Re: Roller cam install 108* or 104*
[Re: Moparrob68]
#3051857
06/19/22 10:43 PM
06/19/22 10:43 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
How does this cam compare to the one you're racing with now?
[Re: Moparrob68]
#3051870
06/19/22 11:34 PM
06/19/22 11:34 PM
Posts: 2,843 Pattison Texas
CSK
Pattison Texas
all you can do is try it & see what it does, that said piston to valve on the intake might be a problem with that big cam advanced
[Re: Moparrob68]
#3051889
06/20/22 04:12 AM
06/20/22 04:12 AM
Cab_Burge
Are you sure that you have sufficient fuel supply? Can you jet it rich enough to slow it down in the 60,330,660 and 1/4 MPH by fattening it up? If not, you can't fatten it up enough to slow it down look at fixing that now If you can slow it down by richening it up, look at shifting it sooner next Either way let us know I would also send that old damaged cam back to Reed, if they are still in business, and have them fix it
[Re: Moparrob68]
#3052536
06/22/22 08:19 PM
06/22/22 08:19 PM
Posts: 20,600 in a cattle trailer down by th...
Guitar Jones
Moving the cam 2° moves the power band about 50 RPM so no, 4° probably won't get you where you want to be.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#3052700
06/23/22 12:24 PM
06/23/22 12:24 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It’s more duration than I’d want, but if you’re going to use it....... check the p/v clearance....... and if fits with it in at 104....... that’s what I’d do. Then the performance just iiwii.
[Re: fast68plymouth]
#3053725
06/27/22 08:05 AM
06/27/22 08:05 AM
Posts: 4,003 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Right, if you're going to stick any old 'brain' in the motor it kinda is what it is. FWIW Bullet has been good to me so far on regrinds.
