Re: Milodon Oil Pan Gasket Recommendation
[Re: OrangeProwler]
#3047813
06/04/22 08:32 AM
06/04/22 08:32 AM
Posts: 6,225 nowhere
Sniper
nowhere
You need to be more specific as to what gasket you are using and what you are thinking of. I see Milodon offers three oil pan gaskets that may be applicable to the conversation here. Two LA's and one Magnum, Of the two LA's one is for the 318/340 pans and the other is for the 360 pan. They do not interchange. The Magnum one is listed as for "Chrysler 360 (1992-2003 Magnum Only)" which is not entirely correct, it should fit all magnums. But basically, the gasket needs to match the pan. Here's a good thread with pictures to show what's happening. https://www.forabodiesonly.com/mopar/threads/la-oil-pan-on-magnum.441111/
[Re: OrangeProwler]
#3047838
06/04/22 11:48 AM
06/04/22 11:48 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I had overlooked the two notches at the timing cover when I put an LA pan on my Magnum. I ended up flattening the notches with a hammer and dolly to essecially remove the notches. I was able to use the modern one piece gasket effectively after that.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
