Accumulator blocker rod/727 #3051385
06/17/22 09:04 PM
06/17/22 09:04 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
Anyone know the correct length for the accumulator blocker rod in a 727? My memory seems to think that it's 2.850", not sure I can trust it though. I ordered a bunch of parts and this one got left off the order. Don't want to wait until next week to finish this up.
Thanks, Brian
Re: Accumulator blocker rod/727 [Re: '72CudaRacer] #3051534
06/18/22 04:03 PM
06/18/22 04:03 PM
moparx Offline
moparx  Offline
the one in my B&M manual kit is 2.952 long.
it's a solid rod, and if i ever use this kit, i will make a new rod out of tubing.
i can't tell you what the TransGo rod length is, as it's in my car at present.
beer
Re: Accumulator blocker rod/727 [Re: moparx] #3051539
06/18/22 04:16 PM
06/18/22 04:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Either of those lengths will work as long as it's not too long to keep the VB from seating.
Re: Accumulator blocker rod/727 [Re: John_Kunkel] #3051541
06/18/22 04:25 PM
06/18/22 04:25 PM
moparx Offline
moparx  Offline
thanks John. up
beer
Re: Accumulator blocker rod/727 [Re: moparx] #3051623
06/18/22 10:46 PM
06/18/22 10:46 PM
Mooresburg, Tn
Mooresburg, Tn
Thanks guys. With the return spring out, it might not even need a rod. It's got one anyway.
Brian
Re: Accumulator blocker rod/727 [Re: '72CudaRacer] #3051744
06/19/22 02:57 PM
06/19/22 02:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
With the spring removed, the accumulator still fully functions on the 1-2 upshift. Only way to stop its function is a blocker rod.
Re: Accumulator blocker rod/727 [Re: John_Kunkel] #3051904
06/20/22 08:31 AM
06/20/22 08:31 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
mopar performance shift improver servo kit, .709 tubing 2.75 long
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Accumulator blocker rod/727 [Re: 440lebaron] #3051944
06/20/22 11:08 AM
06/20/22 11:08 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Does the rod hold it in or out of hole?
Re: Accumulator blocker rod/727 [Re: cudaman1969] #3051960
06/20/22 11:44 AM
06/20/22 11:44 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
With the trans mounted in the car the rod goes in first then the
piston. So the rod spaces the piston toward the valve body
mounting surface.
Re: Accumulator blocker rod/727 [Re: DusterW2] #3052070
06/20/22 06:27 PM
06/20/22 06:27 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
My apologies for hijacking the post, but lets say you were building a case from scratch, am I right in thinking that you could scrap the accumulator circuit/system entirely if you were running a manual valve body??
Alan Jones
Re: Accumulator blocker rod/727 [Re: LA360] #3052171
06/21/22 12:21 PM
06/21/22 12:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Many race valve bodies eliminate the accumulator with the goal of the firmest 1-2 upshift but doing so can lead to rear clutch failure. Ya pays your dime and ya takes your chances.
Re: Accumulator blocker rod/727 [Re: John_Kunkel] #3052216
06/21/22 03:47 PM
06/21/22 03:47 PM
NC
440Jim Offline
440Jim  Offline
NC
Good point.
As I recall, the Griner valve body needed a shorter blocker rod than the standard factory VB.
But I don't think it uses that circuit anyway.
Re: Accumulator blocker rod/727 [Re: 440Jim] #3052218
06/21/22 04:10 PM
06/21/22 04:10 PM
Loudoun County, VA
Brad_Haak Online content
Brad_Haak  Online Content
Loudoun County, VA
After asking a number of questions here on this topic years(?) ago, I decided to use these parts when I had the valve body off before my trans went in w/ the engine:
https://www.sonnax.com/parts/1851-accumulator-piston-kit
https://www.ctpowertrain.com/sonnax-new-hd-enhanced-performance-valve-body-accumulator-spring/
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Accumulator blocker rod/727 [Re: 440Jim] #3052264
06/21/22 09:17 PM
06/21/22 09:17 PM
NW Indiana USA
727specialist Offline
NW Indiana USA
Good point.
With the Griner you leave the accumulator out. Keith
Re: Accumulator blocker rod/727 [Re: 727specialist] #3052275
06/21/22 09:49 PM
06/21/22 09:49 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
First time I've heard that ! will leaving the accumulator piston in cause any problems?
Re: Accumulator blocker rod/727 [Re: cagebob1] #3052281
06/21/22 10:13 PM
06/21/22 10:13 PM
NW Indiana USA
NW Indiana USA
Not a problem unless it has a blocker that is to long and it holds the valve body up causing a leak.
All Griner valve bodies are this way. The accumulator does nothing.
The only exception is if it has the modification to get a line pressure from the accumulator port. Like the Pro Flite. Keith
Re: Accumulator blocker rod/727 [Re: '72CudaRacer] #3052330
06/22/22 08:40 AM
06/22/22 08:40 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Re: Accumulator blocker rod/727 [Re: Brad_Haak] #3052356
06/22/22 10:47 AM
06/22/22 10:47 AM
NW Indiana
P
powertrip Offline
powertrip  Offline
P
NW Indiana
Thanks for those links, ordered the spring for my loooong term project. I have also thought that a heavier spring would be best for a street/strip car.
