Pics of 5.2 Magnum motor mounts for a 95 Dakota?
#3048613
06/07/22 01:30 PM
06/07/22 01:30 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Looking for photos showing the motor mounts in position on the block of a 5.2 Magnum. I believe this series of Dakotas are referred to as 1st generation (87 -96). I searched the web and only came up with pictures showing them separate from the block. Thanks!
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Pics of 5.2 Magnum motor mounts for a 95 Dakota?
[Re: jbc426]
#3048737
06/07/22 09:22 PM
06/07/22 09:22 PM
Posts: 10,524 Freeport IL USA
poorboy
Freeport IL USA
I believe they mount differently on the block between a 4x4 Dakota and a rear drive Dakota. If I remember right, the 4x4 Dakota used the ear on the block for the motor mounts. All I have here right now is a 96 4x4, but I have no clear pictures of the motor mount, during the build process, and its nearly impossible to get a picture of them now, those motor mounts are buried deep. BTW, the motor mount brackets on a Dakota 4x4 are also the front differential mount, the two 1/2 shafts provide the suspension travel.
I believe the early Magnum motors had both the old style ear mounting like the LA motors, and the modern motors use 3 bolts into the bosses on the block. I'm not sure when the ear mounting went away, but they are not present on the later magnum motors.
The "modern" mounts that use the 3 bolts is pretty straight forward, the location for each bolt matches the slightly raised threaded boss on the block. The mount only fits one way, slightly forward of the center of the block, front to back, and the bolts pass through the mount and into the threaded bosses.
[Re: poorboy]
#3048848
06/08/22 11:01 AM
06/08/22 11:01 AM
jbc426
West Coast, USA
Thanks for the information! I'm building a '95 chassis to put under a '57 Dodge 100, and am trying to see how much if any I will have to clearance on the firewall & floor to fit the motor. I have a 2000 5.9 Magnum that uses the ear mounting tabs towards the front of the block. I climb under my car and see if I see the raised bosses you mentioned. Thanks again.
[Re: poorboy]
#3049110
06/09/22 12:25 PM
06/09/22 12:25 PM
jbc426
West Coast, USA
I'll do that. Thank you. Much appreciated.
[Re: jbc426]
#3049233
06/09/22 08:35 PM
06/09/22 08:35 PM
Posts: 4,561 Motor City
6PKRTSE
Motor City
Dakota 2WD drive and 4WD have totally different frame mounts, they also incorporate mounting the front differential housing from underneath as well.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
