Re: Alphabet sites not responding
[Re: Kern Dog]
#3047152
06/01/22 04:56 PM
06/01/22 04:56 PM
Posts: 29,648 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
This has happened to you fairly often, correct? Have you ever really tried enough introspection to realize the the sites themselves are not the problem in this equation? Guess what the common denominator is here........ If you are not sure, a look in the mirror may help?
[Re: Alaskan_TA]
#3047271
06/01/22 11:40 PM
06/01/22 11:40 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
This has happened to you fairly often, correct? Have you ever really tried enough introspection to realize the the sites themselves are not the problem in this equation? Guess what the common denominator is here........ If you are not sure, a look in the mirror may help? It was a joke, Lipshitz. The "look in the mirror" schtick is as old as the hills and clearly shows a lack of wit and originality. Every person that uses this is as bad as the guy that says "Hey, you missed a spot" while you're washing a car. The internet access was wacky here today. Some sites loaded fine, others timed out and failed to load. It happens sometimes.
