727 input shaft help #3049656
06/11/22 12:54 PM
06/11/22 12:54 PM
New England
Tech Instructor Offline OP
New England
Can anyone identify this input shaft it is a 24 spline but my question is the shaft is solid it has no feed holes on the hub end also would a specific stator support be required I was told it came out of a motorhome 727.It is not a lockup shaft as well
Re: 727 input shaft help [Re: Tech Instructor] #3049678
06/11/22 02:12 PM
06/11/22 02:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Pic is too small and blurry. Count the splines, if 19 it's '66-earlier, if 24 it's '67-later.
Re: 727 input shaft help [Re: Tech Instructor] #3049748
06/11/22 06:48 PM
06/11/22 06:48 PM
A727Tflite Offline
A727Tflite  Offline
If no passage between the two seal grooves - then >
That input was released in preparation for the release of lock up. It requires a matching rear clutch piston support which has a metal seal ring on it that engages the matching reaction shaft support.
Rear clutch apply is achieved between the rear input shaft seal ring and the metal ring on the piston support.
Re: 727 input shaft help [Re: A727Tflite] #3049752
06/11/22 07:06 PM
06/11/22 07:06 PM
New England
New England
Thank you that's what I needed do you have a part number by chance for the reaction shaft support
Re: 727 input shaft help [Re: Tech Instructor] #3049761
06/11/22 07:46 PM
06/11/22 07:46 PM
A727Tflite Offline
A727Tflite  Offline
No but I’ll look up the exact year we made that change and post a pic of each part.
Most parts houses can get you what you need knowing what year. At least the one side I have dealt with.
Re: 727 input shaft help [Re: A727Tflite] #3049852
06/12/22 09:57 AM
06/12/22 09:57 AM
A727Tflite Offline
A727Tflite  Offline
Parts changed for 1978 model year.
See pics.
The reaction shaft support you need will have provisions for three ball plugs on the rotor side but only have two installed. You will also notice it has the lead in chamfer like some of the earlier supports, this is where the seal rides that’s in the piston support. The rear input shaft seal and this piston support seal apply rear clutch.
The rear clutch piston retainer has a metal seal in it.
Re: 727 input shaft help [Re: A727Tflite] #3050026
06/12/22 08:20 PM
06/12/22 08:20 PM
New England
New England
Thank you great information
