Re: 563ci build specs, what will it make?
[Re: Streetwize]
#3043030
05/17/22 10:47 AM
05/17/22 10:47 AM
Posts: 7,202 Minnesota
Hemi_Joel
Minnesota
...what stall and gear are you running? Wize, He's running the infinitely variable stall setup.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A “Never argue with a fool; onlookers may not be able to tell the difference.” – Mark Twain "Stay away from negative people. They have a problem for every solution."
[Re: Hemi_Joel]
#3043040
05/17/22 11:07 AM
05/17/22 11:07 AM
Posts: 17,401 S.E. Michigan
ZIPPY
S.E. Michigan
...what stall and gear are you running? Wize, He's running the infinitely variable stall setup. Aka "THE MAN PEDAL"
Rich H.
[Re: ZIPPY]
#3043046
05/17/22 11:09 AM
05/17/22 11:09 AM
Posts: 9,564 MN
JERICOGTX
MN
...what stall and gear are you running? Wize, He's running the infinitely variable stall setup. Aka "THE MAN PEDAL" Correct. The car has a Liberty Equalizer 4 speed. Rear gear will be a 4.30 in the Dana 60, and the Liberty has a 2.92 first gear.
69 GTX
68 Road Runner
[Re: Streetwize]
#3043048
05/17/22 11:12 AM
05/17/22 11:12 AM
Posts: 9,564 MN
JERICOGTX
MN
OK I'm guessing it might be an Ultradyne or Bullet because they seem to cut a lot of their cams for 102 ICL, at least on their Asymmetrical (fast opening/slow closing) lobes. The cam is from Erson. My machinist has had good luck getting cams from them, vs. other cam grinders. This one took only a couple weeks to get.
69 GTX
68 Road Runner
[Re: Streetwize]
#3043083
05/17/22 01:01 PM
05/17/22 01:01 PM
Posts: 9,564 MN
JERICOGTX
MN
I've never been one to do things the easy way... Besides, it gives my buddies lots of ammo for giving me sh!t...
69 GTX
68 Road Runner
[Re: AndyF]
#3043111
05/17/22 02:55 PM
05/17/22 02:55 PM
Posts: 9,564 MN
JERICOGTX
MN
I have a feeling that you'll be exchanging those 4.30 gears for some 3.70 gears after a few passes....... The car has 14x32 tires. Calculations have it going through the traps at 150 mph with 4.30 gears, and 7000 rpm. Liberty wanted a 4.30 gear in the car as well.
69 GTX
68 Road Runner
[Re: Streetwize]
#3043124
05/17/22 04:00 PM
05/17/22 04:00 PM
Hemi_Joel
Minnesota
He'll be grabbing 2nd with the wheels in the air!
[Re: Streetwize]
#3043219
05/18/22 05:14 AM
05/18/22 05:14 AM
Posts: 9,564 MN
JERICOGTX
MN
With a 2.94 First gear either you'll be in 2nd gear by the 60' cone...or you'll be IN ORBIT!! lol The 1-2 shift is usually around the 65'-70' mark, on a stick car. My Jerico had a 3.09 first gear. After years of running the car, you get used to the flow of things. It's what makes a stick car fun.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3043233
05/18/22 07:17 AM
05/18/22 07:17 AM
Posts: 9,670 Weddington, N.C.
Streetwize
Weddington, N.C.
Oh I know I raced sticks for years, back in high school my buddies would set up race bets with their 4 speed cars and then throw me the keys to drive for them !
This is an auto but an 8" spragless 5300 stall can be fun too
[Re: JERICOGTX]
#3043245
05/18/22 08:04 AM
05/18/22 08:04 AM
Posts: 19,313 State of confusion
Thumperdart
State of confusion
What's it weigh for starters and I appreciate you letting me build ya a bad azz billet 1150ish carb to help you meet your goals. As Andy mentioned it MAY make more "magazine hp" but it won't go up the track faster and I've been there many times in the last few years plus my 1050's support over 950 as dynoed and in a light 2600ish pound door car have gone 5,20's in the 1/8. I'm not a very good dyno guesser but 900 seems obtainable and we will all find out soon as your parts will be here today to get started so you can meet your deadline........I'm excited for you and proud to be on board Jeff.....Peace!
[Re: Thumperdart]
#3043246
05/18/22 08:13 AM
05/18/22 08:13 AM
Posts: 9,564 MN
JERICOGTX
MN
Dom,the new combo should weigh 3050lbs, with me in the car, race ready. It was 3148lbs with the old iron/filled 400 block. The liberty, and new stainless headers add some weight, but the aluminum block should still be over a 100lbs less.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3043252
05/18/22 08:44 AM
05/18/22 08:44 AM
Posts: 12,960 aZLiViN
J_BODY
aZLiViN
I've never been one to do things the easy way... Besides, it gives my buddies lots of ammo for giving me sh!t... If you can’t make it down the track, make it pretty to look at! 😉
[Re: J_BODY]
#3043255
05/18/22 08:48 AM
05/18/22 08:48 AM
Posts: 9,564 MN
JERICOGTX
MN
I've never been one to do things the easy way... Besides, it gives my buddies lots of ammo for giving me sh!t... If you can’t make it down the track, make it pretty to look at! 😉  Ah, my number one sh!t giver, never disappoints me... LOL.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3043298
05/18/22 11:35 AM
05/18/22 11:35 AM
Posts: 9,252 MI, usa
dvw
MI, usa
Dom,the new combo should weigh 3050lbs, with me in the car, race ready. It was 3148lbs with the old iron/filled 400 block. The liberty, and new stainless headers add some weight, but the aluminum block should still be over a 100lbs less. I'd kill for 3050. Doug
[Re: dvw]
#3043301
05/18/22 11:45 AM
05/18/22 11:45 AM
Posts: 12,933 Marion, South Carolina [><]
an8sec70cuda
Dom,the new combo should weigh 3050lbs, with me in the car, race ready. It was 3148lbs with the old iron/filled 400 block. The liberty, and new stainless headers add some weight, but the aluminum block should still be over a 100lbs less. I'd kill for 3050. Doug You?
CHIP '70 hemicuda...8 sec street car '69 road runner 440-6, 4 speed '71 Demon 340 '73 Chrysler New Yorker '90 Chevy 454SS Silverado '06 GMC 2500HD LBZ Duramax...toy hauler
