Re: a npk crash
[Re: Schultz62]
#3044126
05/21/22 01:02 PM
05/21/22 01:02 PM
Posts: 11,737 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I don't think the response time was bad. Maybe a little tardy, but Maple Grove has walls to the end of the track and it's fairly long.
Looks like the fire may have been been fed. I wonder if anyone got to the shut off on the back of the car to shut stuff off.
Re: a npk crash
[Re: dvw]
#3044178
05/21/22 05:59 PM
05/21/22 05:59 PM
Posts: 10,049 MN
JERICOGTX
MN
I followed your tip, and installed one in my car as well. After having the shutoff in the car, it should be a rule IMO.
69 GTX
68 Road Runner
Re: a npk crash
[Re: rebel]
#3044355
05/22/22 04:08 PM
05/22/22 04:08 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
My request is to please get all of the people out of and away from the starting line/burnout box! When he backs up he pushes people away from the car. What if a tranny lets go? It can saw a car, floorboard, feet etc within many yards. This amazes me as well. At our track, only the track crew & the car crew are allowed on the start line. I can't believe how many extras are on the start line here & with no protection. Tim Mcamis has an interesting view about this behavior on his Youtube channel that made me chuckle a few times. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: a npk crash
[Re: theraif]
#3044371
05/22/22 05:20 PM
05/22/22 05:20 PM
Posts: 43,309 Bend,OR USA
Cab_Burge
That couldn't happen to a nicer cry baby: grin:: devil: I hope the, person persons, decision making person, persons or people don't allow him back on any program associated with street or any type of drag racing on their network Way to many cry babies on them already Racers race and wanna be racers cry and complain instead of working on making their car and or driving better It seems to me that his Father is the motivation behind him racing I sincerely hope that the other driver wasn't hurt, anyone know of him and his current conditions? After watching the complete video this afternoon it looks like a bunch of the Street Outlaw racers were there also, I wonder why
Re: a npk crash
[Re: birdtracker]
#3044379
05/22/22 05:51 PM
05/22/22 05:51 PM
Posts: 9,883 MI, usa
dvw
MI, usa
Doug can you post a picture of your shut off.? Birdtracker . The cable goes into the car where a lever is attached to the cage. It can be shut off from out side the car (rod in lower part of the pic) as well. The bell crank is just 3/8" steel tube. A compression fitting cut in half locks it to the switch. Doug
Re: a npk crash
[Re: dvw]
#3044381
05/22/22 05:57 PM
05/22/22 05:57 PM
Posts: 1,404 Chesterfield Twp. Mi.
John Burdine
Doug can you post a picture of your shut off.? Birdtracker . The cable goes into the car where a lever is attached to the cage. It can be shut off from out side the car (rod in lower part of the pic) as well. The bell crank is just 3/8" steel tube. A compression fitting cut in half locks it to the switch. Doug Their is value to this on a street car as well. If I had a dime for every time I got in the car and forgot to turn the switch on......
Re: a npk crash
[Re: John Burdine]
#3044437
05/22/22 09:04 PM
05/22/22 09:04 PM
birdtracker
Doug can you post a picture of your shut off.? Birdtracker . The cable goes into the car where a lever is attached to the cage. It can be shut off from out side the car (rod in lower part of the pic) as well. The bell crank is just 3/8" steel tube. A compression fitting cut in half locks it to the switch. Doug Their is value to this on a street car as well. If I had a dime for every time I got in the car and forgot to turn the switch on...... John you are not the only one who does that!!!Lol Doug thanks for posting. Birdtracker
Re: a npk crash
[Re: birdtracker]
#3044443
05/22/22 09:26 PM
05/22/22 09:26 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
Doug can you post a picture of your shut off.? Birdtracker . The cable goes into the car where a lever is attached to the cage. It can be shut off from out side the car (rod in lower part of the pic) as well. The bell crank is just 3/8" steel tube. A compression fitting cut in half locks it to the switch. Doug Their is value to this on a street car as well. If I had a dime for every time I got in the car and forgot to turn the switch on...... John you are not the only one who does that!!!Lol Doug thanks for posting. Birdtracker Count me in this group too.
Re: a npk crash
[Re: John Burdine]
#3044466
05/22/22 11:04 PM
05/22/22 11:04 PM
Cab_Burge
Doug can you post a picture of your shut off.? Birdtracker . The cable goes into the car where a lever is attached to the cage. It can be shut off from out side the car (rod in lower part of the pic) as well. The bell crank is just 3/8" steel tube. A compression fitting cut in half locks it to the switch. Doug Their is value to this on a street car as well. If I had a dime for every time I got in the car and forgot to turn the switch on...... I never turn mine off at the races, never Even on the local two day races I do know several SO CA racers who use a motor home 100 % duty cycle electric solenoid to act as a on and off switch that they can turn on and off from the driver seats It is in series with the main batteery cable after the cut off switch, the bad part about using one like that is it uses current to operate it so it will drain the batteries eventually as long as it is on
Re: a npk crash
[Re: slantzilla]
#3044571
05/23/22 12:04 PM
05/23/22 12:04 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
John, is that the KD in southern Ohio? Honestly I’m not sure. It was posted by the street outlaw guys.
