Re: What headers are easies to intall in a 67 Charger with a 440
[Re: dssaa]
#3052138
06/21/22 09:18 AM
06/21/22 09:18 AM
Posts: 74,970 U.S.S.A.
JohnRR
U.S.S.A.
Having issues with the mini-starter in the 67 Charger I picked up. Its impacting the flywheel and not engaging. Tried several adjustments...no good. Decided to remove it and put in a stock starter. Car has long tube Hooker Headers, so there is my first issue. Impossible to remove the starter without dropping the header, right? Got all the bolts out, see that the torsion bar is running through the header, so that has to come out too! Also found the header was cracked in half at the manifold, and one of the tubes was coming apart. When I finally get this thing out, looking for recommendations for a better header setup? Or am I stuck....I can weld the header back together, but getting the starter/header back together is always a nightmare for me. Suggestions? Thanks! Dave in Colorado Picture of the header ? If the torsion bar went thru the header it sounds to me like the tube you think is cracked and broken is supposed to be like that so you don't have to take the t bar out to get the header in and out. Get an 1 7/8 primary tube header .
