Budget minded, salvage yard turbo on a 360
#3041825
05/12/22 04:41 PM
05/12/22 04:41 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Where can a person find info on adding a turbo?
I am looking to get a little more power, and maybe help the mpg,
Playing with the idea of adding a turbo to a 77 C body Fury, stock engine, and 2.76 gears out back.
Any parts lists of what to scavenge and from what would be helpful.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: Budget minded, salvage yard turbo on a 360
[Re: hp383]
#3041892
05/12/22 10:38 PM
05/12/22 10:38 PM
Posts: 43,124 Bend,OR USA
Cab_Burge
Any parts lists of what to scavenge and from what would be helpful. Lets see, making more power includes consuming more air and fuel correct? Have you decided on how you're going to control the fuel with boost and vacuum yet, carb or fuel injection ?
[Re: MikeN]
#3041939
05/13/22 08:38 AM
05/13/22 08:38 AM
Posts: 2,255 IL
furious70
IL
theturboforums.com was a great resource for DIY stuff, still tons of great historical info to read to see how people have done it. Traffic has fallen way off there, don't know where people went. Also, go to the engine forum here.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: HotRodDave]
#3041999
05/13/22 02:26 PM
05/13/22 02:26 PM
Posts: 2,255 IL
furious70
IL
I missed the mpg part - completely agree mpg increase on an existing engine will never happen. A turbo is a mild restriction in the exhaust when just freewheeling along and there's no way that improves mpg.
mpg can be improved along the lines Dave says + putting a milder cam in an existing engine (not something you need to do on a stock c body 360).
But a turbo can be a very efficient way to provide 25-50% more power than an engine has in it's NA state.
I ran stock Ford SVO/Turbocoupe turbos on my 383 when I first did it. They were too small, but they did work pretty well to get going. Something like that would work pretty good on your 360 (a pair of them). A pair of cummins turbos cfm wise is ok since you're a 5.9 at 2x rpm of a cummins, but the compressor map on those is pretty narrow and so it wouldn't be that efficient.
[Re: topside]
#3042384
05/14/22 09:15 PM
05/14/22 09:15 PM
Posts: 234 Brisvegas, Australia
Alchemi
Turbo slant would be a much better option, way less weight, just over half the capacity. If your truly after MPG, then have a bit of a look at ecomodder.com and the mega weight loss thread here https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2255190/1.htmlAero and weight, plus a well tuned engine is about the extent of achievable stuff without spending stupid money that could just be spent on fuel, especially if its not a daily driver That said, this one popped up in my feed the other day, lawnmower carb on a ford 302 that gets 40mpg, so the dude claims https://www.youtube.com/watch?v=1xHQWu2ZzPc
[Re: Alchemi]
#3042404
05/14/22 10:57 PM
05/14/22 10:57 PM
Posts: 3,042 N.W. Florida
Fat_Mike
N.W. Florida
Turbo slant would be a much better option, way less weight, just over half the capacity. If your truly after MPG, then have a bit of a look at ecomodder.com and the mega weight loss thread here https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2255190/1.htmlAero and weight, plus a well tuned engine is about the extent of achievable stuff without spending stupid money that could just be spent on fuel, especially if its not a daily driver That said, this one popped up in my feed the other day, lawnmower carb on a ford 302 that gets 40mpg, so the dude claims https://www.youtube.com/watch?v=1xHQWu2ZzPc In a '77 C-body with a 2.76 rear end?
[Re: hp383]
#3042514
05/15/22 02:39 PM
05/15/22 02:39 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
A lot of good suggestions in above replys.. I would add one seldom mentioned tip: Try to find someone near you that has a Mazda Millenia S with its factory installed double superchargers V6 that runs on the “Miller Cycle” and see if they would let you drive it, or do a ride along, etc. https://en.wikipedia.org/wiki/Mazda_Milleniahttps://www.carthrottle.com/post/mazda-once-made-a-225l-v6-and-its-spectacularly-complex/https://www.newcartestdrive.com/reviews/2000-mazda-millenia/If you are looking for a boost in fuel economy AND power understanding the Miller Cycle is a good way to learn how. The Miller Cycle can run on one or two turbos, not just with double superchargers like the Millenia S. Double superchargers are easier to program an engine computer for, as their output depends on rpm, and not the volume and temperature of exhaust gas varying second by second. sample quote This car really comes into its own when its Miller-cycle V6 is put to work. Mazda’s unique Miller-cycle engine was named one the world’s “10 Best Engines” by Ward’s, an automotive trade journal for the past four years. It uses a Lysholm compressor — a scroll-type supercharger — to boost intake pressure along with late intake-valve closing to produce an impressive amount of power without sacrificing fuel efficiency. This system allows this 2.3-liter engine to perform like a 3.3-liter engine, while still retaining the 2.3-liter engine’s economy of operation. The result is a vigorous 210-horsepower with the brawny, quick response of 210 foot-pounds of torque. The Miller-cycle package has no downside. end quote
[Re: RTSrunner]
#3042706
05/16/22 08:33 AM
05/16/22 08:33 AM
Posts: 6,225 nowhere
Sniper
nowhere
Go read the comments, if they aren't mostly fake I'll eat the turbo. Now copy the part number, go to Amazon and read the comments there. They are cheap for a reason, cheaply made.
[Re: 360view]
#3042806
05/16/22 01:45 PM
05/16/22 01:45 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
A lot of good suggestions in above replys.. I would add one seldom mentioned tip: Try to find someone near you that has a Mazda Millenia S with its factory installed double superchargers V6 that runs on the “Miller Cycle” and see if they would let you drive it, or do a ride along, etc. https://en.wikipedia.org/wiki/Mazda_Milleniahttps://www.carthrottle.com/post/mazda-once-made-a-225l-v6-and-its-spectacularly-complex/https://www.newcartestdrive.com/reviews/2000-mazda-millenia/If you are looking for a boost in fuel economy AND power understanding the Miller Cycle is a good way to learn how. The Miller Cycle can run on one or two turbos, not just with double superchargers like the Millenia S. Double superchargers are easier to program an engine computer for, as their output depends on rpm, and not the volume and temperature of exhaust gas varying second by second. sample quote This car really comes into its own when its Miller-cycle V6 is put to work. Mazda’s unique Miller-cycle engine was named one the world’s “10 Best Engines” by Ward’s, an automotive trade journal for the past four years. It uses a Lysholm compressor — a scroll-type supercharger — to boost intake pressure along with late intake-valve closing to produce an impressive amount of power without sacrificing fuel efficiency. This system allows this 2.3-liter engine to perform like a 3.3-liter engine, while still retaining the 2.3-liter engine’s economy of operation. The result is a vigorous 210-horsepower with the brawny, quick response of 210 foot-pounds of torque. The Miller-cycle package has no downside. end quote Maybe the original poster should mill a set of magnum heads down about .030, redrill the intake bolt holes to LA pattern, do a 3 angle valve job with nice sharp angles on the intake and polish the ex valve and use a thin steel head gasket to increase compression, air flow, valve lift, swirl, quench... all in one and all that would increase MPG TQ and HP with no turbo lag. It would not gain as much power as a turbo could but I would think 40-50 HP would not be out of the question and give a couple MPG improvement without all the hoses and piping (places for leaks) running all over under the hood making stuff hard to work on. On a side note I been thinking about miller cycle engines and wondering how it could be done on a mopar and don't think it would be too hard, just build really high compression, get a wide LSA cam and retard the heck out of it to keep it from building so much cylinder pressure. You would get reduced overlap for a cleaner faster burn and increased expansion ratio as well as letting the combustion exert it's force on the piston till the last possible degree of rotation. The other option would be Atkins cycle but I think that would be harder to effectively build in a mopar engine with a readily available cam.
[Re: mgoblue9798]
#3043069
05/17/22 01:04 PM
05/17/22 01:04 PM
HotRodDave
Kalispell Mt.
There very well could be some improvement in gas mileage in a smog dog low compression engine using a turbo in a very low boost setup with 6-7 lbs.
Just my two cents but similar efficiency gains could also be had with a set of pistons to bump compression and set up for quench.
Second option is by far the simpler way to go about it imo.
If mileage is the primary concern I would start with a 318 v/s the 360. The engine will not be under any boost the majority of the time, it will still be under vacuum under most driving conditions except now it will be working harder to pump air and exhaust through a pretty big restriction.
[Re: HotRodDave]
#3043467
05/19/22 12:58 AM
05/19/22 12:58 AM
hp383
State of Confusion
I guess the turbo won't help the mpg as I thought it might. I honestly know very little about turbo setups other than a rudimentary concept of how they operate. I've heard others boast about mpg gains and thought it might be something to tinker with.
That looks to be wrong.
