Page 2 of 3 1 2 3
Re: Fancy ignition issues [Re: HardcoreB] #2988276
11/23/21 03:14 PM
11/23/21 03:14 PM
an8sec70cuda Offline OP
Originally Posted by HardcoreB
Yeah, I had a similar experience I'll share FWIW. Being old school I also had analog ignition systems before. I put a used msd7 digital 7530 box in the car from a friends car when he upgraded to the grid system. MSD help is about worthless anymore, I liken it to any other major business. The instructional videos are poorly done and unprofessional. It took me a while to actually figure out how to change things but, to Tony's point we have to advance with the technology/ages. It's been working properly now but, I still bought a used back-up box from another local racer for cheap. I guess that's just prudent anymore? It's a shame that the prices have soared and the quality has plummeted.
I'd grab another 6530 if I could find one cheap enough. I don't think I'll be dropping $500 on an extra though. And yes, MSD's tech support is garbage. They'll tell you everything is wrong and the box is fine. laugh2
BTW...I looked at the HalTech stuff. $2k for an ignition system isn't in my budget, lol.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Fancy ignition issues [Re: n20mstr] #2988388
11/23/21 07:18 PM
11/23/21 07:18 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Originally Posted by n20mstr
Wes, im surprised at you! !
It WORKED! Lol! I said I'm about to........... laugh
"Any fool can know. The point is to understand"
- A. Einstein
Re: Fancy ignition issues [Re: EvilB1Dart] #2988607
11/24/21 10:53 AM
11/24/21 10:53 AM
Daytona sensors doesn't seem to be very nitrous friendly. Another option off the table.
ICE has a system for nitrous cars. It will retard the timing up to 20 degrees, but only in 2° intervals. down
CHIP
Re: Fancy ignition issues [Re: an8sec70cuda] #2988610
11/24/21 11:07 AM
11/24/21 11:07 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
used Holley HP and an LS coil set up......sell all your current MSD stuff and you nitrous controller to help fund it.
....BAD A$$ STREET CAR.....
Re: Fancy ignition issues [Re: n20mstr] #3044853
05/24/22 02:46 PM
05/24/22 02:46 PM
Well, after trying to make it work...the 6530 (6al-2 programmable), I still have the same issue. After talking w/ MSD tech, they finally agree w/ me that the box itself has a problem. It only does it when it gets hot...not the car itself running hot, but push it outside in the heat of the day for a couple hours and it'll do it. I drove it on a cold day and the car runs perfect. Let the car sit outside on a hot day and then fire it up and it instantly has the 4500 rpm misfire/rev limit. So it's on the way back to MSD for another inspection.
In the mean time I have put all the old analog stuff back in the car (6AL, 8987 start/step retard, 2 step, etc.)
CHIP
Re: Fancy ignition issues [Re: an8sec70cuda] #3044862
05/24/22 03:37 PM
05/24/22 03:37 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Heat can do funny things. One bad solder joint. To bad you did not monitor the actual box temperature when it acted up. Then you could tell MSD to heat soak it at that temperature for testing.
Re: Fancy ignition issues [Re: an8sec70cuda] #3044863
05/24/22 03:41 PM
05/24/22 03:41 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
That sucks!
Still getting by with the old analog 6AL here, too.
'63 Dodge 330
11.19 @ 121 mph
Re: Fancy ignition issues [Re: an8sec70cuda] #3044867
05/24/22 03:51 PM
05/24/22 03:51 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Interesting the digital box has some of the same issues the analogue ones do. I went thru a couple, and it was always when cranking over with a low or dead battery that killed them or the coil, or both. I have not had one of their digital ones, but switched to a digital pertronix box and have had great luck with it.
https://www.summitracing.com/parts/pnx-510
Problem is, it won't do what you need....If it where me, I would switch to a Holley efi box, and just use what you need from it. Leave the carb, but hook up the NOS to it, and the Ignition box of choice, and it will do what you need....Although, I am not sure if you can program the ignition curve without a laptop, it would be the best way to go I think. Plus it data logs and has can bus...really nice setup with one of their dashes too.
Re: Fancy ignition issues [Re: Dragula] #3045275
05/26/22 08:22 AM
05/26/22 08:22 AM
The analog stuff either works or is completely dead...at least that's been my experience w/ the 6AL boxes.
I've had high speed misfires w/ the older Digital 6 Plus boxes and the Digital Multi Retard boxes, but otherwise they ran fine.
At this point, I'm all about keeping it simple. If the 6530 comes back, I'll give it another shot. If it still has issues, it's coming out of the car for good and the analog stuff goes back in...for good.
I'm far from a "serious" racer. I mostly test and tune and run the occasional street car/KOS shootout.
I have zero desire to plot a timing curve. All I want to do is pull timing out when the nitrous is activated and have a couple of rev limiters. That's it. I have all the control that I want w/ the nitrous progressive.
I don't want an MSD Grid or anything resembling Holley EFI on this car. I'm not setting the world on fire here w/ my two ton sled.
If this thing would still do a burnout on 20° of timing, I'd just manually pull the timing out, lol.
CHIP
Re: Fancy ignition issues [Re: an8sec70cuda] #3045280
05/26/22 08:53 AM
05/26/22 08:53 AM
The Holley would do it that way...Once a timing curve was built or chosen. They have premade ones you can chose from, and select one of those and adjust from there or build your own. Activating the NOS would pull a set amount that you decide. Talk with Rich, at Fastman EFI...He has done some cool stuff over the years.
You never touch the base timing table once its set. I would do it that way with a 7AL box...I like how well your car performs on NOS, its amazing how fast it is on those little tires. And with the array of sensors, you can log everything you could possibly want to watch. Not everyone uses those as an EFI box, some use them to control everything and keep the carb. Or go all in....
https://www.holley.com/products/fuel_systems/fuel_injection/terminator_x/terminator_x_stealth_4500/
Re: Fancy ignition issues [Re: an8sec70cuda] #3045283
05/26/22 09:30 AM
05/26/22 09:30 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Ha! That's why I have a dial! Do the burnout and then retard. Old school but it works!
'63 Dodge 330
11.19 @ 121 mph
Re: Fancy ignition issues [Re: GY3] #3045291
05/26/22 09:45 AM
05/26/22 09:45 AM
How much do you pull out and what are you using exactly to do it?
CHIP
Re: Fancy ignition issues [Re: an8sec70cuda] #3045297
05/26/22 10:08 AM
05/26/22 10:08 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
MSD 8680 and typically 6 degrees with the 250 shot.
'63 Dodge 330
11.19 @ 121 mph
Re: Fancy ignition issues [Re: GY3] #3045299
05/26/22 10:11 AM
05/26/22 10:11 AM
Cool, I'll keep that in mind. up
For now I have the old 6Al, 2 step, and the 8987 start/step in the car. Never used the 8987 before, so we'll see how it does.
CHIP
Re: Fancy ignition issues [Re: an8sec70cuda] #3046714
05/31/22 12:13 PM
05/31/22 12:13 PM
So far, so good w/ the old analog stuff. The new little retard box pulls timing out like it should and it's accurate. Drives around fine, but haven't been to the track yet. luck
CHIP
Re: Fancy ignition issues [Re: an8sec70cuda] #3046963
06/01/22 06:39 AM
06/01/22 06:39 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Sounds good Chip, hope it pans out up
Re: Fancy ignition issues [Re: an8sec70cuda] #3046989
06/01/22 09:43 AM
06/01/22 09:43 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
As you can read n my "lash" thread, I may be zeroing in on my Digital-6 being bad/erratic. I have been running it since '05, and suspect it has been the source of my 10 years of huge spark scatter. I do know, however, that the brand new MSD retard module I was running with my 6AL digital in the '71 Challenger fried the ignition box. Running great, added the module, and instantly lost the ignition. Wouldn't work even after I took it back out. Cooked the box. I had to cut it out of the system to finish Rocky Mountain Race Week 2020. I had it in there for nitrous, and ended up having to put the spare box in and just manually retard the distributor.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Fancy ignition issues [Re: 67Charger] #3047003
06/01/22 10:38 AM
06/01/22 10:38 AM
Originally Posted by 67Charger
As you can read n my "lash" thread, I may be zeroing in on my Digital-6 being bad/erratic. I have been running it since '05, and suspect it has been the source of my 10 years of huge spark scatter. I do know, however, that the brand new MSD retard module I was running with my 6AL digital fried the ignition box. Running great, added the module, and instantly lost the ignition. Wouldn't work even after I took it back out. Cooked the box. I had to cut it out of the system to finish Rocky Mountain Race Week 2020. I had it in there for nitrous, and ended up having to put the spare box in and just manually retard the distributor.
These digital boxes are something else. My luck has obviously not been good w/ them. Everyone running a fast car w/ an MSD Grid has a spare Grid system in the trailer. Quality is non existent anymore.
CHIP
Re: Fancy ignition issues [Re: an8sec70cuda] #3053835
06/27/22 02:32 PM
06/27/22 02:32 PM
So MSD called me last week to inform me that they cannot duplicate my issue w/ this box. They said they ran it on a "hot box" at 4k rpm for 8 hours and it did fine. I said yep b/c it's fine up until 4500 rpm.
Then he said they put it in the freezer overnight and back on the "hot box" the next day for 8 more hours at 6k rpm w/ no problem.
He said the "hot box" brings the temp up to engine temp. He explained no further.
I said this is interesting b/c I'm confident it's in the box and even one of their tech guys agreed w/ me a few weeks ago when I called to get the RMA number.
He said that's all they can do. shruggy
CHIP
Re: Fancy ignition issues [Re: an8sec70cuda] #3053840
06/27/22 02:54 PM
06/27/22 02:54 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Really not surprising. The one we had issues with wouldn't spark at low rpm. Spin it by hand out of the car at higher rpm and it would spark. Kinda hard to start when they are like that.
'63 Dodge 330
11.19 @ 121 mph
Page 2 of 3 1 2 3
