175/80/13 tires for a 80's plymouth #3041538
05/11/22 03:28 PM
05/11/22 03:28 PM
Escondido, California
JonGottaDemonDad Offline OP
I can only find these tires in trailer tires. The tires on the car are like new but they are 30 plus years old!!!
Advice?
Craig
Re: 175/80/13 tires for a 80's plymouth [Re: JonGottaDemonDad] #3041548
05/11/22 03:48 PM
05/11/22 03:48 PM
Andrewh Offline
Andrewh  Offline
discount tire lists some. and other 13 inch tires.
at least a few were radials. so even if they are trailer tires, it should be better than the bias ply.
down side is none of them are brand names I recognize and they still want a bunch for them.
Re: 175/80/13 tires for a 80's plymouth [Re: Andrewh] #3041567
05/11/22 04:40 PM
05/11/22 04:40 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Re: 175/80/13 tires for a 80's plymouth [Re: Sniper] #3041580
05/11/22 05:32 PM
05/11/22 05:32 PM
scratchnfotraction Offline
at my local tire shop I used a 185/80/13 Dayton radial tire on my 68Dart that came stock with the 13" wheels. should be able to find a 13" metric car tire without a special order tire
what a lot of the lowrider 64 chebbys use with the 13" Dayton wire wheels and hydro pumps & dumps. got them cheap 80$ a tire.
when I went to 5 on 4.5 axles with 11x2.5 rear drums & R-body 11 front disc rotors with the 15" cop wheels i used a 195/60/15 tire. was same height as the 13" 185/80/13
I also have them order up VW tires for my weld drag skinnys 3.5x15 rim 165/15 radial called a VW tire or V-Dub tire.
Re: 175/80/13 tires for a 80's plymouth [Re: JonGottaDemonDad] #3041644
05/11/22 09:40 PM
05/11/22 09:40 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Re: 175/80/13 tires for a 80's plymouth [Re: JonGottaDemonDad] #3041678
05/11/22 11:05 PM
05/11/22 11:05 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
If you search ebay you have to type in " p175/80r13, -st ", you have to add minus st or " -st " to not bring up trailer tires.
https://www.ebay.com/sch/i.html?_fr...c=0&_odkw=P175%2F80r13&_osacat=0
Re: 175/80/13 tires for a 80's plymouth [Re: SNK-EYZ] #3041717
05/12/22 07:45 AM
05/12/22 07:45 AM
new berlin wisconsin
Mr T2U Online content
Mr T2U  Online Content
you can change the size a bit.
tire rack sells these size CAR tires .
175/70/13 4 different tires available between $74-94 each
185/70/13 1 tire sold for $86
https://www.tirerack.com/tires/sizes/results.jsp?diameter=13
perception is 90% of reality
Re: 175/80/13 tires for a 80's plymouth [Re: JonGottaDemonDad] #3041724
05/12/22 08:21 AM
05/12/22 08:21 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
Go with the Maxxis MA1. I got for my 69 Dart 6 cyl with 13" tires. They are very close to the original overall diameter and speedo is right on and are whitewall like original.
It was sad that could not find any Made in USA 13" tires in right size (only low profile) and these are from Indonesia I think. But they did balance very well and appear to be decent tires.
They are a 80 sidewall, so they do have a good amount of tire roll on turns. If you want performance, then go with a low profile tire. Should be able to find BFG TA in 13"
Re: 175/80/13 tires for a 80's plymouth [Re: njmopar] #3041768
05/12/22 11:43 AM
05/12/22 11:43 AM
so much great help!!!
Thank you everyone!!!!
Craig
