Re: It's alive [Re: dvw] #3041585
05/11/22 05:44 PM
05/11/22 05:44 PM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
Very Nice! Looks Good! up
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: It's alive [Re: DusterKid] #3041623
05/11/22 08:03 PM
05/11/22 08:03 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Thanks for the compliments. Its just a home built car that i did the best i could with. Talked to a few different people. Seems pretty common to run the cam straight up in this type of build. The LCA is 112 so we'll see. It has a Jessel so it can be moved if needed. The shocks are Afco BG in the rear which are pretty new. The Fronts are Afco doubles. It was out of adjustment. Running both R &C full tight. So they've been tighten up. The carbs were beautiful billet 4150s from Mark Whitener at Lightening Carbs. NMCA was adamant that they were an unfair advantage in an index class. So Mark was gracious enough to obtain a pr of cast bodies and swap in the annular boosters. I tried to get the rule changed. No dice. So now it's legal.
Doug
Re: It's alive [Re: dvw] #3041663
05/11/22 10:19 PM
05/11/22 10:19 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Still looking great and probably faster and quicker than ever
Re: It's alive [Re: dvw] #3041682
05/11/22 11:21 PM
05/11/22 11:21 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Cool. Glad to see that beast is up and running again. Did you gain anything with the annular boosters vs downleg?
Re: It's alive [Re: mopar dave] #3041689
05/11/22 11:49 PM
05/11/22 11:49 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
wow looking flat out fast
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: It's alive [Re: mopar dave] #3041700
05/12/22 01:16 AM
05/12/22 01:16 AM
gregsdart Offline
gregsdart  Offline
Great looking ride, Doug! If the carbs work well i am betting on your "8". Looking forward to a detailed track report👍
Re: It's alive [Re: gregsdart] #3041708
05/12/22 07:07 AM
05/12/22 07:07 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Mark told me the annular boosters he uses flow as good as any down legs he's tested except one type. We felt with the large plenum and the fact that it's a foot brake car the annular would be a good choice. They flow way more air than it needs anyway. We ran the carbs with the billet bodies last year. Never even got as far as jetting. In fact that was the start of the failure. Previously with the Eddy carbs the starting line was hit or miss at times. Usually 1.32-1.35 60 ft. Occasionally dipping into 1.2x area. On the first test session after a few tweeks it carried the wheels through 2nd gear. (pic below it was this high in 2nd gear). Even with wheelie bars the rear bumper was about 4" off the ground. Came down pretty hard. Bent the pan. A week later it stripped a front planet (now steel). With the Eddy carbs you could loosen the front shocks -20 clicks (29 clicks of adjustment) from full tight. Now they have to be full tight. 60 fts the first day were 1.251-1.252 over 7 passes.
Doug
Re: It's alive [Re: dvw] #3041748
05/12/22 10:31 AM
05/12/22 10:31 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
This is my 1.61" venturi 4150 w/ a set of Mark's annular boosters... as yet untested on an engine.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: It's alive [Re: Brad_Haak] #3041749
05/12/22 10:39 AM
05/12/22 10:39 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Same size here. I've been very happy with Mark. Great to deal with.
Doug
Re: It's alive [Re: dvw] #3041759
05/12/22 11:20 AM
05/12/22 11:20 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Curious to your results as well. I have been told annulars don't work as well as downlegs in a 4150. The venturi is just too small.
Re: It's alive [Re: mopar dave] #3041807
05/12/22 03:10 PM
05/12/22 03:10 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
IMO, booster selection can be somewhat subjective. Put downleg boosters in a "big" 4150 venturi, say 1.58+, and in some (many?) cases it's going to suffer from low booster signal and ragged fuel distribution at low(er) RPM.
A "big" venturi 4150 carb with annular boosters may not flow any more than a smaller venturi + downleg combination, but it may improve atomization and fuel distribution for the same flow rate. Whether that translates into a performance improvement is tied to the combination.
I also have a hypothesis that two annular boosters of comparable size and dry-flow capabilities may result in significantly different wet-flow results where the booster with improved atomization actually reduces the total air-fuel volume significantly. If that's true and the configuration w/ the better atomization -- yet lower wet-flow rate -- improves performance, then that could (would?) reflect an air-fuel mixture quality vs quantity scenario.
Top view of the 1.61" v annular carb pictured above; that's a big hole to park a typical downleg in.
Re: It's alive [Re: moparacer] #3041813
05/12/22 03:42 PM
05/12/22 03:42 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Originally Posted by moparacer
Great news! You car is a work of art.....
Interesting you retarded your cam too. I did a few weeks ago and it picked mine up.
What is the application CID/heads/compression? What cam grind and where did you put the ICL?
Re: It's alive [Re: dvw] #3041815
05/12/22 03:46 PM
05/12/22 03:46 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Again nice work/perseverance Doug. I'm sure the extra trouble will pay back, good luck tomorrow!
Re: It's alive [Re: HardcoreB] #3041847
05/12/22 06:36 PM
05/12/22 06:36 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Mine are the 1.61" venturi also. It has been 148-150 mph with Edelbrock 750's in good air. I'm sure that these have more than enough airflow at my rpm (7300 max). Dry flow was over 1100. For sure it picked up at the starting line. Solid mid 1.2x 60ft leaving at 3000 rpm off the foot brake. Already was 149 mph in OK air. Last weight was 3335 with me. We'll see how it runs tomorrow.
Doug.
Re: It's alive [Re: dvw] #3041853
05/12/22 07:00 PM
05/12/22 07:00 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Good luck Doug!
Re: It's alive [Re: slantzilla] #3041885
05/12/22 09:48 PM
05/12/22 09:48 PM
Chesterfield Twp. Mi.
John Burdine Offline
Where are you testing tomorrow?
Re: It's alive [Re: John Burdine] #3041898
05/12/22 10:57 PM
05/12/22 10:57 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Mid Michigan Motorplex, a friend has a track rental .
Doug
Re: It's alive [Re: Brad_Haak] #3041942
05/13/22 08:50 AM
05/13/22 08:50 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I understand where your coming from. I have been under the impression an annular was better for atomization. Sounds like a good thing to me, but BLP has done many flow tests of the 4150 with annular boosters and didn't like the results. Annulars is what i wanted for my 572 Hemi build in a 1.450 venturi twin carb deal and i was told downleg would be better. Curious to any improvements using annular boosters. Please let us know.
Re: It's alive [Re: mopar dave] #3041971
05/13/22 10:58 AM
05/13/22 10:58 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Dave - FWIW (not much), I wouldn't put an annular in anything smaller than a 1.56" venturi
Re: It's alive [Re: justinp61] #3042326
05/14/22 05:23 PM
05/14/22 05:23 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
That's a nice piece. Real nice!
"Any fool can know. The point is to understand"
- A. Einstein
