Recommend a 275 drag radial for street/strip #3045217
05/25/22 08:26 PM
05/25/22 08:26 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
I have ran Mickey Thompson drag radials on the Cuda for quite a few years. But the last couple of sets have been bad out of round. Now that is not real bad at the track, but on the street, it is really uncomfortable. And this year the car will see a lot more street time, than track time. The MTs hook okay, but they are egg shaped and no amount of weights can help that.
It is now time for a new pair of 275/60-15s and I haven't bought a set in 3 years. So have the MTs gotten any better? How about the Hoosiers? Any other brands that hook like the MTs, but are round?
Thank you!
Master, again and still
Re: Recommend a 275 drag radial for street/strip [Re: DaveRS23] #3045219
05/25/22 08:36 PM
05/25/22 08:36 PM
AndyF Offline
AndyF  Offline
I had a couple of sets of MT drag radials on the Duster and they were both egg shaped. Not sure if the tires are just poorly made, or if it had to do with the fact that the car sat a lot.
Re: Recommend a 275 drag radial for street/strip [Re: AndyF] #3045225
05/25/22 08:54 PM
05/25/22 08:54 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
It has been suggested to me that my Mickeys are egg shaped because the car does sit a lot. But they were that way when I mounted them. I was told that they would get in shape after a bit of driving. eyes They didn't.
Re: Recommend a 275 drag radial for street/strip [Re: DaveRS23] #3045252
05/25/22 10:59 PM
05/25/22 10:59 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Hoosier 17317
Love them, street drive a good bit
Hook hard at the track
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Recommend a 275 drag radial for street/strip [Re: B3422W5] #3045298
05/26/22 10:10 AM
05/26/22 10:10 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I use the ET Street Pro. No issues with out of round here.
I will say they DO NOT like to be balanced the way typical tires do. Leave the weights off!
'63 Dodge 330
11.19 @ 121 mph
Re: Recommend a 275 drag radial for street/strip [Re: GY3] #3045303
05/26/22 10:16 AM
05/26/22 10:16 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Ditto...I run the Pros and don't balance them and have no issues at 135 mph.
Re: Recommend a 275 drag radial for street/strip [Re: TheOtherDodge] #3045307
05/26/22 10:43 AM
05/26/22 10:43 AM
an8sec70cuda Offline
I've never used them, but I have a friend that uses a loves the M&H drag radials. He bought them a few years ago for Drag Week when you couldn't find any M/T radials anywhere.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Recommend a 275 drag radial for street/strip [Re: an8sec70cuda] #3045322
05/26/22 11:47 AM
05/26/22 11:47 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Would that friend be Ray? Sounds like something he told me a couple of years ago. I've seen vids of some people going pretty quick on the M&H, but have no personal or close second-hand experience.
When people are referring to M/T, please remember they currently have three 275/60R15 offerings:
- ET Street S/S, which is DOT legal and supposed to be like the original ET Street construction, only w/ additional grooves
- ET Street R, which is DOT legal and built more like the ET Street Pro, only "just enough"grooves that M/T still promotes it as a street-legal option
- ET Street Pro, which is not DOT legal for highway although some people run them on the street like GY3 does
The original and the S/S have steel belts in their construction. The R and the Pro do not, which is why their sidewalls behave differently (and likely part of why they hook better w/ what's supposed to be the same compound).
The original ET Streets on my old car never had any balancing or out-of-round issues and were smooth up to 125+ MPH. The ET Street S/S on my 1320 (305/40R18, not 275/60R15) do act a bit "funny" at maybe 90+; not sure if they need to be rebalanced due to possibly spinning on the rims after some track time, or and indication that they don't run true that's showing up on the big end. It's not scary, but it's there... feels like hitting a bumpy section of the track when it starts doing it.
I don't know what the Nitto NT555RII would do on my old car, although it would probably be "OK" on my 1320. From a few reviews I've seen, they sound like the work decently when new, but get baked from repeated heat cycles and don't grip as well even when there's still a lot of tread on them. The do make a 275/60R15, but I don't know anyone personally that runs that size.
shruggy
FWIW, tread patterns from left to right: NT555RII, ET Street S/S, M&H
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Recommend a 275 drag radial for street/strip [Re: DaveRS23] #3045462
05/26/22 08:07 PM
05/26/22 08:07 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
I spoke to MT tech this morning. 'Mark' beat around the bush some, but after a few minutes, "yes, there are some tires that aren't as round as we would like" and that they would warranty them if out of round. But, he says that there are very few out of rounds. Well, I have 2 now, and have had ones in the past, too. One thing he said that was new information to me was that 1% of the tire's weight was the acceptable limit for balance weights. First I have heard that and is something that I will keep in mind in the future.
I guess that I will go with the Mickeys again. If they are round, hurray! If not, we'll see how good their customer service really is. Since the car will see mostly street time, I plan to go with the S/S tire this time.
McCormack Racing on ebag seems to have the best price that I can find and they claim to have them in stock. I'll find out tomorrow. $490 a pair shipped. Any better deals out there?
Thanks for the help, guys. I appreciate it.
Oh, and one last question; anyone use the 'beads' in their DRs rather than weights? Are you happy with the results?
Re: Recommend a 275 drag radial for street/strip [Re: DaveRS23] #3045472
05/26/22 09:32 PM
05/26/22 09:32 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Bought my last 2 sets of Mickey Thompson tires from McCormack. up
Go directly to their website, instead of eBarf. Sign up for their "club" program and it'll save you a couple bucks more than buying on eBarf.
Re: Recommend a 275 drag radial for street/strip [Re: Brad_Haak] #3045499
05/26/22 10:33 PM
05/26/22 10:33 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
The Hoosier drag radial I mentioned above, and have such good luck with..is out of stock everywhere I checked, and I need new ones. Hoping for one more track outing on these I have
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Recommend a 275 drag radial for street/strip [Re: DaveRS23] #3045831
05/28/22 11:05 AM
05/28/22 11:05 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I run Nitto 555R 275/60-15's. They work very well on the street, but they only work well between a somewhat narrow temperature range. Too hot gets them greasy feeling, too cool and they spin almost as bad as a Radial T/A. They are also speed rated to 186 MPH.
Re: Recommend a 275 drag radial for street/strip [Re: jbc426] #3045887
05/28/22 01:30 PM
05/28/22 01:30 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have tried many on my Charger, nitto 555 no hook, MT hooked great egg shaped , hoosier hooked great but drove like crap on the street, [ soft side walls] have M&H now, hook great, drive ok
