Brake fluid leaks #3041347
05/10/22 10:31 PM
05/10/22 10:31 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
What is the secret to getting new brake lines at the master cylinder and distribution block leak free. Lines and distribution block/proportion valves are new from classic industries. Lines are steel.
Re: Brake fluid leaks [Re: RROD] #3041359
05/10/22 11:57 PM
05/10/22 11:57 PM
Tighten the heck out of them to get the flares to flatten out and seal wrench scope
Make sure and use a tubing wrench only on them, not an standard box or open end wrench tsk
Good luck, let us know what you find please.
Re: Brake fluid leaks [Re: RROD] #3041380
05/11/22 06:35 AM
05/11/22 06:35 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I like to tighten them up and then back them off slightly and repeat that process several times, getting them tighter with each turn.
Re: Brake fluid leaks [Re: Cab_Burge] #3041381
05/11/22 06:35 AM
05/11/22 06:35 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I know this sounds wrong. But trust me it works. Over 25 years, no leaks. A dab of white Teflon sealer on the flare and thread. I don't know why it works. My feeling is it lubricates and allows the parts to seat. I didn't believe it when I was told years ago by a friend. Got frustrated with leaks one day and tried it. Never looked back since.
Doug
Re: Brake fluid leaks [Re: dvw] #3041461
05/11/22 12:26 PM
05/11/22 12:26 PM
moparx Online content
moparx  Online Content
i have had good luck using hi-temperature copper anti-seize on the threads and using a toothpick to apply just a tiny dab to the flare.
beer
Re: Brake fluid leaks [Re: RROD] #3041480
05/11/22 12:56 PM
05/11/22 12:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Get a flare lapping tool.
Re: Brake fluid leaks [Re: John_Kunkel] #3041485
05/11/22 01:07 PM
05/11/22 01:07 PM
Kirkland, Washington
Pacnorthcuda Offline
Wow! For the toolbox that has everything!
Re: Brake fluid leaks [Re: John_Kunkel] #3041487
05/11/22 01:09 PM
05/11/22 01:09 PM
iagree
I have a different, Parker brand, tool for that that I forgot about blush
Re: Brake fluid leaks [Re: John_Kunkel] #3041495
05/11/22 01:22 PM
05/11/22 01:22 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
At $150 I'll just tighten and loosen a few times to seat the flare.
https://www.speedwaymotors.com/Koul-Tools-P-51-Sure-Seat-Lapping-Tool-Kit-37-45-Degree-Flare,246739.html
Re: Brake fluid leaks [Re: Sniper] #3041519
05/11/22 02:31 PM
05/11/22 02:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Brake fluid leaks [Re: John_Kunkel] #3041568
05/11/22 04:41 PM
05/11/22 04:41 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Not what you posted. Try telling us how much the one you posted costs, hint $150, I shopped around.
Re: Brake fluid leaks [Re: fastmark] #3041643
05/11/22 09:40 PM
05/11/22 09:40 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
And have used this procedure on MANY lines over the last 30+ years. Do not over tighten to the point of strippin the hex or threads. Good and tight but not brutally so. What you will observe if watching carefully, is that each time you tighten, loosen, and retighten with the same torque the Nut will move further than before. as it is forming the "SEAL" between the opposing flares. After repeating several times the nut will stop moving as much.
The finishing tool John showed will likely help but I've never needed one.
Another tip if the leak continues, carefully look at the male and female flares. You'll likely see the "SEAL" problem normally on the softer of the two. twocents beer
Re: Brake fluid leaks [Re: TJP] #3041670
05/11/22 10:39 PM
05/11/22 10:39 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Thanks for all the advise. I’m try a “poor man” lapping devise I made using valve lapping compound and steel wool. Hope it works.
