Crank Main seals Big Block #3042068
05/13/22 06:20 PM
05/13/22 06:20 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
What you use for a boosted app. I have always used the rubber felpro in back and a stock timing cover seal but always had blow by at 30PSI of boost. Need a better seal.
Re: Crank Main seals Big Block [Re: FastmOp] #3042070
05/13/22 06:27 PM
05/13/22 06:27 PM
Sounds like you need better crankcase ventilation, bigger and or more breathers work scope
There should no pressure in the crankcase or the rest of the motor twocents
How about a vacuum pump work up scope
IHTHs luck
Re: Crank Main seals Big Block [Re: FastmOp] #3042081
05/13/22 07:11 PM
05/13/22 07:11 PM
AndyF Offline
AndyF  Offline
Not a lot of choices for a BB Mopar. You can upgrade to a Jesel belt drive in front since that would give you access to better seals. In the rear you can try the one piece setup from Fast Fish.
Re: Crank Main seals Big Block [Re: FastmOp] #3042180
05/14/22 08:09 AM
05/14/22 08:09 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I used an aluminum cover, and fabricated a thin ring out of aluminum as a retainer to hold the seal in. Two small allen head screws sealed with rtv, plenty of room to fit behind balancer, did it on several Chevy engines as well.
Re: Crank Main seals Big Block [Re: jwb123] #3042237
05/14/22 12:04 PM
05/14/22 12:04 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Pics?
Re: Crank Main seals Big Block [Re: FastmOp] #3042247
05/14/22 12:27 PM
05/14/22 12:27 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Don't have any pics, but just used two hole saws and clamped a piece of 1/8 aluminum to the drill press. first for the inner diameter and then a bigger one for the outer, its got to be clamped tight, then die grinder to smooth up. Got some stainless allen head bolts smallest ones they had and drilled and tapped the cover sealed the bolt treads with rtv.
Re: Crank Main seals Big Block [Re: jwb123] #3042509
05/15/22 02:02 PM
05/15/22 02:02 PM
Texas
Chief Offline
Chief  Offline
Texas
Not trying to steal the thread but my question is relevant to the OP..
I run a 8:71 on my BBM. I also run a vacuum pump. I use the Fast Fish rear seal, no leak there. But I'm trying to stop any vacuum leaks at the front seal. I have packed the backside with RTV but I'm not happy with it. I know the chebby crowd has a double lip seal they use on their builds.
Anyone have a part number for a double lip seal or a better way to go for a BBM?
Dave Covey
Re: Crank Main seals Big Block [Re: Chief] #3042518
05/15/22 03:05 PM
05/15/22 03:05 PM
AndyF Offline
AndyF  Offline
The NASCAR guys developed a super high vacuum front cover seal. I bought a couple of them years ago when I was developing the billet timing cover for SB Mopars. The seals are expensive and not widely available. I bought mine from some shop in NC, don't recall the name.
Re: Crank Main seals Big Block [Re: AndyF] #3042545
05/15/22 04:34 PM
05/15/22 04:34 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Tritec seals, before they were bought by a bigger company i bought three upper and lower double lip jesel seals as well as well as 3 double lip rear main high vacuum seals. i recently looked up and found the company that acquired them,im sure they still make the same seals...
Re: Crank Main seals Big Block [Re: FastmOp] #3042591
05/15/22 07:30 PM
05/15/22 07:30 PM
Have you filled the rear main seal holder edges to the block with adhesive silicone gasket maker yet on the rear main? if not try that, I've seen a lot of rear main seal leaks there, which made the owners, racers, mechanics, think it was the crank seals instead of the side seals leaking: work:: scope: wrench: up
Re: Crank Main seals Big Block [Re: GomangoCuda] #3042598
05/15/22 07:56 PM
05/15/22 07:56 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Pics?
2011 Drag Pak Challenger
Re: Crank Main seals Big Block [Re: rickseeman] #3042694
05/16/22 07:19 AM
05/16/22 07:19 AM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
I use a mopar chrome front cover but might upgrade. Seems like it's time lol.
Thanks gents.
Is a hemi seal the same size as a big block. ?
Re: Crank Main seals Big Block [Re: FastmOp] #3042719
05/16/22 09:25 AM
05/16/22 09:25 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Yes
Re: Crank Main seals Big Block [Re: rickseeman] #3042747
05/16/22 10:43 AM
05/16/22 10:43 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Tritec's website is down, but I think these guys sell their seal for a BBM.
https://www.fastfishautoparts.com/store/p_1203721/big-block-mopar-performance-rear-main-seal-
Re: Crank Main seals Big Block [Re: LAD 524] #3042886
05/16/22 06:55 PM
05/16/22 06:55 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
So I dug this out but I need the crank gear. And prolly some shims or a setup kit. Never messed with this stuff before.
Can I order just the crank gear and setup kit.
Re: Crank Main seals Big Block [Re: LAD 524] #3042901
05/16/22 08:57 PM
05/16/22 08:57 PM
San Jose Ca.
San Jose Ca.
no those seals are not tri tec seals https://www.fh-group.com/work/tritec-motorsports/
Re: Crank Main seals Big Block [Re: boatracer572] #3042906
05/16/22 09:03 PM
05/16/22 09:03 PM
San Jose Ca.
San Jose Ca.
Re: Crank Main seals Big Block [Re: FastmOp] #3043129
05/17/22 05:36 PM
05/17/22 05:36 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I need some parts too. I'll make some calls in the morning and see if parts are still available for these.
Re: Crank Main seals Big Block [Re: rickseeman] #3043136
05/17/22 06:04 PM
05/17/22 06:04 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
For the OP: I think that gear drive is for a raised cam block. Do you have a raised cam block?
Re: Crank Main seals Big Block [Re: rickseeman] #3043209
05/17/22 11:49 PM
05/17/22 11:49 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
No I don't. Neither of my aluminum blocks are raised cam
