Re: Is crank shot 2 images
[Re: fal3]
#3046848
05/31/22 05:24 PM
05/31/22 05:24 PM
Posts: 2,749 Michigan
Transman
A continuation. Thanks ahead for advice/suggestions. Oh, might be important: re-built in Fall'98; has 25,000 miles. Connecting rod journals grind .040; main journals grind .030 on re-build. Lose the pictures of the rod and cap without the bearings. Show #7 and 8 rod bearings.
Re: Is crank shot images
[Re: poorboy]
#3046934
05/31/22 10:12 PM
05/31/22 10:12 PM
Posts: 4,130 West Plains, MO
DrCharles
West Plains, MO
The only Crankshaft I ever broke was turned .030 on the rods & mains. It's hard to conclude anything useful from a sample size of 1  Couldn't it be equally likely that that crank had a LOT of hard use, having been turned down three times? What about turning the rod journal down for a 2.100 Chevy rod? Those engines don't seem to break cranks constantly
[Re: fal3]
#3046960
06/01/22 01:40 AM
06/01/22 01:40 AM
Posts: 40,855 Bend,OR USA
Cab_Burge
[Re: fal3]
#3047162
06/01/22 04:16 PM
06/01/22 04:16 PM
Posts: 19,797 Park Forest, IL
slantzilla
Park Forest, IL
What do the bearing halves out of the rods look like? They will probably look worse.
