77 Cordoba 727 shift seal #3037439
04/26/22 11:04 PM
04/26/22 11:04 PM
Nashport, OH
chargers777 Offline OP
Nashport, OH
Can you change it in the car?
Re: 77 Cordoba 727 shift seal [Re: chargers777] #3037461
04/27/22 12:01 AM
04/27/22 12:01 AM
A727Tflite Offline
A727Tflite  Offline
Yes.
Re: 77 Cordoba 727 shift seal [Re: chargers777] #3037477
04/27/22 12:59 AM
04/27/22 12:59 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Re: 77 Cordoba 727 shift seal [Re: SNK-EYZ] #3037515
04/27/22 08:31 AM
04/27/22 08:31 AM
A727Tflite Offline
A727Tflite  Offline
Make your own, use a socket or washer that is the same diameter as the metal can of the seal, and use a bolt and nut with washers.
Just carefully align the seal and start turning the nut.
Re: 77 Cordoba 727 shift seal [Re: A727Tflite] #3037689
04/27/22 06:22 PM
04/27/22 06:22 PM
Nashport, OH
Nashport, OH
Can it be done in the car?
Re: 77 Cordoba 727 shift seal [Re: chargers777] #3037690
04/27/22 06:32 PM
04/27/22 06:32 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
You can do it. Not super easy. I have done it with a pick or a small screw driver to remove and tapped it back in with a socket and small hammer. I think if you have the right size C clamp it can be pressed back it.
Re: 77 Cordoba 727 shift seal [Re: chargers777] #3037704
04/27/22 07:10 PM
04/27/22 07:10 PM
Minn
SportF Offline
SportF  Offline
Minn
When you buy that seal, which isn't real expensive, buy two. Good luck.
Re: 77 Cordoba 727 shift seal [Re: chargers777] #3037718
04/27/22 07:40 PM
04/27/22 07:40 PM
A727Tflite Offline
A727Tflite  Offline
Yes. Like I said earlier.
Just go slow, line things up and slowly tighten the nut from the bottom, bolt in from the top.
Make sure the seal is centered in the countersink of the case.
You can easily knock the seal out from the bottom.
You need to remove the valve body first, I assume you know that.
Re: 77 Cordoba 727 shift seal [Re: A727Tflite] #3037796
04/27/22 10:22 PM
04/27/22 10:22 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
You can replace it in car like others have said. The advice I would give is buy 2 or 3 seals before you do the job. You may ruin one pressing it in place. I did this in car and ruined two, third one was the charm. I bent up the seal housing because things were not centered correctly.
1972 Dodge Challenger
Re: 77 Cordoba 727 shift seal [Re: A727Tflite] #3037852
04/28/22 02:10 AM
04/28/22 02:10 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The tool I put the link to doesn't require removing the valve body.
The one on the right in the pics is for removing the seal, all that is required is removing the shift lever and throttle pressure/kickdown lever.
The one on the left is for installing the seal.
I've had one of those seal remover/installer tools in my toolbox for almost 40 years, it's come in handy several times.
It's designed to make replacing the seal in the car much easier.
Re: 77 Cordoba 727 shift seal [Re: SNK-EYZ] #3038193
04/29/22 11:30 AM
04/29/22 11:30 AM
Rochester NY
Jer Offline
Jer  Offline
Rochester NY
Perfect! Just ordered a set, thanks for this.
Anyone have any suggestions for good seals? Some of the seals and bearings we've been getting lately have been less than crummy.
TIA!
Jer
Re: 77 Cordoba 727 shift seal [Re: Jer] #3038261
04/29/22 03:21 PM
04/29/22 03:21 PM
md
md
TIA!
Jer
l have some mopar 2466842 NOS seals.
Re: 77 Cordoba 727 shift seal [Re: mopars4ever] #3038359
04/29/22 08:57 PM
04/29/22 08:57 PM
Maryland
MoparMike1974 Offline
Maryland
The hardest part of replacing the seal in the car is that its difficult to see what you are doing. Its tight in there so you kinda have to feel your way through the job. Dropping the crossmember and letting the tailshaft drop a couple inches gives you a little more room. Watch firewall while lowering, small block distributor will hit first.
Re: 77 Cordoba 727 shift seal [Re: MoparMike1974] #3042109
05/13/22 10:40 PM
05/13/22 10:40 PM
Nashport, OH
Nashport, OH
Bought the tool.It shredded the hard seal.Now what. I don't want to remove the valve body.
Re: 77 Cordoba 727 shift seal [Re: chargers777] #3042139
05/14/22 12:29 AM
05/14/22 12:29 AM
md
md
I have pried them out with a small screw driver before.
Re: 77 Cordoba 727 shift seal [Re: chargers777] #3042153
05/14/22 04:34 AM
05/14/22 04:34 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Did you get it threaded completely down into the seal before you started tightening the upper bolt to pull the seal (and the tool) up and out?
It should bite into the metal ring part of the seal when threaded in completely.
That's what pulls that part of the seal out, just threading it into the rubber won't.
Re: 77 Cordoba 727 shift seal [Re: SNK-EYZ] #3042272
05/14/22 02:36 PM
05/14/22 02:36 PM
moparx Offline
moparx  Offline
i know you really don't want to remove the valve body, but it isn't that hard to do.
just my opinion, your mileage will vary.
beer
Re: 77 Cordoba 727 shift seal [Re: moparx] #3042358
05/14/22 07:23 PM
05/14/22 07:23 PM
Nashport, OH
Nashport, OH
Got it Took was crap. Pried it out with a small screwdriver. Not fun but it's done. Thanks for the help.
Re: 77 Cordoba 727 shift seal [Re: chargers777] #3042385
05/14/22 09:17 PM
05/14/22 09:17 PM
md
md
Your welcome.
Re: 77 Cordoba 727 shift seal [Re: mopars4ever] #3042485
05/15/22 12:03 PM
05/15/22 12:03 PM
moparx Offline
moparx  Offline
glad it ended successfully ! up
beer
