563ci build specs, what will it make?
#3041995
05/13/22 02:09 PM
05/13/22 02:09 PM
Posts: 10,009 MN
JERICOGTX
MN
I picked up my new engine build from the machinist today. Time to get busy, and bolt everything together.
Here are the specs of the build:
INDY RB Aluminum block Molnar 4.375 crank Molnar 7.100 rods Diamond pistons 4.524 bore INDY 440-1 345CNC heads, finished by Dwayne Porter. Flow numbers attached. Compression ratio is 13.5:1 T&D 1.6 rockers INDY 4403X intake manifold Erson roller cam specs: Lift Intake= .768 Exhaust= .760 Duration@ .050 =288/302 LSA= 111
Jesel belt drive MSD Crank trigger Moroso 4 vane vacuum pump Thumper 1150cfm 4500 carb
Headers are 2.125-2.250 with 4” collectors.
I’m hoping to have everything together, and dyno test it in a few weeks. Anyone want to take a guess at what it will make for HP/TRQ?
Jeff
69 GTX
68 Road Runner
Re: 563ci build specs, what will it make?
[Re: tboomer]
#3042016
05/13/22 03:26 PM
05/13/22 03:26 PM
Posts: 10,009 MN
JERICOGTX
MN
No help Jeff but I hope to see you at the track with it! As of right now, the only race I’m planning on attending this year, is Brainerd for 4th of July. Money is extremely tight right now, and with Diesel prices climbing every day, I won’t be making any long hauls.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042027
05/13/22 03:53 PM
05/13/22 03:53 PM
Posts: 16,916 NC
440Jim
NC
Headers are 2.125-2.250 with 4” collectors. I like that build. What length are the headers? A shorter length may make peak hp a couple hundred higher. You have the cam duration to do it. Since Andy was so close to my initial thought, I'm going with 29-30" long headers and 910 hp at 7200 rpm. I will guess the torque peak at 5650 rpm. (approximately ...)
[Re: 440Jim]
#3042043
05/13/22 04:49 PM
05/13/22 04:49 PM
Posts: 10,009 MN
JERICOGTX
MN
Primary tubes are 39” long. They step up from 2.125-2.250 after 6 “ from the header flange. I basically copied my Hooker 5209 headers, when I built them, only these actually fit the car without a hammer.
69 GTX
68 Road Runner
[Re: tboomer]
#3042044
05/13/22 04:50 PM
05/13/22 04:50 PM
Posts: 10,009 MN
JERICOGTX
MN
Cool! Can you remember what my 60' was when you drove my junker? Been meaning to ask that... 1.42 if I remember correctly.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042046
05/13/22 04:52 PM
05/13/22 04:52 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The HP numbers could vary significantly between different dynos.
I’d expect to see 875-900 here.
A 572 with the same heads, 14:1, 282@.050 cam, 440-2 with 4500 adapter and a good working 1150, but no vacuum pump made 778tq.
That’s 1.36 lb/ft per ci. At 563ci you’d be around 765tq.
[Re: fast68plymouth]
#3042049
05/13/22 05:07 PM
05/13/22 05:07 PM
Posts: 10,009 MN
JERICOGTX
MN
I’d be very happy if it made those numbers. Could possibly push the Road Runner into the 8’s on a good day, with a tail wind.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042053
05/13/22 05:19 PM
05/13/22 05:19 PM
fast68plymouth
So. Burlington, Vt.
I’m thinking the 288/302-111 might cost a little bit of peak tq output........ and I don’t know if the vac pump will be enough to equal that out or not.
I guess we’ll find out.
Another 14:1 572 made 766tq. That one had bigger heads, the 3X intake, a little more cam, and a fairly ineffective vac pump(4”). Even though the peak tq was less, it did end up making 40hp more.
[Re: JERICOGTX]
#3042072
05/13/22 06:33 PM
05/13/22 06:33 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
If the cam is installed straight up at 111 ILC I would guess between 875 HP maybe up to 950 HP around 7600 RPM depending on the actual weather that day and fuel used, torque around 790 Ft lbs. around 5200 RPM My guesses have no scientific input, pure speculation on my part
[Re: Cab_Burge]
#3042123
05/13/22 11:33 PM
05/13/22 11:33 PM
Posts: 7,471 Minnesota
Hemi_Joel
Minnesota
I guess 891 @ 7300. Whatever it makes it's great to see it coming back together!
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3042140
05/14/22 12:32 AM
05/14/22 12:32 AM
Posts: 165 Sticky South
Rodenteliminator
Sticky South
I am going to be a little more generous and go 920 hp 790 tq range, comparing your specs and the 540 Todd just finished for me, I don’t have the numbers on my -1’s but I bet they wouldn’t flow quite that good and you have a little more lift, and of course the dyno operator.
Sorry honey I spent the rent
[Re: quickd100]
#3042158
05/14/22 05:56 AM
05/14/22 05:56 AM
Posts: 10,009 MN
JERICOGTX
MN
Is that 4spd going to go bye-bye? Dave, the Jerico is gone, and a Liberty Equalizer is in its place.
69 GTX
68 Road Runner
[Re: fbs63]
#3042689
05/16/22 06:11 AM
05/16/22 06:11 AM
Posts: 10,009 MN
JERICOGTX
MN
Slowly going together. This is the first time I've set up a Jesel belt drive, so I'm taking my time. Should get the cam degreed in, in the next couple days, if I can find the time.
69 GTX
68 Road Runner
[Re: J_BODY]
#3042753
05/16/22 10:58 AM
05/16/22 10:58 AM
Posts: 10,009 MN
JERICOGTX
MN
What’ll it make?? A trek to that crispy cool fall air at Interstate Dragway to grab a trophy time slip in that low DA Anyone can get a trophy time slip at Interstate in the fall... Enough leaves blowing around to get a 380mph time slip... It's happened many times.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042761
05/16/22 11:29 AM
05/16/22 11:29 AM
Posts: 17,800 S.E. Michigan
ZIPPY
S.E. Michigan
I'd have to guess it'd make a metric $#!+ - of horsepower with a sizeable pantload of torque.
Sure looks good. Are you going to break some hearts and grind off the logo on the belt drive?
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3042777
05/16/22 12:09 PM
05/16/22 12:09 PM
Posts: 10,009 MN
JERICOGTX
MN
Are you going to break some hearts and grind off the logo on the belt drive? No. It gets covered enough by the engine plate, and water pump. I'll break hearts by painting an aluminum block...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042784
05/16/22 12:22 PM
05/16/22 12:22 PM
ZIPPY
S.E. Michigan
True to form, then. I love the overall look with the painted parts, and all the extra work you put in. Really sets it apart.
Rich H.
Esse Quam Videri
[Re: JERICOGTX]
#3042799
05/16/22 01:21 PM
05/16/22 01:21 PM
Posts: 16,916 NC
440Jim
NC
Primary tubes are 39” long. They step up from 2.125-2.250 after 6 “ from the header flange. I basically copied my Hooker 5209 headers, when I built them, only these actually fit the car without a hammer. What headers will be used on the dyno? Those are pretty long, IMO. I do like the short length of 2.125 tubes. I made mine with 8” of 2.125” and 21” of 2.250” for a total 29” length.
[Re: 440Jim]
#3042804
05/16/22 01:38 PM
05/16/22 01:38 PM
Posts: 10,009 MN
JERICOGTX
MN
We will make the first pulls with Hooker 5209 headers, then switch over to the headers I built. I basically copied the 5209 headers when I built them.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042835
05/16/22 04:24 PM
05/16/22 04:24 PM
Posts: 16,916 NC
440Jim
NC
Very nice looking headers. I wasn't sure if the Hooker car headers would fit around the dyno you will use. I look forward to the performance comparison.
[Re: Streetwize]
#3042914
05/16/22 09:38 PM
05/16/22 09:38 PM
Posts: 10,009 MN
JERICOGTX
MN
I'd put the cam in earlier unless you're tire limited. I'd guess about 870-880 hp I let my machinist pick out the cam. He wants the cam set 107-108, which is where it’s at now.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042917
05/16/22 09:47 PM
05/16/22 09:47 PM
Posts: 9,963 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I'd put the cam in earlier unless you're tire limited. I'd guess about 870-880 hp I let my machinist pick out the cam. He wants the cam set 107-108, which is where it’s at now. I am guessing stick cars like a little earlier c/l?. Plenty of duration.
[Re: gregsdart]
#3042949
05/17/22 06:31 AM
05/17/22 06:31 AM
Posts: 10,009 MN
JERICOGTX
MN
I'd put the cam in earlier unless you're tire limited. I'd guess about 870-880 hp I let my machinist pick out the cam. He wants the cam set 107-108, which is where it’s at now. I am guessing stick cars like a little earlier c/l?. Plenty of duration. No clue. I wish I understood camshafts more. About a year ago, he built a 572 Mopar with 572-13 heads, and it made 1000hp. I didn't see any reason for him to not pick out the cam.
69 GTX
68 Road Runner
[Re: dvw]
#3042956
05/17/22 07:20 AM
05/17/22 07:20 AM
Posts: 10,009 MN
JERICOGTX
MN
Doug, bore is 4.524. Previous owner of the block just had it cleaned up enough, and ordered custom pistons for it. When I got the block, it had broke a rod bolt on the 202 pass, since being refreshed. It was in a dragster, that only ran 1/8 mile. The block came with 6 good pistons, so I only had to order two from Diamond. I tried to keep this on somewhat of a budget, so I used what I had, and worked around it.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042969
05/17/22 08:11 AM
05/17/22 08:11 AM
Posts: 9,866 Weddington, N.C.
Streetwize
Weddington, N.C.
Well if it's 111 and in at 107 it's plus 4 where I thought it was put in straight-up (@ 111 ATDC) which for a non efi car seems late.
[Re: Streetwize]
#3042986
05/17/22 09:24 AM
05/17/22 09:24 AM
Posts: 10,009 MN
JERICOGTX
MN
Checking the cam installed straight up, it came to 102. I had all I could do to get it to 109, but after talking with the machinist, he wanted it around 107-108. It's at 108 right now.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042993
05/17/22 09:42 AM
05/17/22 09:42 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: WadeMetzinger]
#3042998
05/17/22 10:02 AM
05/17/22 10:02 AM
Posts: 10,009 MN
JERICOGTX
MN
My goal is 850hp. Anything over is a bonus. Anything less, is what it is.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042999
05/17/22 10:07 AM
05/17/22 10:07 AM
Posts: 13,319 Marion, South Carolina [><]
an8sec70cuda
My goal is 850hp. Anything over is a bonus. Anything less, is what it is. I'm no dyno guy, but I'll say I think you're gonna be happy w/ it!
[Re: an8sec70cuda]
#3043004
05/17/22 10:27 AM
05/17/22 10:27 AM
Posts: 10,009 MN
JERICOGTX
MN
My goal is 850hp. Anything over is a bonus. Anything less, is what it is. I'm no dyno guy, but I'll say I think you're gonna be happy w/ it! I've lowered my expectations enough to just live with what ever happens.
69 GTX
68 Road Runner
[Re: Streetwize]
#3043030
05/17/22 11:47 AM
05/17/22 11:47 AM
Hemi_Joel
Minnesota
...what stall and gear are you running? Wize, He's running the infinitely variable stall setup.
[Re: Hemi_Joel]
#3043040
05/17/22 12:07 PM
05/17/22 12:07 PM
ZIPPY
S.E. Michigan
...what stall and gear are you running? Wize, He's running the infinitely variable stall setup. Aka "THE MAN PEDAL"
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3043046
05/17/22 12:09 PM
05/17/22 12:09 PM
Posts: 10,009 MN
JERICOGTX
MN
...what stall and gear are you running? Wize, He's running the infinitely variable stall setup. Aka "THE MAN PEDAL" Correct. The car has a Liberty Equalizer 4 speed. Rear gear will be a 4.30 in the Dana 60, and the Liberty has a 2.92 first gear.
69 GTX
68 Road Runner
[Re: Streetwize]
#3043048
05/17/22 12:12 PM
05/17/22 12:12 PM
Posts: 10,009 MN
JERICOGTX
MN
OK I'm guessing it might be an Ultradyne or Bullet because they seem to cut a lot of their cams for 102 ICL, at least on their Asymmetrical (fast opening/slow closing) lobes. The cam is from Erson. My machinist has had good luck getting cams from them, vs. other cam grinders. This one took only a couple weeks to get.
69 GTX
68 Road Runner
[Re: Streetwize]
#3043083
05/17/22 02:01 PM
05/17/22 02:01 PM
Posts: 10,009 MN
JERICOGTX
MN
I've never been one to do things the easy way... Besides, it gives my buddies lots of ammo for giving me sh!t...
69 GTX
68 Road Runner
[Re: AndyF]
#3043111
05/17/22 03:55 PM
05/17/22 03:55 PM
Posts: 10,009 MN
JERICOGTX
MN
I have a feeling that you'll be exchanging those 4.30 gears for some 3.70 gears after a few passes....... The car has 14x32 tires. Calculations have it going through the traps at 150 mph with 4.30 gears, and 7000 rpm. Liberty wanted a 4.30 gear in the car as well.
69 GTX
68 Road Runner
[Re: Streetwize]
#3043124
05/17/22 05:00 PM
05/17/22 05:00 PM
Hemi_Joel
Minnesota
He'll be grabbing 2nd with the wheels in the air!
[Re: Streetwize]
#3043219
05/18/22 06:14 AM
05/18/22 06:14 AM
Posts: 10,009 MN
JERICOGTX
MN
With a 2.94 First gear either you'll be in 2nd gear by the 60' cone...or you'll be IN ORBIT!! lol The 1-2 shift is usually around the 65'-70' mark, on a stick car. My Jerico had a 3.09 first gear. After years of running the car, you get used to the flow of things. It's what makes a stick car fun.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3043233
05/18/22 08:17 AM
05/18/22 08:17 AM
Streetwize
Weddington, N.C.
Oh I know I raced sticks for years, back in high school my buddies would set up race bets with their 4 speed cars and then throw me the keys to drive for them !
This is an auto but an 8" spragless 5300 stall can be fun too
[Re: JERICOGTX]
#3043245
05/18/22 09:04 AM
05/18/22 09:04 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
What's it weigh for starters and I appreciate you letting me build ya a bad azz billet 1150ish carb to help you meet your goals. As Andy mentioned it MAY make more "magazine hp" but it won't go up the track faster and I've been there many times in the last few years plus my 1050's support over 950 as dynoed and in a light 2600ish pound door car have gone 5,20's in the 1/8. I'm not a very good dyno guesser but 900 seems obtainable and we will all find out soon as your parts will be here today to get started so you can meet your deadline........I'm excited for you and proud to be on board Jeff.....Peace!
[Re: Thumperdart]
#3043246
05/18/22 09:13 AM
05/18/22 09:13 AM
Posts: 10,009 MN
JERICOGTX
MN
Dom,the new combo should weigh 3050lbs, with me in the car, race ready. It was 3148lbs with the old iron/filled 400 block. The liberty, and new stainless headers add some weight, but the aluminum block should still be over a 100lbs less.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3043252
05/18/22 09:44 AM
05/18/22 09:44 AM
Posts: 13,182 aZLiViN
J_BODY
aZLiViN
I've never been one to do things the easy way... Besides, it gives my buddies lots of ammo for giving me sh!t... If you can’t make it down the track, make it pretty to look at! 😉
[Re: J_BODY]
#3043255
05/18/22 09:48 AM
05/18/22 09:48 AM
Posts: 10,009 MN
JERICOGTX
MN
I've never been one to do things the easy way... Besides, it gives my buddies lots of ammo for giving me sh!t... If you can’t make it down the track, make it pretty to look at! 😉 Ah, my number one sh!t giver, never disappoints me... LOL.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3043298
05/18/22 12:35 PM
05/18/22 12:35 PM
Posts: 9,791 MI, usa
dvw
MI, usa
Dom,the new combo should weigh 3050lbs, with me in the car, race ready. It was 3148lbs with the old iron/filled 400 block. The liberty, and new stainless headers add some weight, but the aluminum block should still be over a 100lbs less. I'd kill for 3050. Doug
[Re: dvw]
#3043301
05/18/22 12:45 PM
05/18/22 12:45 PM
an8sec70cuda
Dom,the new combo should weigh 3050lbs, with me in the car, race ready. It was 3148lbs with the old iron/filled 400 block. The liberty, and new stainless headers add some weight, but the aluminum block should still be over a 100lbs less. I'd kill for 3050. Doug You?
[Re: Al_Alguire]
#3043336
05/18/22 04:58 PM
05/18/22 04:58 PM
Hemi_Joel
Minnesota
Jeff's new secret weapon!
[Re: Al_Alguire]
#3043360
05/18/22 05:56 PM
05/18/22 05:56 PM
Posts: 10,009 MN
JERICOGTX
MN
Heck I'd kill for 3300 Sounds like you have a good combo getting ready to make some noise. Im sure it will keep you ahead for that steak dinner race for awhile Yeah someone has been slacking, but that’s Standard Operating Procedure, for him, and keeps saying he has PLENTY of time. LOL.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3043376
05/18/22 06:47 PM
05/18/22 06:47 PM
Posts: 2,902 A shed in England
Tig
A shed in England
I'd put the cam in earlier unless you're tire limited. I'd guess about 870-880 hp I let my machinist pick out the cam. He wants the cam set 107-108, which is where it’s at now. We run the Indy CM3 cam. .768/.720" 284/300 on a 580 motor. It absolutely ran the best on a 108 centre line (intake). Motor makes over 900 in good air.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: 440Jim]
#3043479
05/19/22 06:13 AM
05/19/22 06:13 AM
Posts: 10,009 MN
JERICOGTX
MN
Jeff, Just stick to your work and run a good number. No need to answer the jive talkers.... I usually have it coming. LOL.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3043486
05/19/22 06:59 AM
05/19/22 06:59 AM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
Jeff, Just stick to your work and run a good number. No need to answer the jive talkers.... I usually have it coming. LOL. No way? lol
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: Bad340fish]
#3043491
05/19/22 07:14 AM
05/19/22 07:14 AM
Posts: 10,009 MN
JERICOGTX
MN
Jeff, Just stick to your work and run a good number. No need to answer the jive talkers.... I usually have it coming. LOL. No way? lol LOL!!!
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3045047
05/25/22 08:18 AM
05/25/22 08:18 AM
Posts: 10,009 MN
JERICOGTX
MN
Have been making slow progress with the engine. After mocking up a cylinder head to check for pushrod length, I noticed that the pushrods were going to hit the block. INDY casts one block for Wedge, and HEMI's. If the block is designated for a Wedge head, the boss for the HEMI head bolt is machined off. While this is a used block, the previous owner had SR heads, with 1.5 rockers. 440-1 heads with offset intake rockers, and 1.6 rockers changed the pushrod location. I taped everything off, and took my die grinder to the areas that need to be clearanced. Nothing too major, just takes time. A buddy of mine turned down the mandrel for my vacuum pump. Didn't want any more hanging out than was necessary.
Over the last weekend, I was able to get the rear end setup. A friend had a set of 4.30 Pro Gears with a few passes on them. I also think I have my RacePak driveshaft senor issue figured out. The graph has always been messed up after a pass, and never "clean". Doing some reading and it was mentioned that the bracket holding the sensor needs to be nonferrous. My was made of steel. Guessing the sensor was grounding out? That is now fixed, hopefully.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3050654
06/15/22 08:29 AM
06/15/22 08:29 AM
Posts: 10,009 MN
JERICOGTX
MN
Dyno session is scheduled for tomorrow morning. Engine is ready. Not sure my nerves are. LOL. I did get my 1150 Thumper carb from Dom, since the last time I posted on this thread. Looks awesome! I don't really have too many things to test. Will start out with Hooker 5209 headers, and my old 1050 for break in, then switch to Dom's carb, and bigger headers that fit my car. I did make the decision to run Sunoco Supreme 112 gas, instead of the Renegade 110.
69 GTX
68 Road Runner
[Re: gregsdart]
#3050680
06/15/22 10:30 AM
06/15/22 10:30 AM
Posts: 10,009 MN
JERICOGTX
MN
Jeff, i predict 910 hp at 7100 rpm. Dynoing at R&R? Good luck with it! Not R&R. The dyno is in Eden Valley. Craig's Machine & Dyno. He is good friends with my machinist.
69 GTX
68 Road Runner
[Re: tboomer]
#3050719
06/15/22 12:48 PM
06/15/22 12:48 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
Best of luck hopefully it does all you want it to do.....Refresh my memory any big changes other than the block from the old set up?
[Re: tboomer]
#3050727
06/15/22 01:02 PM
06/15/22 01:02 PM
an8sec70cuda
Good luck Jeff! Can't wait for the results! What he said!!!
[Re: Al_Alguire]
#3050756
06/15/22 02:17 PM
06/15/22 02:17 PM
Posts: 10,009 MN
JERICOGTX
MN
Best of luck hopefully it does all you want it to do.....Refresh my memory any big changes other than the block from the old set up? The only thing I used from the old engine, is the distributor, and oil pan. SR heads vs 440-1 345CNC's, 499ci vs, 563ci, Bigger headers, bigger carb, and WAY bigger cam.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3050772
06/15/22 03:50 PM
06/15/22 03:50 PM
Al_Alguire
Las Vegas
Should make plenty more power...Did you ever dyno the old combo?
I wish we could get some parts. Love to share the build stuff but its just sitting collecting dust
[Re: Al_Alguire]
#3050774
06/15/22 04:04 PM
06/15/22 04:04 PM
Posts: 10,009 MN
JERICOGTX
MN
I wish we could get some parts. Love to share the build stuff but its just sitting collecting dust The old engine made 732hp with a flat tappet cam. Not sure what happened to the dyno sheets, as that was 19 years ago.
69 GTX
68 Road Runner
[Re: J_BODY]
#3050966
06/16/22 01:24 PM
06/16/22 01:24 PM
Al_Alguire
Las Vegas
Well should make enough to run an 8 That should be plenty to keep you ahead in the "steak dinner" races for awhile.
[Re: Al_Alguire]
#3050967
06/16/22 01:27 PM
06/16/22 01:27 PM
Posts: 10,009 MN
JERICOGTX
MN
Well… I’ll keep this short and to the point. Never made any pulls today. Have water in the oil. Not sure where from, and honestly, I don’t even want to look at it right now. Pretty disappointed, and took the wind out of my sail.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3050968
06/16/22 01:31 PM
06/16/22 01:31 PM
Cab_Burge
[Re: JERICOGTX]
#3050982
06/16/22 01:59 PM
06/16/22 01:59 PM
ZIPPY
S.E. Michigan
Dangit. Sorry to hear that man.
Rich H.
Esse Quam Videri
[Re: J_BODY]
#3050984
06/16/22 02:05 PM
06/16/22 02:05 PM
an8sec70cuda
Alright Jeff, it's after 2 PM now. What'd it make?????
[Re: an8sec70cuda]
#3050987
06/16/22 02:13 PM
06/16/22 02:13 PM
Posts: 10,009 MN
JERICOGTX
MN
Alright Jeff, it's after 2 PM now. What'd it make????? It made a mess…
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3050992
06/16/22 02:20 PM
06/16/22 02:20 PM
fast68plymouth
So. Burlington, Vt.
Wow...... sucks big time!!
My suggestion will be to not take it too far apart without pressure testing it as is.
Hopefully it’s as simple as a leaking head gasket.
[Re: JERICOGTX]
#3051011
06/16/22 03:03 PM
06/16/22 03:03 PM
an8sec70cuda
Alright Jeff, it's after 2 PM now. What'd it make????? It made a mess… Damm, I hate to hear that! What happened man?
[Re: Rodenteliminator]
#3051056
06/16/22 06:04 PM
06/16/22 06:04 PM
Al_Alguire
Las Vegas
As much a I hate to say this I am not all that surprised and older Indy block is leaking especially if it had any repairs in its past. I have seen a few here that have done the same. Hopefully something simple. You may have some options if it is a leaky block however. Hope its not that bad and yes pressure test it before you tear it to far down. Seen a few of the old blocks leak around the bottom of the bore.....
[Re: HardcoreB]
#3051209
06/17/22 09:59 AM
06/17/22 09:59 AM
Posts: 9,091 Rogue River, OR
Jeremiah
Rogue River, OR
I can relate; my 451 split #5 for no apparent reason in May. After sonic testing 3 blocks we finally found a decent one. Hopefully starting assy next week.
Keep your head up and try not to let disappointment cloud your end goals. I think we are all excited to see you rip some gears in that car!
[Re: J_BODY]
#3051212
06/17/22 10:08 AM
06/17/22 10:08 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I’m sickened by this…. this hobby serves up such a beat down sometimes When you get in the ring with a serious contender , you know that you're going to be hit. You can still win the fight. I've had parallel experiences , though not at this price or power level. But the bruises to the psyche sure seem to last. I hope it isn't too severe , or difficult to pin down.
[Re: tubtar]
#3051457
06/18/22 09:48 AM
06/18/22 09:48 AM
Posts: 8,156 Plymouth, MI
Blusmbl
Plymouth, MI
I'm so sorry Jeff, this is brutal. I hope it's a relatively easy repair and you're only out time.
[Re: birdtracker]
#3058725
07/12/22 10:15 PM
07/12/22 10:15 PM
Posts: 10,009 MN
JERICOGTX
MN
Update: After running the engine on the dyno for only a couple minutes, we found water in the oil. Pulled the engine off the dyno right away, and once it was back in my garage, I pressure tested the cooling system, and immediately found the leak. The water was coming from in between the block casting, and sleeve. A good friend helped me tear everything down, so I could get the block back to the machinist right away. Once it was back at his shop we discussed what happened, and where to go from there. He called this last Saturday, and said he has the sleeve out and pressure tested the block, and found a crack at the bottom of the bore. Today, I brought the block home, and prepared the block to be welded tomorrow, and then I bring the block back, to have the sleeve reinstalled. Before anyone goes off, I’m not blaming anyone. Sh!t happens. This was a used, damaged block, that I bought extremely cheap. I have less into this thing than the fully prepared 400 block I had done nearly 20 years ago. It’s just the risk you take. It’s being taken care of. Time to move forward.
69 GTX
68 Road Runner
[Re: Cab_Burge]
#3058776
07/13/22 07:06 AM
07/13/22 07:06 AM
Posts: 10,009 MN
JERICOGTX
MN
I try to make the best of all my experiences, if I don't have the bad ones now and then I don't really enjoy the good one. Sounds like you have a bunch of good times in front of you You have to take the not so good experiences in stride. For myself, it makes me learn about the problem, and how to go about fixing it. A couple years ago, I was having an issue with my Jerico trans. and was getting ready to load the car up in the trailer, when the racer next to me came walking over. He said, "It sucks having stuff go wrong, but do you see all these people walking into the gate, and into the stands? They wish they could be doing what you're doing now, instead of being a spectator. You'll get it fixed, and be back out again."
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3058781
07/13/22 07:27 AM
07/13/22 07:27 AM
Posts: 25,851 United Socialist States of Ame...
tboomer
I try to make the best of all my experiences, if I don't have the bad ones now and then I don't really enjoy the good one. Sounds like you have a bunch of good times in front of you You have to take the not so good experiences in stride. For myself, it makes me learn about the problem, and how to go about fixing it. A couple years ago, I was having an issue with my Jerico trans. and was getting ready to load the car up in the trailer, when the racer next to me came walking over. He said, "It sucks having stuff go wrong, but do you see all these people walking into the gate, and into the stands? They wish they could be doing what you're doing now, instead of being a spectator. You'll get it fixed, and be back out again." And Jeff. That fella was right! You have the knowledge and desire to get it fixed and be back out there! I have not been down the track in my car in ten years and it sits in my garage. I can't even bring myself to go spectate anymore. I will watch for updates on your progress and I wish you nothing but the best! Good luck Jeff!
The end is near.....
[Re: JERICOGTX]
#3058786
07/13/22 08:09 AM
07/13/22 08:09 AM
Bad340fish
Tulsa OK
I try to make the best of all my experiences, if I don't have the bad ones now and then I don't really enjoy the good one. Sounds like you have a bunch of good times in front of you You have to take the not so good experiences in stride. For myself, it makes me learn about the problem, and how to go about fixing it. A couple years ago, I was having an issue with my Jerico trans. and was getting ready to load the car up in the trailer, when the racer next to me came walking over. He said, "It sucks having stuff go wrong, but do you see all these people walking into the gate, and into the stands? They wish they could be doing what you're doing now, instead of being a spectator. You'll get it fixed, and be back out again." Glad it is moving forward again, and I look forward to seeing you in September if Joel gets his car finished.
[Re: JERICOGTX]
#3058787
07/13/22 08:14 AM
07/13/22 08:14 AM
Posts: 4,003 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
[quote=Cab_Burge]..................... You'll get it fixed, and be back out again." This was a Jedi mind trick! Either way you are in a good state of mind! Thanks for sharing the ups and downs, it makes the report more real and helps everyone put into perspective all the crap that happens behind the scenes, maybe it inspires us. Best wishes.
[Re: Bad340fish]
#3058831
07/13/22 10:47 AM
07/13/22 10:47 AM
Posts: 10,009 MN
JERICOGTX
MN
I try to make the best of all my experiences, if I don't have the bad ones now and then I don't really enjoy the good one. Sounds like you have a bunch of good times in front of you You have to take the not so good experiences in stride. For myself, it makes me learn about the problem, and how to go about fixing it. A couple years ago, I was having an issue with my Jerico trans. and was getting ready to load the car up in the trailer, when the racer next to me came walking over. He said, "It sucks having stuff go wrong, but do you see all these people walking into the gate, and into the stands? They wish they could be doing what you're doing now, instead of being a spectator. You'll get it fixed, and be back out again." Glad it is moving forward again, and I look forward to seeing you in September if Joel gets his car finished. I think Joel will have been to the track at LEAST a half dozen times by the time Drag Week rolls around. Everything should be sorted out, and proven.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3058836
07/13/22 10:58 AM
07/13/22 10:58 AM
Bad340fish
Tulsa OK
I try to make the best of all my experiences, if I don't have the bad ones now and then I don't really enjoy the good one. Sounds like you have a bunch of good times in front of you You have to take the not so good experiences in stride. For myself, it makes me learn about the problem, and how to go about fixing it. A couple years ago, I was having an issue with my Jerico trans. and was getting ready to load the car up in the trailer, when the racer next to me came walking over. He said, "It sucks having stuff go wrong, but do you see all these people walking into the gate, and into the stands? They wish they could be doing what you're doing now, instead of being a spectator. You'll get it fixed, and be back out again." Glad it is moving forward again, and I look forward to seeing you in September if Joel gets his car finished. I think Joel will have been to the track at LEAST a half dozen times by the time Drag Week rolls around. Everything should be sorted out, and proven. I feel like Joel typed that. lol
[Re: Bad340fish]
#3058871
07/13/22 12:47 PM
07/13/22 12:47 PM
Al_Alguire
Las Vegas
Older Indy blocks are notorious for leaking there. The material there is almost tin foil thickness in many spots. FWIW a partial fill might be a good thing to consider. Been down this road many times.
[Re: Al_Alguire]
#3058949
07/13/22 03:52 PM
07/13/22 03:52 PM
Posts: 10,009 MN
JERICOGTX
MN
Older Indy blocks are notorious for leaking there. The material there is almost tin foil thickness in many spots. FWIW a partial fill might be a good thing to consider. Been down this road many times. It's over a 1/4' thick there. Just happens to be where the rod broke. At first it didn't look like much damage there. It is going to get a partial fill, just to help stabilize things more. Block is welded, and turned out nice. It will be back at the machinists, less than 2 hours from me typing this. We pressure tested it, and the leak is gone. It just needs to be machined, and drop in a new sleeve, and I can put it all back together.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3058989
07/13/22 05:15 PM
07/13/22 05:15 PM
birdtracker
[Re: birdtracker]
#3058994
07/13/22 06:01 PM
07/13/22 06:01 PM
Hemi_Joel
Minnesota
on the rock block, best stuff out there. Jeff that's great news! I hope you got your motorvation back. Now I better get busy so I don't lose another bet.
[Re: birdtracker]
#3059098
07/14/22 06:07 AM
07/14/22 06:07 AM
Posts: 10,009 MN
JERICOGTX
MN
Thank you for that. Got it on order.
69 GTX
68 Road Runner
[Re: birdtracker]
#3059132
07/14/22 09:41 AM
07/14/22 09:41 AM
Hemi_Joel
Minnesota
[Re: JERICOGTX]
#3059174
07/14/22 12:33 PM
07/14/22 12:33 PM
Al_Alguire
Las Vegas
Good luck with it, hopefully it is fixed, the only issue I have seen with pressure testing these bocks is NOT heating them up before you test them. Hopefully you have the problems fixed.
[Re: JERICOGTX]
#3059381
07/15/22 11:46 AM
07/15/22 11:46 AM
an8sec70cuda
Hope the re-rebuild goes smoothly Jeff! Looking forward to some dyno results and seeing it finished!
[Re: an8sec70cuda]
#3059418
07/15/22 01:49 PM
07/15/22 01:49 PM
Posts: 10,009 MN
JERICOGTX
MN
Hope the re-rebuild goes smoothly Jeff! Looking forward to some dyno results and seeing it finished! Thanks Chip. The RockBlock arrived early this morning, so I delivered it to the machinist. He’s on vacation for a week after today. I’m planning on being ready for Labor Day weekend. Still have to finish up the floor in the car, paint the scatter shield, and if time allows, paint the new hood for the car.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3077394
09/15/22 06:25 AM
09/15/22 06:25 AM
Posts: 10,009 MN
JERICOGTX
MN
Just an update on this project. The block was welded, and I was lucky to find a sleeve .010 over, locally. After having the cylinder machined to fit the sleeve, it was pressure tested, and a pin hole leak was exposed. I picked up the block on a Monday, had it welded at work the next day, and in the afternoon, it was back in the machinists shop. Got a call this last Monday, and was told that the spot that was welded was now leaking worse... After work, I picked up the block once again, and something didn't look right. The new weld was much different looking than the previous work. Brought it into work, and the welder knew exactly what happened. He grabbed the wrong filler rod, and used a harder rod by mistake. I dug out the recent weld with a die grinder, and opened up a fairly big area. It was then rewelded, with the proper filler rod, and I delivered the block to the machinist last night. It's been a frustrating journey...
At this point, I just want to get the engine together, dyno test it, and get everything in the car before the snow flies.
69 GTX
68 Road Runner
[Re: tboomer]
#3077419
09/15/22 08:58 AM
09/15/22 08:58 AM
an8sec70cuda
Man, this thing is fighting you aint it! It'll be worth it in the end...just keep plugging away at it.
[Re: an8sec70cuda]
#3077422
09/15/22 09:05 AM
09/15/22 09:05 AM
Posts: 10,009 MN
JERICOGTX
MN
Man, this thing is fighting you aint it! It'll be worth it in the end...just keep plugging away at it. Fighting me like an old married couple that hate each other. Just been annoying, and disappointing. Hate not being able to make a pass in the car this year.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3077525
09/15/22 01:34 PM
09/15/22 01:34 PM
Al_Alguire
Las Vegas
Hopefully it woudl out for you. As I have stated my luck with the older indy blocks has not been so good.
[Re: Al_Alguire]
#3077545
09/15/22 03:02 PM
09/15/22 03:02 PM
Posts: 10,009 MN
JERICOGTX
MN
Hopefully it woudl out for you. As I have stated my luck with the older indy blocks has not been so good. It will work out. If it was easy, everyone would be doing it. Right?
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3077558
09/15/22 03:38 PM
09/15/22 03:38 PM
Al_Alguire
Las Vegas
Yes sir...Lets hope this is the end of your long road...
[Re: JERICOGTX]
#3077590
09/15/22 06:06 PM
09/15/22 06:06 PM
Blusmbl
Plymouth, MI
At this point, I just want to get the engine together, dyno test it, and get everything in the car before the snow flies. The wrong filler rod is a kick in the shorts on top of everything else, ugh. If you get it together after the MN tracks are closed, would you head south with it to make some passes?
[Re: Blusmbl]
#3077624
09/15/22 07:16 PM
09/15/22 07:16 PM
Posts: 10,009 MN
JERICOGTX
MN
At this point, I just want to get the engine together, dyno test it, and get everything in the car before the snow flies. The wrong filler rod is a kick in the shorts on top of everything else, ugh. If you get it together after the MN tracks are closed, would you head south with it to make some passes? It’s costly enough to hit the local 1/8th mile track, 50 miles away. No way I’m headed South to test.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3077675
09/15/22 09:27 PM
09/15/22 09:27 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
At this point, I just want to get the engine together, dyno test it, and get everything in the car before the snow flies. Geez. Jeff, I hope things turn for the better man. The cost, the logistics, and hoping it works out takes all the fun out it. That is definitely frustrating. Good luck.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: EvilB1Dart]
#3077862
09/16/22 03:54 PM
09/16/22 03:54 PM
Posts: 10,009 MN
JERICOGTX
MN
Thanks Wes. You aren’t kidding about taking the fun out of it. What I wouldn’t give right now to yank the handle on that Liberty trans.
Jeff
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3079506
09/22/22 07:30 AM
09/22/22 07:30 AM
Posts: 10,009 MN
JERICOGTX
MN
Got a phone call from the machinist on Monday. Finally some good news. The new weld was machined, and then the block pressure tested. Passed with flying colors. The new sleeve was going in, right away, then fill the block with Rock Block, bore and hone the cylinder, and cut the deck. He's hoping to be done with everything by early next week. Since Joel and I did not go on Drag Week this year, I went back to work, to save a couple vacation days. Once the block is back, I'll take a day off and reassemble everything, then take another day off for the dyno appointment. If everything goes well, I should have the car back together before the snow flies. At least I will be ready for next year.
69 GTX
68 Road Runner
[Re: Leigh]
#3079584
09/22/22 11:11 AM
09/22/22 11:11 AM
Posts: 10,009 MN
JERICOGTX
MN
If my potato harvest job is finished, maybe I’ll see you at Grove Creek, Oct 8th. Good luck with it. Last race at GC is Oct 1-2.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3082772
10/03/22 12:31 PM
10/03/22 12:31 PM
Posts: 10,009 MN
JERICOGTX
MN
Picked up the block on Friday. Have only installed the crankshaft, and one piston. Need to cut the pistons down .005 or buy different head gaskets. Cutting the piston will be faster.
69 GTX
68 Road Runner
[Re: Cab_Burge]
#3082886
10/03/22 02:49 PM
10/03/22 02:49 PM
Posts: 10,009 MN
JERICOGTX
MN
Most likely goofing off... I'm sure he's making out his Christmas list to include Texas Roadhouse gift certificates, so he can pay up on yet another dinner bet, in 2023.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3082888
10/03/22 02:51 PM
10/03/22 02:51 PM
Posts: 702 Lake Villa Il
INTMD8
Lake Villa Il
Picked up the block on Friday. Have only installed the crankshaft, and one piston. Need to cut the pistons down .005 or buy different head gaskets. Cutting the piston will be faster. How close are they to the head?
[Re: INTMD8]
#3082893
10/03/22 02:57 PM
10/03/22 02:57 PM
Posts: 10,009 MN
JERICOGTX
MN
Picked up the block on Friday. Have only installed the crankshaft, and one piston. Need to cut the pistons down .005 or buy different head gaskets. Cutting the piston will be faster. How close are they to the head? The piston was .011 above the deck, before this last mess. I have .051 Cometic gaskets. The piston now sits .014 above the deck. Too tight for my liking at this point.
69 GTX
68 Road Runner
[Re: Cab_Burge]
#3082900
10/03/22 03:28 PM
10/03/22 03:28 PM
Hemi_Joel
Minnesota
Now don't go dragging my good name into this plebian world of wedgery. Isn't a Buick a wedge?
[Re: JERICOGTX]
#3082990
10/03/22 08:11 PM
10/03/22 08:11 PM
gregsdart
Picked up the block on Friday. Have only installed the crankshaft, and one piston. Need to cut the pistons down .005 or buy different head gaskets. Cutting the piston will be faster. How close are they to the head? The piston was .011 above the deck, before this last mess. I have .051 Cometic gaskets. The piston now sits .014 above the deck. Too tight for my liking at this point. I am counting on block growth as it warms to increase clearance the head. If we gain . 008 in clearance as it warms. All good. I am thinking I should do a test to make sure. Now to figure out how to heat the lock to about 160,' to find out for certain.
[Re: gregsdart]
#3083095
10/04/22 06:18 AM
10/04/22 06:18 AM
Posts: 10,009 MN
JERICOGTX
MN
Picked up the block on Friday. Have only installed the crankshaft, and one piston. Need to cut the pistons down .005 or buy different head gaskets. Cutting the piston will be faster. How close are they to the head? The piston was .011 above the deck, before this last mess. I have .051 Cometic gaskets. The piston now sits .014 above the deck. Too tight for my liking at this point. I am counting on block growth as it warms to increase clearance the head. If we gain . 008 in clearance as it warms. All good. I am thinking I should do a test to make sure. Now to figure out how to heat the lock to about 160,' to find out for certain. I'd like to think the clearance would be fine with an Aluminum block, but I just am not willing to take any chances at this point. This engine has been 2 years plus in the making. No need to risk it.
69 GTX
68 Road Runner
[Re: gregsdart]
#3083109
10/04/22 07:01 AM
10/04/22 07:01 AM
Bad340fish
Tulsa OK
Picked up the block on Friday. Have only installed the crankshaft, and one piston. Need to cut the pistons down .005 or buy different head gaskets. Cutting the piston will be faster. How close are they to the head? The piston was .011 above the deck, before this last mess. I have .051 Cometic gaskets. The piston now sits .014 above the deck. Too tight for my liking at this point. I am counting on block growth as it warms to increase clearance the head. If we gain . 008 in clearance as it warms. All good. I am thinking I should do a test to make sure. Now to figure out how to heat the lock to about 160,' to find out for certain. I have seen some guys use a propane burner on a large pot of water that circulates water with the electric water pump. That was on an assembled engine though. I thought it was a pretty genius way to heat cycle and retorque stuff with the engine out of the car. Especially on the combo I saw it on, a twin turbo BBC that looked like a nuclear reactor under the hood with all the plumbing lol.
[Re: tboomer]
#3083129
10/04/22 08:05 AM
10/04/22 08:05 AM
Posts: 10,009 MN
JERICOGTX
MN
What are you shooting for clearance wise Jeff? Mine are .004 below the deck.... I want .040 piston to head clearance.
69 GTX
68 Road Runner
[Re: tubtar]
#3083142
10/04/22 08:53 AM
10/04/22 08:53 AM
Posts: 10,009 MN
JERICOGTX
MN
Now don't go dragging my good name into this plebian world of wedgery. Isn't a Buick a wedge? Shots fired ! Shots fired ! It was proven 30+ years ago, in a magazine shootout, that a Buick is far superior to a HEMI anything. It predates the internet, so it MUST be true.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3083230
10/04/22 01:06 PM
10/04/22 01:06 PM
Al_Alguire
Las Vegas
.040" piston to head with an aluminum block is plenty conservative......
[Re: Al_Alguire]
#3083241
10/04/22 01:39 PM
10/04/22 01:39 PM
Posts: 10,009 MN
JERICOGTX
MN
.040" piston to head with an aluminum block is plenty conservative...... Right now I'm around .035-.036. The piston has plenty of rock in it. The highest point I saw was .028 above the deck.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3083472
10/05/22 08:15 AM
10/05/22 08:15 AM
gregsdart
.040" piston to head with an aluminum block is plenty conservative...... Right now I'm around .035-.036. The piston has plenty of rock in it. The highest point I saw was .028 above the deck. Since piston contact happens due to piston rock, (those with more experience chime in if I am missing something) the idea of shaving . 005 off at an angle on the closed side of the chamber might be a way to save a current combo? The angle could be measured with the piston cold in the block, and the actual cut may only extend three quarters of an inch in. JUST THINKEN, 🧐
[Re: gregsdart]
#3083703
10/06/22 06:24 AM
10/06/22 06:24 AM
Posts: 10,009 MN
JERICOGTX
MN
.040" piston to head with an aluminum block is plenty conservative...... Right now I'm around .035-.036. The piston has plenty of rock in it. The highest point I saw was .028 above the deck. Since piston contact happens due to piston rock, (those with more experience chime in if I am missing something) the idea of shaving . 005 off at an angle on the closed side of the chamber might be a way to save a current combo? The angle could be measured with the piston cold in the block, and the actual cut may only extend three quarters of an inch in. JUST THINKEN, 🧐 Probably more work to do it that way than it's worth? Fairly easy to just skim .005 off the top. Can I get away with less, while using an aluminum block? Probably, but since this is a bracket engine, and I really don't have the funds to be buying new pistons, once something does go wrong. I'll just adjust the old shoe polish on the window instead.
69 GTX
68 Road Runner
