Tunnel Ram or not?
#305233
05/02/09 01:46 AM
05/02/09 01:46 AM
Posts: 1,894 Mira Loma, CA
69B3GT
Mira Loma, CA
Ok so im a long ways off from building my 340 but i was wondering how a tunnel ram would do with two holley 450s, ive always loved the look and was wondering how it would perform. Plus i can get 2 450 holleys for basically a song. So is a tunnel ram great on performance or should i stick to a run-of-the-mill style intake? Im not too familiar with this as the 340 will be the first motor ill be building so i thought id ask. Thanks, Chris.
Re: Tunnel Ram or not?
[Re: 69B3GT]
#305234
05/02/09 01:57 AM
05/02/09 01:57 AM
Posts: 16,482 Canada
CrAzYMoPaRGuY
Canada
If it's a stout small block I would run a tunnel ram no hesitation. Tunnel rams aren't strictly for top end drag cars, they are VERY streetable. I've owned dozens of tunnel ram 2x4bbl street cars and trucks. I drove a work truck for years with a tunnel ram, stock converter, mild cam (268 Comp cam) and it had TONS of torque and awesome drivability.
CrAzYMoPaRGuY
[Re: RUNCHARGER]
#305237
05/02/09 08:49 AM
05/02/09 08:49 AM
Posts: 871 WA 98043
thecarfarmer
WA 98043
Ran an M1 TR and two 770 CFM (275 HP 327 carbs IIRC) on a low CR 383 w/ 4.10s and a loose convertor; ran well.
Until the #6 rod bearing spun...
My .02: go for it!
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: modelmakerinc]
#305240
05/02/09 01:30 PM
05/02/09 01:30 PM
Posts: 735 Spokane,WA
Genuinejed
Spokane,WA
Go for it! I just put my wieand track ram on my 426 Street wedge with two 650 eddies. Runs good except a slight lean spot off idle (working on it). Does funny car style burn outs now!
1968 Plymouth road runner
1968 Dodge Coronet 500
64 D200
Good, Fast, Cheap. Pick Two.
[Re: RUNCHARGER]
#305241
05/02/09 02:01 PM
05/02/09 02:01 PM
69B3GT
Mira Loma, CA
I'm not so sure the 450 Holleys work that great. You might want to run 600s.
Sheldon
two 600s on a 340? i thought that would be a little much, the 450s are pretty tempting since i need one for my 273 right now. Well im still a long ways off from this motor but i think ill try the 450s and if tey dont perform the best ill find a set of 600s
