Small Block Engines
[Re: moparts]
#3040253
05/06/22 10:07 AM
05/06/22 10:07 AM
Posts: 7,570 DELAWARE
TONY_DAGOSTINO
DELAWARE
All Small Block Motors: 340 Bare Block 6-26-70 Cast date, Standard Bore, Cracks In Lifter Gallery Area, Needs Repair $250, 340 Complete Intake to Oil Pan, 5-25-73 Cast date, Standard Bore $1495, 360 Bare Block 11-12-76 Cast Date, Standard Bore But Needs To Be Bored 30 Or 40 Over. 1 Cylinder Has Some Pitts $225, Sign up for our email blast to get exclusive offers and discounts! https://www.tonysparts.com/subscribeCheck Out Our New Webstore at Check Out Our New Webstore at tonysparts.com]http://tonysparts.com]tonysparts.com302-398-0821, contact@tonysparts.comTonys Parts Harrington Delaware 19952
340 Engine Bonanza Sale!! 5 to Choose from from 1970-1973
[Re: TONY_DAGOSTINO]
#3040330
05/06/22 01:20 PM
05/06/22 01:20 PM
Posts: 4,202 Florida
blewbyu
I am thining the herd of 340 motors I have been stashing away. I will post pics of each year in each photo post below. I get really good shipping rates so shipping will not be a problem. They have gone up some recently but have shipped motors from Fl to NY for as low as $150.00 in the past. All prices are plus shipping. Here is the info and the prices: 1) 1970 motor Vin Number 0B 360693 I am told originally from a Duster. Motor is total apart and is a complete long block, no oil pan, windage tray or intake. Does have J heads and steel crank. Block is std bore but #8 cylinder has a groove in it from something. what you see in pics is what you get. $1000.00 2) 1971 Motor Vin Number 1B274393 I am told originally from a Cuda. Motor is a complete motor intake to pan. I believe it is std bore. Does have J Heads and steel crank. Motor was running when pulled to put a crate 380 Hp Magnum Motor in. Turns over free and has been stored correctly. $2000.00 3) 1972 Motor Vin Number 2B350039 I am not sure what it came out of. Motor is complete intake to pan with dizzy. Does have J Heads and Steel crank with crack pulley and balancer. Motor turns over free and has been stored correctly. $1800.00 4) 1972 motor Vin Number 2B501431 I am not sure what it came out of. This motor is a absolutly complete all numbers matych 340 carb to pan, exhaust manifolds and all a/c parts and dizzy and all pulleys. does have J heads. Motor is locked up and that is how it was when I found it. I do also have the matching numbers 727 tranny for aditional money. Motor complete $1500.00 5) 1973 motor Vin 3B545223 This is a complete rebuilt motor that has never been fired. Heads, valves, pistons all brgs and cam. Was not bagged so has had humity surface build up and ends of valves in exhaust ports. Does have J heads. $2000.00 For pics go to: https://www.forabodiesonly.com/mopa...-5-to-choose-from-from-1970-1973.517315/blewbyu2bad@aol.com
90 degree oil filter adapter
[Re: blewbyu]
#3042633
05/15/22 10:28 PM
05/15/22 10:28 PM
Posts: 261 delhi,il
trw1982
delhi,il
only 1 left. comes with gasket set also. 85.00 shipped in lower 48. site says file too big. pm mere with phone number and i will send pics.
Re: SOLD Edelbrock Small Block Mopar heads
[Re: trw1982]
#3044922
05/24/22 08:03 PM
05/24/22 08:03 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
SOLD: a pair of Edelbrock Small Block Mopar Heads, with some upgraded parts, some minimal port work (Hensley Performance), surface cut and minor fixes, valve job (Brian Hafliger IMM) These heads were sold to me in September 2008 by Moparts member Irun5snd8th (then Irun6snd8th). They had some minor damage in a couple of places. Irun5snd8th said the heads had Manley valves, and dual valve springs with dampers. According to him, Hensley Performance did some minor work in the shroud around the valves and port matched the intake and exhaust ports. In October 2008 Brian Hafliger at Indio Motor Machine (IMM), did a surface cut and some minor repairs, did a valve job and tested the springs and said they were set at 1.875 installed height, they measure 131 lbs. on the seat and 300 lbs. open pressure at .500 lift. After receiving the heads they were stored in my closet for a future engine build that never happened. I would like to sell the pair locally in Southern California for $1200.
I am in Escondido, CA (North County San Diego)
Update 2022/05/27 SOLD for asking price
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
Re: For Sale - Small Block Engine - 2nd Quarter
[Re: JP8]
#3045990
05/28/22 07:44 PM
05/28/22 07:44 PM
Posts: 15,827 Mesa, Arizona
dart4forte
Mesa, Arizona
……………SOLD………………….Offy duel plane “360” intake manifold, 273-318, it’s in good shape however a small piece on the edge of the carb pad by the one of the studs is chipped. It’s not into the threads. Came off a running 318 that had no sealing issues.
$135.00 plus shipping. Shipping on a small aluminum manifold has been averaging $35.00
Mesa, AZ
SPEED PRO/SEALED POWER PISTONS with RINGS
[Re: Mopucky]
#3047171
06/01/22 05:45 PM
06/01/22 05:45 PM
Posts: 1,360 NW Chicago suburban area
Mopar Mitch
BRAND NEW IN BOXES: I am selling only because I decided to go with a 360-stroker engine (requiring different pistons).
Fits LA 360 engine, 030 overbore (4.030" cylinder bore).
SPEED PRO H116CP 030 PISTONS (Hypereutectic, Dur-O-Shield skirt coated)
SEALED POWER E-251K-030 RINGS (Moly coated, factory pre-gapped)
$300 for both, plus shipping.
Please send me PM if interested, or else text at 847-six-eight-two-0807 (Chicago area)
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
1971 360 LA CRANKSHAFT with NEW FACTORY HARMONIC BALANCER
[Re: Mopar Mitch]
#3047176
06/01/22 06:01 PM
06/01/22 06:01 PM
Mopar Mitch
Factory original crankshaft from 1971 LA 360. Had been freshly cut 010 / 010. Rotationally balanced by professional machine shop.
Brand new factory harmonic balancer that has been 360-degree rotationally degreed.
I am selling only because I decided to go with a 360 stroker (requiring new crankshaft, etc).
$150 for both; located in NW-Chicago suburbs. Prefer pick-up or willing to drive short distance (~100 miles) for delivery.
Please send PM if interested, or else text me at 847-six-eight-two-0807. Mitch (aka Mopar Mitch)
Mopar Mitch
FLOWMASTER FORCE II SCAVENGER COLLECTORS
[Re: schmitty]
#3048690
06/07/22 06:24 PM
06/07/22 06:24 PM
Mopar Mitch
NEW in box. FLOWMASTER FORCE II SCAVENGER COLLECTORS #C-158218234
Make your own 4-into-1 header pipes into these collectors.
1-5/8" primaries, 3" collectors.
Asking $40 plus shipping (new sold for $120).
Please send PM, or text my cell 847-six-eight-two-0807
Mopar Mitch
NOT SHIPPING ANYTHING CASH PICK UP ONLY
[Re: moparts]
#3049014
06/08/22 09:31 PM
06/08/22 09:31 PM
Posts: 1,530 MA
ragtop
MA
NOT SHIPPING ANYTHING FOR ANY PRICE. Cash Pick Up Only. Located in the eastern part of MA. See my E body parts and my 4 spd. Transmission and parts.
1970 T/A 340 block: std bore, hot tanked, very little ware, includes caps & bolts, OB 305926 6000 1970 T/A 340 heads: complete, re-built, bowls cleaned up, push rod pinch area machined away, Rockers bored +.010 to match new + .010 oversize shaft, includes valves, retainers, seals, locks, & springs 4000 pair 1970 T/A 340 pushrods: new sealed power RP1359 150 1971 340 Long Block: 030 over, very low mileage. 10 to 1 forged pistons, new cam bearings and oil pump, comes with oil pick up, windage tray, oil pan, oil slinger, fuel pump eccentric, front cam plate, date coded timing chain cover, engine cradle, & date coded heads which are re-built. Heads come with rockers and shaft, retainers, valves, locks & valve seals. (no valve springs) 5000 1968 273 block: needs rebuild, std bore 200 1968 273 pistons & rods assembly, std diameter, no measurable ware 150 set Small block cast crankshaft 50 340 forged crankshaft 100 340 294 oil pan 130 340 right hand oil filter adaptor complete 55 340 right hand oil filter adapter missing bold 45 1970 & up small block timing chain cover 15 Small block straight oil filter adaptor & bolt 20 Small block oil pump & pick up tube 25 Small block F E oil filler cap 20 Small block rubber motor mounts, new aftermarket 35 pair Thermostat housing small block 15 Small block harmonic balancer: forged crank 65 Small block crank pulley: 2 groove, non AC asymmetric hole pattern 60 Small block water pump pulley: non AC 25 318 valve covers 20 pair Small block alternator bracket set & spacers, non AC 40 Small block power steering pump bracket set: federal style with spacers 75 Small block coil bracket 20 Small block distributer hold down bracket 10 Power steering pump reservoir: federal style 30
360 Center Sump Pan and Windage Tray
[Re: Joesixpack]
#3049728
06/11/22 05:40 PM
06/11/22 05:40 PM
Posts: 3,495 Michigan
MarkZ
Worthy
Worthy
360 center sump pan with windage tray and pickup. Pretty decent shape. Comes with three main studs. Locate in Macomb, Michigan. $50 plus shipping. PM me.
Comp XE-274
[Re: MarkZ]
#3049733
06/11/22 05:48 PM
06/11/22 05:48 PM
MarkZ
Worthy
Worthy
Used Comp XE-274. Good shape Was pulled to go roller on a stroker build. Lifters not included as the order got mixed up. Best offer with shipping. Macomb, Michigan.
[Re: JRepucci]
#3050297
06/13/22 07:40 PM
06/13/22 07:40 PM
Posts: 1,738 Harriman NY
71GTX471
Harriman NY
For Sale 1969 318 eng. complete carb to pan aprox.70K on eng.when removed from 69 Sat.sport for a BB RR clone project,eng.ran fine when removed.
$250 OBO located in NY 10926. Don't know why pics.come out turned.
273 4bbl manifold and Carb OEM
[Re: moparts]
#3050616
06/14/22 10:44 PM
06/14/22 10:44 PM
Posts: 21,957 Trumussia
jcc
Trumussia
This for a 273, it is single plane cast Iron OEM, the 273 is unique, in that the mounting bolts have a different angle than the 318, 340 & 360 engines, it also has smaller ports sized for the 273.It ran fine when I removed and installed an Alum dual plane. You should be able to make out the casting number I hope. Must be gone before end of month. $100, $20 to pack, PU is OK, its in SW Fla, you pay shipping/insurance. PM, but please be patient, I'm not here often normally.
If you can't dazzle them with diamonds, don't waste your time, because nothing will
Re: 360 chrysler marine engine parts
[Re: jcc]
#3051229
06/17/22 11:17 AM
06/17/22 11:17 AM
Posts: 11,711 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
1978 360 CHRYSLER MARINE PARTS, USED, EXC WATER COOLED 2 EXHAUST MANIFOLDS $200 . PLUS SHIPPING.
LOCATION APACHE JUNCTION AZ cowgerwilliam035@gmail.com
