'69 RR hood opening measurements needed #3041733
05/12/22 09:06 AM
05/12/22 09:06 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
The car has had the front cowl, cowl brackets, inner fenders and rad support all changed. Now the hood opening is different front to back - the front being wider by 1/2 an inch !! We're not sure if the opening is even square. Would appreciate it if someone could provide measurements of the front and rear widths as well as from the cowl to the front tip.
The rad support pieces were installed separately which probably contributed to the issues.
Re: '69 RR hood opening measurements needed [Re: Stanton] #3041746
05/12/22 10:23 AM
05/12/22 10:23 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Hood has a bit of crown so checked opening with it up, left it down and held tape in middle for cowl to tip. Stuck finger down at tip to gauge end on tape.
Front with rad support as good guide for straight across - 53” on the money
Rear with rear hood hinge bolt as rough guide for straight across - 52 7/8
Cowl with tape tip held to body, held tape in middle to hood with left hand, stuck finger down to touch tip of hood - 51.5
Will post up gap pics shortly. 69 GTX, 71k miles CA car and never hit or rusted in any way. Car has nice paint that I’m sure was redone, not sure if fenders came off.
I want my fair share
Re: '69 RR hood opening measurements needed [Re: SomeCarGuy] #3041747
05/12/22 10:26 AM
05/12/22 10:26 AM
SomeCarGuy Offline
SomeCarGuy  Offline
Pics are too big to upload. I’m not sure what changes the game on that. Had this happen on here before.
I’d say my gaps are pretty darn good with door to fender, cowl and hood sides, level all around so if you can get those numbers and a straight hood you should be golden.
Re: '69 RR hood opening measurements needed [Re: SomeCarGuy] #3041751
05/12/22 10:46 AM
05/12/22 10:46 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The photos are too large to post, 4Mb is the largest acceptable. Resize your photos and try again. You should be able to do it with 'Microsoft Office Picture Manager' under the 'Picture' tab.
"Only the best and brightest"
Re: '69 RR hood opening measurements needed [Re: 6PakBee] #3041758
05/12/22 11:11 AM
05/12/22 11:11 AM
SomeCarGuy Offline
SomeCarGuy  Offline
I only have apple stuff
Re: '69 RR hood opening measurements needed [Re: SomeCarGuy] #3042183
05/14/22 08:30 AM
05/14/22 08:30 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
These are SomeCarGuy's photos.
1969 Roadrunn Front Clip-1.jpg1969 Roadrunn Front Clip-2.jpg1969 Roadrunn Front Clip-3.jpg
Re: '69 RR hood opening measurements needed [Re: 6PakBee] #3042185
05/14/22 08:36 AM
05/14/22 08:36 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I measured a local car that appears to be in original shape and the rear is a tad narrower than the front. It doesn't have a hood I could measure so I'm curious if the hood is also narrower at the rear.
Re: '69 RR hood opening measurements needed [Re: Stanton] #3042274
05/14/22 02:39 PM
05/14/22 02:39 PM
moparx Offline
moparx  Offline
i wouldn't think the hood would be narrower at the rear.
but then, i have been wrong many times before.
beer
Re: '69 RR hood opening measurements needed [Re: moparx] #3042749
05/16/22 10:46 AM
05/16/22 10:46 AM
SomeCarGuy Offline
SomeCarGuy  Offline
Mine is 52 5/8 front and rear.
I went to just behind the edge of the hood scoop in rear.
Went just behind the angled parts of the front as that seemed to be a better place with the dome effect. Held tape down in middle of hood for both measurements.
