70 Charger headlight door problem, elec.
#3047823
06/04/22 10:03 AM
06/04/22 10:03 AM
Posts: 1,317 Ohio
jlatessa
Ohio
It's been on the road for 6 years, and everything has been fine up to now.
Doors quit working a few days ago and I did a couple of voltage checks at the motor and the relay assembly. When I rewired the car, I put the relay asbly into the engine compartment and used a Bosch relay with the little canister type, two connecter "relay"? attached with a tie wrap just to make it easier to service.
No voltage to the motor with the lights on, and just trace voltage, (3 or 4) to the little canister terminals.
Where do I go from there to figure this out?
Thanks,
Joe
Edit, I guess I should patch another Bosch in, but I've never had one fail before??
Re: 70 Charger headlight door problem, elec.
[Re: jlatessa]
#3047844
06/04/22 12:22 PM
06/04/22 12:22 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
What relays are we talking about?
Headlight doors just use one, and is triggered from light switch, hence inside the cab since must be before the floor dimmer switch.
Headlights relay upgrade themself would require two, one for each beam (although could be wired diff, but that's the standard one) and that one could be installed on engine bay, althought I installed mines into the cab between floor dimmer switch and bulkhead for a cleaner view into engine bay without relays.
So, if the doors are not coming up and headlights are working, problem is on doors relay, motor or motor wiring... or lack of ground at relay or motor.
[Re: NachoRT74]
#3048017
06/05/22 12:43 PM
06/05/22 12:43 PM
NachoRT74
Valencia, España
I must add, the headlight doors relay even is triggered by the light switch is SOURCED by the Run circuit and in stock from gets a circuit breaker on this line. So, still if the trigger signal is not working, relay should still be sourcing for some of the circuits. If no one of both wires for open or close the doors is live with ign key in RUN, you can get a relay failure, circuit breaker failure or this source is broken before the relay/breaker.
[Re: NachoRT74]
#3049086
06/09/22 09:59 AM
06/09/22 09:59 AM
Posts: 1,317 Ohio
jlatessa
Ohio
Thanks all, Natcho, I found your schematic on the 3 wiring options, I used #3 and ordered another 5 pin relay, but after looking at the wiring and the initial test I did, I think we've lost the 12 V supply.
It's been awhile since we drove at night, and we've done some alterations to our wiring in the interim, so we'll start there.
Thank you all,
Joe
[Re: jlatessa]
#3049232
06/09/22 08:33 PM
06/09/22 08:33 PM
Posts: 4,562 Motor City
6PKRTSE
Motor City
Don't forget. There is always the manual knob on the motor to open and close them in case of emergencies.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3049260
06/09/22 10:57 PM
06/09/22 10:57 PM
Posts: 1,317 Ohio
jlatessa
Ohio
[Re: jlatessa]
#3049352
06/10/22 11:03 AM
06/10/22 11:03 AM
NachoRT74
Valencia, España
First Nacho, sorry for misspelling your name, second, since I moved the headlight door breaker and relay next to the headlight upgrade relays when we rewired, why don't I tap into the 12 V wire going to the low beams for door initiation?
I'll just terminate the old wire....
Joe relay must remain into the cab because the trigger is before the floor dimmer switch. If you tap the trigger into the low beam signal, door will close as soon you put high beams... if the relay is being sourced of course. Also, the 12 volts power should be tapped into a keyed circuit... run or acc. Originally is onto the run circuit, to allow to keep doors open while in acc for beams adjustment or replacement without get doors closed as soon you turn off the lights there is no reason to move to the engine bay ( don't worry about the name misspeling LOL )
