Re: Accumulator blocker rod/727
[Re: '72CudaRacer]
#3051534
06/18/22 04:03 PM
06/18/22 04:03 PM
Posts: 19,555 north of coder
moparx
the one in my B&M manual kit is 2.952 long. it's a solid rod, and if i ever use this kit, i will make a new rod out of tubing. i can't tell you what the TransGo rod length is, as it's in my car at present.
[Re: moparx]
#3051539
06/18/22 04:16 PM
06/18/22 04:16 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Either of those lengths will work as long as it's not too long to keep the VB from seating.
[Re: '72CudaRacer]
#3051744
06/19/22 02:57 PM
06/19/22 02:57 PM
John_Kunkel
Rio Linda, CA
With the spring removed, the accumulator still fully functions on the 1-2 upshift. Only way to stop its function is a blocker rod.
[Re: John_Kunkel]
#3051904
06/20/22 08:31 AM
06/20/22 08:31 AM
Posts: 1,610 westerly, ri. usa
440lebaron
westerly, ri. usa
mopar performance shift improver servo kit, .709 tubing 2.75 long
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: DusterW2]
#3052070
06/20/22 06:27 PM
06/20/22 06:27 PM
Posts: 6,148 Melbourne , Australia
LA360
My apologies for hijacking the post, but lets say you were building a case from scratch, am I right in thinking that you could scrap the accumulator circuit/system entirely if you were running a manual valve body?? ??
Alan Jones
[Re: LA360]
#3052171
06/21/22 12:21 PM
06/21/22 12:21 PM
John_Kunkel
Rio Linda, CA
Many race valve bodies eliminate the accumulator with the goal of the firmest 1-2 upshift but doing so can lead to rear clutch failure. Ya pays your dime and ya takes your chances.
[Re: John_Kunkel]
#3052216
06/21/22 03:47 PM
06/21/22 03:47 PM
Posts: 16,929 NC
440Jim
NC
Either of those lengths will work as long as it's not too long to keep the VB from seating. Good point. As I recall, the Griner valve body needed a shorter blocker rod than the standard factory VB. But I don't think it uses that circuit anyway.
[Re: 440Jim]
#3052218
06/21/22 04:10 PM
06/21/22 04:10 PM
Posts: 1,151 Loudoun County, VA
Brad_Haak
Loudoun County, VA
After asking a number of questions here on this topic years(?) ago, I decided to use these parts when I had the valve body off before my trans went in w/ the engine: https://www.sonnax.com/parts/1851-accumulator-piston-kithttps://www.ctpowertrain.com/sonnax-new-hd-enhanced-performance-valve-body-accumulator-spring/
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: 440Jim]
#3052264
06/21/22 09:17 PM
06/21/22 09:17 PM
Posts: 377 NW Indiana USA
727specialist
NW Indiana USA
Either of those lengths will work as long as it's not too long to keep the VB from seating. Good point. As I recall, the Griner valve body needed a shorter blocker rod than the standard factory VB. But I don't think it uses that circuit anyway. With the Griner you leave the accumulator out. Keith
[Re: cagebob1]
#3052281
06/21/22 10:13 PM
06/21/22 10:13 PM
727specialist
NW Indiana USA
First time I've heard that ! will leaving the accumulator piston in cause any problems? Not a problem unless it has a blocker that is to long and it holds the valve body up causing a leak. All Griner valve bodies are this way. The accumulator does nothing. The only exception is if it has the modification to get a line pressure from the accumulator port. Like the Pro Flite. Keith
