Re: Jetting tunnelram
[Re: jwb123]
#3045070
05/25/22 10:21 AM
05/25/22 10:21 AM
Posts: 4,576 Motor City
6PKRTSE
Motor City
That is a big question. Start with factory settings, take out the powervalves, jet up 4 numbers on the blocks you took the power valves out of and then it is start with reading plugs and O2's if you have them. I just did a tunnel ram with twin dominators they came in at 6 numbers leaner than stock. I have a twin Dominators set up also that I drive on the street. Mine are staggered from 88's to 91's I believe. I have O2's and all 8 EGT's also which helps. Obviously, no where near stock.... lol. It is fat at idle but cleans up and has perfect AFR's at cruise and WOT.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Cab_Burge]
#3045239
05/25/22 09:42 PM
05/25/22 09:42 PM
6PKRTSE
Motor City
It's not pig fat. Doesn't smell or water your eyes or anything. It is 10.5-11.0 on the O2's at idle and 13.0-13.7 at idle and WOT.
[Re: 6PKRTSE]
#3045246
05/25/22 10:50 PM
05/25/22 10:50 PM
Posts: 43,275 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3045286
05/26/22 09:37 AM
05/26/22 09:37 AM
6PKRTSE
Motor City
With this car driving back and forth to work it's not very gas mileage friendly anyway.... lol. The 2 kits Come in handy if I am running late.
[Re: Cab_Burge]
#3045295
05/26/22 09:55 AM
05/26/22 09:55 AM
Posts: 624 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Listen to Cab. Perhaps also reduce fuel to the idle transfer slots via smaller jets if the metering block/body allows it or mod the block/body to enable you to do so. Then tune with IABs etc to clean up the idle even better. Even with a .750 lift roller I'm in the low - mid 15s at idle, and similar numbers to Cabs cruise and WOT numbers. Engine loves it
[Re: LAD 524]
#3045304
05/26/22 10:17 AM
05/26/22 10:17 AM
6PKRTSE
Motor City
I appreciate the input and help guys. It rev's like a small block and runs exceptionally well as is but a little more fine tuning won't hurt. Mine is over .800 solid roller. Makes great power to 7600.
