I belive most if not all ther products address the electronic actuated transmissions like the 46RE.
I talked them for a good bit yesterday, helpful guy. Their controller will work on the RH's for most applications. Their control
Has a lot of features though that make it the most useful on an RE for the cost.
I drew up a control strategy last night using the haltech, the ramcharger is basic in engine operation, so I have a ton of
Redefinable inputs and outputs left over to do some extra control with the transmission using only tcc lockup and Od.
I can setup a tow/haul mode with different od and tc lockup, I can also setup a 4x4 mode to lock the converter lower in ground speed but with a different engine rpm and also have it there for engine braking and have a brake pedal input to turn it off. Another switch input from Tps position will mean I can automatically unlock the converter in highway mode when throttle position is zero, to coast without engine braking.
Now I just have to choose a throttle body with injectors and a high pressure fuel system for the truck, I luckily have a half dozen or so bosch 044's kicking around and some high pressure fuel stuff from other projects.
