Can a headliner bow be flipped without... #3042757
05/16/22 11:09 AM
05/16/22 11:09 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Much work or destroying the headliner. The headliner is perfect but one of the bows was put in upside down or it flipped
Re: Can a headliner bow be flipped without... [Re: Sammy] #3042765
05/16/22 11:35 AM
05/16/22 11:35 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That's a weird one ! A photo might help, but:
The bows are in sleeves above where the seams are, so the risk is separating the seam or tearing the material.
Seems to me you'd have to drop the headliner back to the problem area to flip the bow.
Probably easier to work from the front than the rear.
Re: Can a headliner bow be flipped without... [Re: topside] #3042773
05/16/22 11:56 AM
05/16/22 11:56 AM
moparx Offline
moparx  Offline
i read the post you had in the general section about selling your hemi car, then the guy whining about stuff to get money back, including the headliner bow being upside down.
if that were truly the case, the headliner would be bagging down severely at that bow.
having installed several headliners over the years, i can't begin to imagine how this could be possible without ripping the listing sleeve from the headliner and causing damage.
this could happen during installation of the headliner, but once installed with the bows positioned as they should be, it would be real hard to do without damaging the headliner.
just my experience. your mileage will vary.
beer
Re: Can a headliner bow be flipped without... [Re: topside] #3042775
05/16/22 11:59 AM
05/16/22 11:59 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I agree.
A sleeve came apart that holds the bow, but the headliner stitching is still fine.
My headliner I installed in 1995 is separated. It looked a little low and when I pushed up on the seem I can feel a distance between the seem and bow rod that shouldn't be there. Not very visually noticeable.
But if I jerked around with it and wasn't careful maybe the bow would flip down shruggy. If you poke around like an idiot, you can find a way to screw anything up.
Re: Can a headliner bow be flipped without... [Re: autoxcuda] #3042834
05/16/22 04:23 PM
05/16/22 04:23 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Originally Posted by autoxcuda
[quote=topside] If you poke around like an idiot, you can find a way to screw anything up.
haha
Truer words have never been spoken. Ask me how I know... whistling
Re: Can a headliner bow be flipped without... [Re: Ramrod39] #3044016
05/20/22 09:44 PM
05/20/22 09:44 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
haha
I wonder if the guy tried to lift the top while driving and catching air and blowing out the top, then trying move it back into place, but the bow didn’t go as planned?
Re: Can a headliner bow be flipped without... [Re: Sammy] #3044019
05/20/22 09:48 PM
05/20/22 09:48 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iI had one that the front bow came loose after install. Not really noticeable and was that way for 30 years until I sold the car beer
Re: Can a headliner bow be flipped without... [Re: TJP] #3044136
05/21/22 01:40 PM
05/21/22 01:40 PM
lino lakes, mn
Schultz62 Offline
Schultz62  Offline
lino lakes, mn
Came loose a little ok. Flipped...absolutely no way!!!! There is no way that could happen. None shake_head
Re: Can a headliner bow be flipped without... [Re: Schultz62] #3044438
05/22/22 09:10 PM
05/22/22 09:10 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Yeah, I’m thinking it was flipped when initially installed.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Can a headliner bow be flipped without... [Re: BloFish] #3045478
05/26/22 09:39 PM
05/26/22 09:39 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I think you are right. Anyway to take down headliner without a disaster?
