Best hp per $$ items for an 8 second build
#3049290
06/10/22 06:37 AM
06/10/22 06:37 AM
Posts: 9,963 Frostbitefalls MN (Rocky&Bullw...
gregsdart
After having gone down the wrong road more than a few times over the years, i thought it would be good to get opinions on where to put the money to build an 8 second door car? Lets hear it,,,!
Re: Best hp per $$ items for an 8 second build
[Re: gregsdart]
#3049293
06/10/22 06:46 AM
06/10/22 06:46 AM
gregsdart
Well, i will start, cubic inchs. Buy all you can. Aluminum 4.5 bore block. Light weight race disc brakes, due to weight savings Lithium battery and leave it up front. ( 16.5 lbs, save at least 8 to 10 lbs on cables to back of car) Chrome moly cage, mustang II front, ladderbars
[Re: gregsdart]
#3049299
06/10/22 07:09 AM
06/10/22 07:09 AM
Posts: 2,901 A shed in England
Tig
A shed in England
Light car, big tyre chassis. Total opposite to what I've done
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3049303
06/10/22 07:42 AM
06/10/22 07:42 AM
Posts: 9,791 MI, usa
dvw
MI, usa
We already know. We just don't do it. Don't start with a factory car. Use a light 4 link, strut, tube chassis, panel car. A big engine with high compression. My original short block with similar -1 heads went 8.10@169, 2470lbs 10 years ago before I got it. Doug
[Re: Tig]
#3049305
06/10/22 07:48 AM
06/10/22 07:48 AM
Posts: 570 UK
rb446
UK
Light car, big tyre chassis. Total opposite to what I've done Your 655 in my not so light 3300lb '69 Cuda would've gone 8.50>60's@155 if the 2x3 chassis would've handled it. As for parts we have a '69 Cuda going 8.70's@154 with an all ally 540 low deck motor on alky with rons toilet, -1's and an .800-ish roller.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: racerx]
#3049327
06/10/22 09:36 AM
06/10/22 09:36 AM
dvw
MI, usa
Member here TS3303. Tube chassis latter model Daytona. Doug
[Re: rb446]
#3049348
06/10/22 10:44 AM
06/10/22 10:44 AM
Tig
A shed in England
Light car, big tyre chassis. Total opposite to what I've done Your 655 in my not so light 3300lb '69 Cuda would've gone 8.50>60's@155 if the 2x3 chassis would've handled it. Still hopeful that we will dip into the 8's in good air with the 655, needs an honest 1100hp though.
[Re: Tig]
#3049378
06/10/22 11:57 AM
06/10/22 11:57 AM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Remove weight.
From what you have or by trading up to a lighter car.
[Re: CMcAllister]
#3049386
06/10/22 12:17 PM
06/10/22 12:17 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
No doubt lighter is better period! Cheaper to loose weight than build power. There is no "magic bullet" but having a goal and a plan and STICKING to it will usually yield the desired result. Also having the "want to" is a large part of it, as long as the goals are REALISTIC!
Having said all that been a LONG time since I have NOT had an 8 second car. My 64 has been in the 8's at 3600. I would imagine it makes less power than many here think. It is still a work in progress as well. I just cut the old age out and put a new moly one in it, still have some ignition issue to find and that will likely lead to a complete rewire if the car. My current goal is to run an 8 here in Vegas. We have been 9.teens so far here and one hero run a tad quicker. I just plan to refine whats already done, converter is a tad tight, shocks are just ok and until I can get the chassis to work with all the power in at the hit Ill likely not make my goal. But I know its achievable and realistic. We are also hoping with a few minor changes to the dragsters engine to be in the 6's with a BB Mopar NA...My truck I am building for .90 stuff so ultimately the ET goal does not matter as setting a car up for max MPH on the stop is not the way to go the quickest ET's but hopefully it can go 5.0's in the 1/8 in great air.
[Re: CMcAllister]
#3049394
06/10/22 12:40 PM
06/10/22 12:40 PM
Posts: 1,597 westerly, ri. usa
440lebaron
westerly, ri. usa
tube chassis lebaron 540 .750 roller 1150 dom 2450lbs 8.85 155 used race car $10,000-20,000 engine 10,000 = $30.000 ?
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: mgoblue9798]
#3049418
06/10/22 02:14 PM
06/10/22 02:14 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
The cheapest power you can get right now is probably a stock bottom end LS, Gen III Hemi, or Coyote ford with a turbo charger on it. Its insane how fast some low budge builds have gone. One of our own members has stepped over to the darkside and gas a 8 second turbo LS mustang, I just can't remember his screen name lol. The sloppy mechanics 8 seconds for $8000 build was interesting also. Started with nothing but knowledge and went 8.83 for 8000ish. Link https://sites.google.com/site/sloppywiki/sloppy-builds/8s-for-8-mustang
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: Bad340fish]
#3049429
06/10/22 02:52 PM
06/10/22 02:52 PM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The cheapest power you can get right now is probably a stock bottom end LS, Gen III Hemi, or Coyote ford with a turbo charger on it. Its insane how fast some low budge builds have gone. One of our own members has stepped over to the darkside and gas a 8 second turbo LS mustang, I just can't remember his screen name lol. The sloppy mechanics 8 seconds for $8000 build was interesting also. Started with nothing but knowledge and went 8.83 for 8000ish. Link https://sites.google.com/site/sloppywiki/sloppy-builds/8s-for-8-mustang We should Just start calling this website “anything goes” or “whatever it takes”. Man Mopar guys are a different breed now.
[Re: Bad340fish]
#3049440
06/10/22 03:41 PM
06/10/22 03:41 PM
Posts: 4,651 Wichita
GY3
Wichita
The cheapest power you can get right now is probably a stock bottom end LS, Gen III Hemi, or Coyote ford with a turbo charger on it. Its insane how fast some low budge builds have gone. One of our own members has stepped over to the darkside and gas a 8 second turbo LS mustang, I just can't remember his screen name lol. The sloppy mechanics 8 seconds for $8000 build was interesting also. Started with nothing but knowledge and went 8.83 for 8000ish. Link https://sites.google.com/site/sloppywiki/sloppy-builds/8s-for-8-mustang I love watching his builds. The white Colorado was awesome! Slammed together used bits with a China turbo and doing 1,000 HP at the rear wheels. He has a Fairmont waiting in the wings that should be interesting.
[Re: pittsburghracer]
#3049441
06/10/22 03:50 PM
06/10/22 03:50 PM
Bad340fish
Tulsa OK
The cheapest power you can get right now is probably a stock bottom end LS, Gen III Hemi, or Coyote ford with a turbo charger on it. Its insane how fast some low budge builds have gone. One of our own members has stepped over to the darkside and gas a 8 second turbo LS mustang, I just can't remember his screen name lol. The sloppy mechanics 8 seconds for $8000 build was interesting also. Started with nothing but knowledge and went 8.83 for 8000ish. Link https://sites.google.com/site/sloppywiki/sloppy-builds/8s-for-8-mustang We should Just start calling this website “anything goes” or “whatever it takes”. Man Mopar guys are a different breed now. I accept all fast cars, the ones I own happen to be Mopars but I will pay attention and learn from all of it. If my whole setup were to burn to the ground I would probably come back with a Fox body mustang with a Gen III hemi lol.
