim?
[Re: BDW]
#3053352
06/25/22 08:01 PM
06/25/22 08:01 PM
Posts: 8,873 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
7 1/2 inches? on a 10" rim? Not uncommon on later vehicles - Mustangs in particular.
[Re: Sniper]
#3053401
06/26/22 02:21 AM
06/26/22 02:21 AM
GomangoCuda
My race car had a set of Monoque that were 15 inches wide with 3.0 offset from the back side I have two other sets of drag race wheels, a set of Centerline 15 inch wide with 5.5 offset and a set of Welds 13.5 with 4.0 offset. I think Weld offers offsets in half inch increments and Centerline use to only offer 3 1/8 and 5 1/4 inch offset regardless of the wheel widths, I think: work: 7 1/2 inches? on a 10" rim? The original poster was talking about 12" wheels.
[Re: BDW]
#3053728
06/27/22 08:16 AM
06/27/22 08:16 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
I'd find the rims you like, then that makes th e rear end choice for you. You may change rims over the life of the car, so pick something common/standard Only want to buy the rear end once........ Otherwise you might have to order custom offset wheels from somewhere like Holeshot. Not a bad thing, but expensive.
[Re: Sniper]
#3053793
06/27/22 12:38 PM
06/27/22 12:38 PM
Cab_Burge
