Best dimple method
#3047920
06/04/22 07:06 PM
06/04/22 07:06 PM
Posts: 4,707 Florida
BDW
Test fit my engine and have interference between the TTI headers and steering pump. Seems like I need to put a rounded ding in the header. What's a good method to not remove the coating on the header? Thx
Re: Best dimple method
[Re: BDW]
#3047922
06/04/22 07:48 PM
06/04/22 07:48 PM
Posts: 12,019 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I use a deep well socket with an extension as a handle. Pick the best size socket for the size of dent needed and slap with a hammer accordingly. Smooth and round with no sharp corners when whacked just right.
Master, again and still
[Re: TJP]
#3047940
06/04/22 10:03 PM
06/04/22 10:03 PM
BDW
Good question on the leaning, quite possible. I didn't install the bolts in the brackets, engine was just sitting down on mounts, supported by lift. Which brings up my next question. How much will engine shift around with the rubber biscuit motor mounts? Seems like there should at least 1/4" or more? I also only have 1/4 for alternator, but that's an easier fix.
[Re: BDW]
#3048014
06/05/22 12:34 PM
06/05/22 12:34 PM
Posts: 15,304 Omaha Ne
TJP
Omaha Ne
Good question on the leaning, quite possible. I didn't install the bolts in the brackets, engine was just sitting down on mounts, supported by lift. Which brings up my next question. How much will engine shift around with the rubber biscuit motor mounts? Seems like there should at least 1/4" or more? I also only have 1/4 for alternator, but that's an easier fix. That is a hard to answer question as it depends on the mounts and rubber used as well as gearing, traction and a few other variables. The good news is the motor torques to the right under hard accel going forward, and of course the opposite in reverse so unless you plan on doing burnouts in reverse that's in your favor. I have known a few that have drilled through the mounts and used flat head hard ware to limit the movement while retaining the isolation of the rubber. Don't know if Urethane mounts are available but the are usually stiffer and interlocked
[Re: BDW]
#3048104
06/05/22 05:51 PM
06/05/22 05:51 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Can you shim under the mounts to raise the engine?
[Re: John_Kunkel]
#3048117
06/05/22 07:11 PM
06/05/22 07:11 PM
BDW
Can you shim under the mounts to raise the engine? Hadn't thought of that? Where would the shim go, between mount that bolts to block and block? Maybe add 1/4" of washers in each spot?
[Re: BDW]
#3048148
06/05/22 09:53 PM
06/05/22 09:53 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I've used a piece of belt leather and a ball peen hammer. I've also used an oxy/acetylene torch and a hammer. Then touched up the areas with VHT Hi-temp paint.
I overheated a set of TTI's and repainted the entire exhaust matt black using VHT Hi-temp paint. It's still looking good 6 years later.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
