Under hood fuel press. gauge reads low at OT #304534
05/01/09 01:49 PM
05/01/09 01:49 PM
Highland, CA
Mosin Offline OP
Mosin  Offline OP
Highland, CA
Hi All,
Is it common for in-line fuel gauges mounted in the engine cpt. to read lower when the engine is at OT? I ask because my Mr. Gasket FP gauge reads a strong 6.5 at startup, but then drops to ~2-4 once the engine warms up. The path is
tank>canister filter> Carter P4600HP>in-line filter>Holley press reg>gauge>carb
Thanks!
Re: Under hood fuel press. gauge reads low at OT [Re: Mosin] #304535
05/01/09 08:19 PM
05/01/09 08:19 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Extremely common that a liquid filled gauge changes reading with temperature. Often low or nothing at normal under hood temps.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
