Page 2 of 8 1 2 3 4 5 6 7 8
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042761
05/16/22 11:29 AM
05/16/22 11:29 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I'd have to guess it'd make a metric $#!+ - of horsepower with a sizeable pantload of torque.
Sure looks good. Are you going to break some hearts and grind off the logo on the belt drive?
Rich H.
Esse Quam Videri
Re: 563ci build specs, what will it make? [Re: ZIPPY] #3042777
05/16/22 12:09 PM
05/16/22 12:09 PM
MN
JERICOGTX Offline OP
MN
No. It gets covered enough by the engine plate, and water pump. I'll break hearts by painting an aluminum block...
69 GTX 68 Road Runner
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042784
05/16/22 12:22 PM
05/16/22 12:22 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
True to form, then. up
I love the overall look with the painted parts, and all the extra work you put in. Really sets it apart.
Rich H.
Esse Quam Videri
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042799
05/16/22 01:21 PM
05/16/22 01:21 PM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted by JERICOGTX
Primary tubes are 39” long. They step up from 2.125-2.250 after 6 “ from the header flange. I basically copied my Hooker 5209 headers, when I built them, only these actually fit the car without a hammer.
What headers will be used on the dyno?
Those are pretty long, IMO. I do like the short length of 2.125 tubes. I made mine with 8” of 2.125” and 21” of 2.250” for a total 29” length.
Re: 563ci build specs, what will it make? [Re: 440Jim] #3042804
05/16/22 01:38 PM
05/16/22 01:38 PM
MN
MN
We will make the first pulls with Hooker 5209 headers, then switch over to the headers I built. I basically copied the 5209 headers when I built them.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042835
05/16/22 04:24 PM
05/16/22 04:24 PM
NC
440Jim Offline
440Jim  Offline
NC
Very nice looking headers. up
I wasn't sure if the Hooker car headers would fit around the dyno you will use.
I look forward to the performance comparison.
Re: 563ci build specs, what will it make? [Re: 440Jim] #3042839
05/16/22 04:31 PM
05/16/22 04:31 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I'd put the cam in earlier unless you're tire limited. I'd guess about 870-880 hp
WIZE
In Car:
Re: 563ci build specs, what will it make? [Re: Streetwize] #3042914
05/16/22 09:38 PM
05/16/22 09:38 PM
MN
MN
I let my machinist pick out the cam. He wants the cam set 107-108, which is where it’s at now.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042917
05/16/22 09:47 PM
05/16/22 09:47 PM
gregsdart Offline
gregsdart  Offline
I am guessing stick cars like a little earlier c/l?. Plenty of duration.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: 563ci build specs, what will it make? [Re: gregsdart] #3042949
05/17/22 06:31 AM
05/17/22 06:31 AM
MN
MN
No clue. I wish I understood camshafts more. About a year ago, he built a 572 Mopar with 572-13 heads, and it made 1000hp. I didn't see any reason for him to not pick out the cam.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042952
05/17/22 06:50 AM
05/17/22 06:50 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Some things in our combos are close. I'm assuming your actual bore is 4.530". Yours has .250" less stroke, 1.5 points less compression, less lift (mine has 1.7 rocker). But it has stepped headers with a larger collector, arguably better intake, a touch more duration. My cam was in at 108 for years. Just moved it back to 111. So far the results are positive. My bet is yours will be over 900hp at higher rpm than mine. I think you'll be pleased with the outcome.
Doug
Re: 563ci build specs, what will it make? [Re: dvw] #3042956
05/17/22 07:20 AM
05/17/22 07:20 AM
MN
MN
Doug, bore is 4.524. Previous owner of the block just had it cleaned up enough, and ordered custom pistons for it. When I got the block, it had broke a rod bolt on the 202 pass, since being refreshed. It was in a dragster, that only ran 1/8 mile. The block came with 6 good pistons, so I only had to order two from Diamond. I tried to keep this on somewhat of a budget, so I used what I had, and worked around it.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042963
05/17/22 07:55 AM
05/17/22 07:55 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
That explains it. I did the last bore at 4.505" wanted to go to 4.510" this time but there was limited ring selection.
Doug
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042969
05/17/22 08:11 AM
05/17/22 08:11 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Well if it's 111 and in at 107 it's plus 4 where I thought it was put in straight-up (@ 111 ATDC) which for a non efi car seems late.
WIZE
In Car:
Re: 563ci build specs, what will it make? [Re: Streetwize] #3042986
05/17/22 09:24 AM
05/17/22 09:24 AM
MN
MN
Checking the cam installed straight up, it came to 102. I had all I could do to get it to 109, but after talking with the machinist, he wanted it around 107-108. It's at 108 right now.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042993
05/17/22 09:42 AM
05/17/22 09:42 AM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
My guess is 865hp
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: 563ci build specs, what will it make? [Re: WadeMetzinger] #3042998
05/17/22 10:02 AM
05/17/22 10:02 AM
MN
MN
Originally Posted by WadeMetzinger
My guess is 865hp
My goal is 850hp. Anything over is a bonus. Anything less, is what it is.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3042999
05/17/22 10:07 AM
05/17/22 10:07 AM
an8sec70cuda Offline
My guess is 865hp
I'm no dyno guy, but I'll say I think you're gonna be happy w/ it! up
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3043003
05/17/22 10:26 AM
05/17/22 10:26 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
OK I'm guessing it might be an Ultradyne or Bullet because they seem to cut a lot of their cams for 102 ICL, at least on their Asymmetrical (fast opening/slow closing) lobes.
I always referred to "straight-up' as when the installed CL is the same as the lobe spread, (i.e., 111)
That thing should rip the welds out of the frame with those heads and cubes, what stall and gear are you running?
WIZE
In Car:
Re: 563ci build specs, what will it make? [Re: an8sec70cuda] #3043004
05/17/22 10:27 AM
05/17/22 10:27 AM
MN
MN
My guess is 865hp
I've lowered my expectations enough to just live with what ever happens.
