Re: Big block water pump housing bypass
[Re: SuperRob]
#3051978
06/20/22 12:53 PM
06/20/22 12:53 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The heater circuit will also act as a bypass, provided there isn’t a closed heater control valve being used, and the core isn’t plugged.
You could always drill a hole in the housing too.
[Re: fast68plymouth]
#3052142
06/21/22 09:33 AM
06/21/22 09:33 AM
Posts: 178 Hamburg - Germany
SuperRob
Hamburg - Germany
You could always drill a hole in the housing too. Thanks. Yes, drilling the hole will be on the agenda. I was just surprised to find a housing without a bypass. After trying to cure the symptoms with different water pumps and thermostats for years I was running out of ideas why the engine would idle for hours at 140 F without a t-stat but would jump like crazy between 180 and 230 in seconds when operated with a t-stat.
