8 3/4 powr-lok too tight? #3052452
06/22/22 04:18 PM
06/22/22 04:18 PM
NW Illinois
MoonshineMattK Offline OP
NW Illinois
Hello,
Last year we installed a powr-lok in a customers 8 3/4. He is complaining it is too tight and doesn't slip enough in tight turns - Gas stations, parking lots, etc. He hears a clunking sound.
Is anyone familiar with this? I have powr-loks in both my chargers and have noticed the inside wheel slide when turning sharp but nothing I thought was a problem. My customers car has a street lynx rear suspension and I'm wondering if the rod ends on the 4 link amplify when the tire drags at slow speed and cause a clunk?
Thanks, Matt
Re: 8 3/4 powr-lok too tight? [Re: MoonshineMattK] #3052455
06/22/22 04:26 PM
06/22/22 04:26 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Mine was crazy tight after I rebuilt it. I had to use a little extra additive and go out and drive some figure 8s to make it stop banging around turns.
Rich H.
Esse Quam Videri
Re: 8 3/4 powr-lok too tight? [Re: ZIPPY] #3052458
06/22/22 04:31 PM
06/22/22 04:31 PM
an8sec70cuda Offline
I've only rebuilt one powr-lok for a Dana 60, but had the same result. Had to use the Ford friction additive Dr. Diff recommended and drive it some. It's fine now.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 8 3/4 powr-lok too tight? [Re: an8sec70cuda] #3052459
06/22/22 04:33 PM
06/22/22 04:33 PM
NW Illinois
NW Illinois
Thanks. We used the ford lube Dr Diff recommended.
I'll have him run some figure 8s too. Good idea.
Re: 8 3/4 powr-lok too tight? [Re: MoonshineMattK] #3052557
06/22/22 09:51 PM
06/22/22 09:51 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Some of the rebuild kits out there use all thick plates and that would be too tight and the plates don't slip like they should. I usually re-use a few of the old thin plates when I rebuild one and it works perfectly.
Gus beer
64 Plymouth Savoy
Dana 60
Re: 8 3/4 powr-lok too tight? [Re: fourgearsavoy] #3052924
06/24/22 11:06 AM
06/24/22 11:06 AM
NW Illinois
NW Illinois
Gus beer
This unit was from Dr Diff
Does he use thicker plates you describe?
Re: 8 3/4 powr-lok too tight? [Re: MoonshineMattK] #3052968
06/24/22 12:52 PM
06/24/22 12:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Dr Diff sells two clutch kits, one for factory and another for aftermarket. If you're not sure which one you had.................
Re: 8 3/4 powr-lok too tight? [Re: John_Kunkel] #3053664
06/26/22 10:13 PM
06/26/22 10:13 PM
NW Illinois
NW Illinois
did not buy a rebuild kit. Bought a whole new power-lok
Re: 8 3/4 powr-lok too tight? [Re: John_Kunkel] #3053669
06/26/22 10:19 PM
06/26/22 10:19 PM
NW Illinois
NW Illinois
Been a couple years but I believe this is the unit
https://www.doctordiff.com/8-3-4-clutch-type-sure-grip-powr-lok.html
My question is:
He hears a clunk in short turns. I don't think its the power-lok. I think its the street lynx suspension. Because the suspension is 4link with rod ends there is not the usual thick rubber insulation. The only thing I can think is that the inside tire drags when he turns sharp. If that tire bounces a bit and unloads/loads the suspension it might make the bang/clunk he's hearing.
Both my cars with power-lok 8 3/4 axles drag the tire on tight turns. But they never bang or clunk.
Re: 8 3/4 powr-lok too tight? [Re: MoonshineMattK] #3053670
06/26/22 10:20 PM
06/26/22 10:20 PM
NW Illinois
NW Illinois
I just don't see how the power-lok could make a clunk sound. There's nothing in it to clunk.
Re: 8 3/4 powr-lok too tight? [Re: MoonshineMattK] #3053677
06/26/22 10:48 PM
06/26/22 10:48 PM
Kirkland, Washington
Pacnorthcuda Offline
They clunk when the clutch packs bind up until the force applied overcomes the bind and then they release, somewhat violently. Rather than a smooth ‘limited slip’.
Re: 8 3/4 powr-lok too tight? [Re: MoonshineMattK] #3053739
06/27/22 08:57 AM
06/27/22 08:57 AM
Rittman Ohio
Rittman Ohio
Not the first time I've heard of this condition with a "new" Power-Lock unit. They are simply set up too tight from the factory IMHO twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: 8 3/4 powr-lok too tight? [Re: fourgearsavoy] #3053794
06/27/22 12:46 PM
06/27/22 12:46 PM
Gus beer
iagree
I sold one to a customer of mine that is a lawyer, he had it removed and replaced with gear type posi due to it almost making his 1967 Plymouth 440 powered GTX convertible go into the ditch across the street turning at a corner making a 90-degree right hand turn at or slower than 5 MPH:: puke: shruggy
I'm wondering if doing several hard burn outs might loosen them up some to make them like the stock clutch type posi are? work
Re: 8 3/4 powr-lok too tight? [Re: Cab_Burge] #3055558
07/03/22 03:53 PM
07/03/22 03:53 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I used to run dana 44 clutches so they would act that way, they were a tad thicker
