Truck - 833 4-speed Transmission with Shifter
[Re: moparts]
#3052598
06/23/22 04:00 AM
06/23/22 04:00 AM
Posts: 4,229 Danville, NH
Mopar_Mike
Danville, NH
I believe this is a 833 4-speed transmission for a Truck from the late 70's early 80's. Comes as seen with the shifter and linkage. Shifts good and I see no reason why it would not work as-is. Should work with Big Block and Small Block engines. No Shipping. $425
fas141@comcast.net
RS23L7 440 4-Speed RS27L7 440 727
Late 1960's Jeep T14 3-Speed Transmission - Nice Condition
[Re: moparts]
#3052599
06/23/22 04:02 AM
06/23/22 04:02 AM
Mopar_Mike
Danville, NH
I believe this is a late 1960's Jeep 3-Speed T14 Transmission. Part number on case: 13-02-065-002 and on the tail shaft 13-02-027-906. Comes as seen with shifter rods. 10 spline input shaft and 16 spline output shaft. Transmission shifts smooth and is tight. Could use a cleaning but has never been opened up. It is untested, but is a nice shifting tight transmission. No Shipping. $250
fas141@comcast.net
