Page 3 of 8 1 2 3 4 5 6 7 8
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3043007
05/17/22 10:38 AM
05/17/22 10:38 AM
tboomer Online work
tboomer  Online Work
You always do quality stuff Jeff. I think you will be surprised at what it makes! Heck!! I am happy with my 550 hp 64 that you drove! wave
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3043011
05/17/22 10:52 AM
05/17/22 10:52 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I don’t know squat, about that distributor location. My little motor would make a good starter for it. 😁
Re: 563ci build specs, what will it make? [Re: Streetwize] #3043030
05/17/22 11:47 AM
05/17/22 11:47 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Originally Posted by Streetwize
...what stall and gear are you running?
Wize, He's running the infinitely variable stall setup.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 563ci build specs, what will it make? [Re: Hemi_Joel] #3043040
05/17/22 12:07 PM
05/17/22 12:07 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Aka "THE MAN PEDAL"
Rich H.
Esse Quam Videri
Re: 563ci build specs, what will it make? [Re: ZIPPY] #3043046
05/17/22 12:09 PM
05/17/22 12:09 PM
MN
JERICOGTX Offline OP
MN
Aka "THE MAN PEDAL"
Correct. The car has a Liberty Equalizer 4 speed. Rear gear will be a 4.30 in the Dana 60, and the Liberty has a 2.92 first gear.
69 GTX 68 Road Runner
Re: 563ci build specs, what will it make? [Re: Streetwize] #3043048
05/17/22 12:12 PM
05/17/22 12:12 PM
MN
MN
OK I'm guessing it might be an Ultradyne or Bullet because they seem to cut a lot of their cams for 102 ICL, at least on their Asymmetrical (fast opening/slow closing) lobes.
The cam is from Erson. My machinist has had good luck getting cams from them, vs. other cam grinders. This one took only a couple weeks to get.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3043078
05/17/22 01:43 PM
05/17/22 01:43 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Daddy LIKES!!!
WIZE
In Car:
Re: 563ci build specs, what will it make? [Re: Streetwize] #3043083
05/17/22 02:01 PM
05/17/22 02:01 PM
MN
MN
I've never been one to do things the easy way... Besides, it gives my buddies lots of ammo for giving me sh!t...
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3043110
05/17/22 03:52 PM
05/17/22 03:52 PM
AndyF Offline
AndyF  Offline
I have a feeling that you'll be exchanging those 4.30 gears for some 3.70 gears after a few passes.......
Re: 563ci build specs, what will it make? [Re: AndyF] #3043111
05/17/22 03:55 PM
05/17/22 03:55 PM
MN
MN
The car has 14x32 tires. Calculations have it going through the traps at 150 mph with 4.30 gears, and 7000 rpm. Liberty wanted a 4.30 gear in the car as well.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3043121
05/17/22 04:47 PM
05/17/22 04:47 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
With a 2.94 First gear either you'll be in 2nd gear by the 60' cone...or you'll be IN ORBIT!! lol
WIZE
In Car:
Re: 563ci build specs, what will it make? [Re: Streetwize] #3043124
05/17/22 05:00 PM
05/17/22 05:00 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
He'll be grabbing 2nd with the wheels in the air!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 563ci build specs, what will it make? [Re: Streetwize] #3043219
05/18/22 06:14 AM
05/18/22 06:14 AM
MN
MN
The 1-2 shift is usually around the 65'-70' mark, on a stick car. My Jerico had a 3.09 first gear. After years of running the car, you get used to the flow of things. It's what makes a stick car fun.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3043233
05/18/22 08:17 AM
05/18/22 08:17 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Oh I know I raced sticks for years, back in high school my buddies would set up race bets with their 4 speed cars and then throw me the keys to drive for them !
This is an auto but an 8" spragless 5300 stall can be fun too
WIZE
In Car:
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3043245
05/18/22 09:04 AM
05/18/22 09:04 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What's it weigh for starters and I appreciate you letting me build ya a bad azz billet 1150ish carb to help you meet your goals. As Andy mentioned it MAY make more "magazine hp" but it won't go up the track faster and I've been there many times in the last few years plus my 1050's support over 950 as dynoed and in a light 2600ish pound door car have gone 5,20's in the 1/8. I'm not a very good dyno guesser but 900 seems obtainable and we will all find out soon as your parts will be here today to get started so you can meet your deadline........I'm excited for you and proud to be on board Jeff.....Peace!
Re: 563ci build specs, what will it make? [Re: Thumperdart] #3043246
05/18/22 09:13 AM
05/18/22 09:13 AM
MN
MN
Dom,the new combo should weigh 3050lbs, with me in the car, race ready. It was 3148lbs with the old iron/filled 400 block. The liberty, and new stainless headers add some weight, but the aluminum block should still be over a 100lbs less.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3043252
05/18/22 09:44 AM
05/18/22 09:44 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If you can’t make it down the track, make it pretty to look at! 😉
Re: 563ci build specs, what will it make? [Re: J_BODY] #3043255
05/18/22 09:48 AM
05/18/22 09:48 AM
MN
MN
laugh2
Ah, my number one sh!t giver, never disappoints me... LOL.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3043298
05/18/22 12:35 PM
05/18/22 12:35 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'd kill for 3050.
Doug
Re: 563ci build specs, what will it make? [Re: dvw] #3043301
05/18/22 12:45 PM
05/18/22 12:45 PM
an8sec70cuda Offline
I'd kill for 3050.
Doug
You? laugh2 laugh2 wave
CHIP
'06 GMC 2500HD LBZ Duramax
