Sitting 727 How long ? #3042321
05/14/22 04:14 PM
05/14/22 04:14 PM
west palm beach, florida
modelmakerinc Online content OP
modelmakerinc  Online Content OP
Fellas, I have a rebuilt 727 that has been stored inside for about ten years, it was rebuilt and has never had fluid in it or installed
Should a freshen be in order or would it be just fine as is.
Thanks in advance Henry
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Sitting 727 How long ? [Re: modelmakerinc] #3042334
05/14/22 05:04 PM
05/14/22 05:04 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
“Inside”…. Like inside out of the heat and humidity?
Re: Sitting 727 How long ? [Re: J_BODY] #3042351
05/14/22 05:57 PM
05/14/22 05:57 PM
I'm in Florida, it's been in a garage, not a shed, but yes maybe max 90* and typical humidity for ambient air.
Re: Sitting 727 How long ? [Re: modelmakerinc] #3042361
05/14/22 06:44 PM
05/14/22 06:44 PM
IMGTX Offline
IMGTX  Offline
If every part was coated with fluid like when I build one, then the deep internals will be ok if the visible internals are ok.
Pull the pan and take a look.
Chances are it will be fine.
Re: Sitting 727 How long ? [Re: IMGTX] #3042409
05/14/22 10:29 PM
05/14/22 10:29 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
I installed a moth balled for 20 years trans behind a stock 318, and it was fine
In fact, it worked perfectly....
Re: Sitting 727 How long ? [Re: moparjim79] #3042427
05/15/22 01:23 AM
05/15/22 01:23 AM
Maryland
MoparMike1974 Offline
Maryland
I rebuilt one and didnt use it until 15 years later. Worked fine, no problems. Recently pulled pan to swap in a reverse manual valve body and everything looked normal..
Re: Sitting 727 How long ? [Re: MoparMike1974] #3042436
05/15/22 05:47 AM
05/15/22 05:47 AM
Thanks guys, gives me confidence to use it as is.
Henry
Re: Sitting 727 How long ? [Re: modelmakerinc] #3042623
05/15/22 08:50 PM
05/15/22 08:50 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Did any of you replace the seals? I have one under then bench for about 20 years because I sold the car it was for. Have wondered if it’d leak like a screen door.
I want my fair share
Re: Sitting 727 How long ? [Re: modelmakerinc] #3042950
05/17/22 05:33 AM
05/17/22 05:33 AM
Usa
A39Coronet Online content
A39Coronet  Online Content
Usa
As much of a PITA they are to put in I'd go through it. If it's never had fluid it'll be a clean disassembly and since all you should be doing is double checking it won't take very long. I'd want to resoak the clutches at the very least.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Sitting 727 How long ? [Re: A39Coronet] #3042987
05/17/22 08:30 AM
05/17/22 08:30 AM
scratchnfotraction Offline
when a moparts member "GOLDMEMBER" Jim said on my a999LU trans it is lube with trans greese on everything/fiber were soak in ATF on install. store it standing up on bell to keep front seal clean/plug both trans line fittings, install a tail shaft pug or yoke to seal from dirt/dust. good to sit for yrs till needed install new TC when installing for service.
he did my 727 to CRT-John Cope specs for the CRT VB with TF-II shift kit, greesed it/sealed it sat in my work shed for about 5-6 yrs and I installed it with a fesh TC and been bang gears daily for 50,000 miles now.
I would Indeed replace the front pump seal just insurance against seal leaks. that one sucks. the rest can be serviced in the car as needed. MAYBE do both of the shift shaft seals while on the bench.
FYI, I have pulled many a used JY trannys & trannys that have sat very long times. only had a couple that had internal seal issues, most troubles were mechanical I always open/clean/inspect filter/pan and pour fresh ATF inside letting drain down on the internals then button up the filter/pan. always start then in N so the pump fill TC & prime-lube itself right away and let it come up to temp 5-10 mins before running through he gears on it.
front pump seal and let it rip.
Re: Sitting 727 How long ? [Re: scratchnfotraction] #3043204
05/17/22 10:16 PM
05/17/22 10:16 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
How long do you think seals set on a shelf before being used? No moisture inside, run it
