Re: 563ci build specs, what will it make?
[Re: J_BODY]
#3050966
06/16/22 01:24 PM
06/16/22 01:24 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
Well should make enough to run an 8 That should be plenty to keep you ahead in the "steak dinner" races for awhile.
[Re: Al_Alguire]
#3050967
06/16/22 01:27 PM
06/16/22 01:27 PM
Posts: 10,009 MN
JERICOGTX
MN
Well… I’ll keep this short and to the point. Never made any pulls today. Have water in the oil. Not sure where from, and honestly, I don’t even want to look at it right now. Pretty disappointed, and took the wind out of my sail.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3050968
06/16/22 01:31 PM
06/16/22 01:31 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
[Re: JERICOGTX]
#3050982
06/16/22 01:59 PM
06/16/22 01:59 PM
Posts: 17,801 S.E. Michigan
ZIPPY
S.E. Michigan
Dangit. Sorry to hear that man.
Rich H.
Esse Quam Videri
[Re: J_BODY]
#3050984
06/16/22 02:05 PM
06/16/22 02:05 PM
Posts: 13,319 Marion, South Carolina [><]
an8sec70cuda
Alright Jeff, it's after 2 PM now. What'd it make?????
[Re: an8sec70cuda]
#3050987
06/16/22 02:13 PM
06/16/22 02:13 PM
Posts: 10,009 MN
JERICOGTX
MN
Alright Jeff, it's after 2 PM now. What'd it make????? It made a mess…
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3050992
06/16/22 02:20 PM
06/16/22 02:20 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Wow...... sucks big time!!
My suggestion will be to not take it too far apart without pressure testing it as is.
Hopefully it’s as simple as a leaking head gasket.
[Re: JERICOGTX]
#3051011
06/16/22 03:03 PM
06/16/22 03:03 PM
an8sec70cuda
Alright Jeff, it's after 2 PM now. What'd it make????? It made a mess… Damm, I hate to hear that! What happened man?
[Re: Rodenteliminator]
#3051056
06/16/22 06:04 PM
06/16/22 06:04 PM
Al_Alguire
Las Vegas
As much a I hate to say this I am not all that surprised and older Indy block is leaking especially if it had any repairs in its past. I have seen a few here that have done the same. Hopefully something simple. You may have some options if it is a leaky block however. Hope its not that bad and yes pressure test it before you tear it to far down. Seen a few of the old blocks leak around the bottom of the bore.....
[Re: HardcoreB]
#3051209
06/17/22 09:59 AM
06/17/22 09:59 AM
Posts: 9,091 Rogue River, OR
Jeremiah
Rogue River, OR
I can relate; my 451 split #5 for no apparent reason in May. After sonic testing 3 blocks we finally found a decent one. Hopefully starting assy next week.
Keep your head up and try not to let disappointment cloud your end goals. I think we are all excited to see you rip some gears in that car!
