Overdrive trans change over #3051216
06/17/22 10:33 AM
06/17/22 10:33 AM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Two trucks 79 and 88 both had regular trans, I’m planning to install the overdrive 518 in both and wondering if the trans mount can adapt to the overdrive?
Re: Overdrive trans change over [Re: cudaman1969] #3051225
06/17/22 11:02 AM
06/17/22 11:02 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
With some fabrication you can make it work. IIRC, I made an "adapter" steel plate to attach the three bolt pattern OD to the two bolt pattern non OD pattern in 1991. Couldn't find a newer truck in the JY at the time. Not too much trouble. Driveline angle is the hard part. For that I had to cut, fabricate reinforcements and lower the center portion of the crossmember. Find an OD crossmember and save a lot of trouble.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Overdrive trans change over [Re: 3hundred] #3051254
06/17/22 12:19 PM
06/17/22 12:19 PM
fredericksburg,va
fredericksburg,va
A bolt in thing?
Re: Overdrive trans change over [Re: cudaman1969] #3051268
06/17/22 01:04 PM
06/17/22 01:04 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
A bolt in thing?
IIRC, we welded it to the existing mount, thinking we had bolt clearance issues. I remember we smoked the rubber mount, might want to start with a poly mount? The "adapter" plate matched the 3 bolt pattern of the OD trans. We should have added an offset bend, there's also an elevation change between the 2 bolts and single bolt. We used washers to make up the difference, not the best but it worked.
edit: oh the crossmember? Yeah, I think so. I finally sourced one but never got around to installing it before I sold the truck. There's a LOT of different part numbers, I think they're all interchangeable. You may have to drill new holes in the frame, the OD is 6 15/16" longer than the non OD. We used the welding on of the adapter plate to make up the difference.
'69 300 Convertible
'16 300 S Hemi
Re: Overdrive trans change over [Re: cudaman1969] #3051316
06/17/22 03:52 PM
06/17/22 03:52 PM
Guitar Jones Offline
crossmember
adapter plate
mount
This worked for my NV4500 swap. I didn't need the adapter plate as the mount bolted directly to the trans.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Overdrive trans change over [Re: Guitar Jones] #3051324
06/17/22 04:18 PM
06/17/22 04:18 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
That is a work of art.
Re: Overdrive trans change over [Re: MarkZ] #3051348
06/17/22 05:57 PM
06/17/22 05:57 PM
fredericksburg,va
fredericksburg,va
Thanks, great ideas so far
Re: Overdrive trans change over [Re: cudaman1969] #3051564
06/18/22 06:59 PM
06/18/22 06:59 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
look at mopar parts giant. it appears that there are 2 different setups. i just went thru this when i shortened an 86 long bed frame to a short bed frame. i thought that i had all the right stuff but things did not work out correctly. i went to two different pick/pull yards and found 3 trucks to pull the stuff off of. 2 were different. i still try to collect the stuff as i have a bunch of trucks. look at the p/p's.
Re: Overdrive trans change over [Re: trw1982] #3051576
06/18/22 07:56 PM
06/18/22 07:56 PM
fredericksburg,va
fredericksburg,va
Thanks, I’ll try to use the mounts off both vans somehow. 92 and 94
Re: Overdrive trans change over [Re: cudaman1969] #3052255
06/21/22 08:59 PM
06/21/22 08:59 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
I swapped my '71 Sweptline and my wife's '79 LRE from 727 to 518. Built adapters for both that bolted to the factory crossmember...not pretty but they've both done over 20,000 miles with no issues. If you've got the mount to go with the 518 and average fab skills it's not a big deal. You CAN do the "work of art" mount if you've got the skills and equipment. With the pressure and vacuum switch setup for shifting the OD and lockup, it's an awesome swap and well worth doing.
Re: Overdrive trans change over [Re: nuthinbutmopar] #3062893
07/27/22 03:03 AM
07/27/22 03:03 AM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
Last one I did was a two-wheel drive D100. Crossmember out of a 92 Ramcharger was used. set it in the frame drilled six holes and everything was bolt in. And note to self when using a plasma cutter for piercing the holes in the cab is on the frame. Make sure you stick some heavy steel between the two otherwise you'll have a hole in the floorboard. Ask me how I know🤣
