Carter carb tune settings #3041339
05/10/22 10:09 PM
05/10/22 10:09 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Carter 9636SA
438" b-block, 383 with a 440 crank.
214 / 224 cam, 1 3/4 headers, 4-speed, 3.91
I know I need to dial in the tune once it's running, but just for initial fire-up, do you figure I should go with OOTB Carter settings ?
.098 jets, .070/.060 rods, plain springs, 7/16 float setting.
I don't know what the OOTB Carter is supposedly optimized for.
Re: Carter carb tune settings [Re: hemienvy] #3041345
05/10/22 10:25 PM
05/10/22 10:25 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That's a pretty small carb for a 438" engine.
Probably "tuned" for a 360/340 sized engine, not something as large as you are putting it on.
Re: Carter carb tune settings [Re: Sniper] #3041348
05/10/22 10:31 PM
05/10/22 10:31 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
True, but it's just a mild motor, under 5000 RPM.
Even so, I was wondering if I should jet it up 438/360 = 20% more jet area.
Re: Carter carb tune settings [Re: hemienvy] #3041353
05/10/22 11:10 PM
05/10/22 11:10 PM
I would try it the way it is after verifying the stock jetting and springs under the front metering rod pistons are in place. Same thing on the ignition timing and spark plug selected and set at. scope up
Re: Carter carb tune settings [Re: Cab_Burge] #3041397
05/11/22 07:58 AM
05/11/22 07:58 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
go to a .068x.047 metering rod and make sure there are .095's in the secondary.
Re: Carter carb tune settings [Re: Cab_Burge] #3041426
05/11/22 10:14 AM
05/11/22 10:14 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
iagree The CarterBrocks have ancient calibrations and the transitions (where street cars spend most of their time) are difficult to adjust. There are simply better carb choices for your car today. Having said that, I agree with Cab, start with the original jetting for initial start up. But rather than spend too much time and some money trying to get the old CarterBrock up to snuff after the initial start up, just move on to a better and closer to optimum carb.
Master, again and still
Re: Carter carb tune settings [Re: lewtot184] #3041645
05/11/22 09:44 PM
05/11/22 09:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
You're no fun laugh2 beer
Re: Carter carb tune settings [Re: lewtot184] #3041655
05/11/22 10:02 PM
05/11/22 10:02 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Lewtot,
Thank you, I take it you speak from experience ?
Re: Carter carb tune settings [Re: hemienvy] #3041734
05/12/22 09:11 AM
05/12/22 09:11 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
Originally Posted by hemienvy
Lewtot,
yep. actually, i figure jet area on those afb's. what i've found on the carbs i use is the cruise side wants about .004 sqin's and the power wants about .0063sqin's of jet area on the primary side. that's real close to an edelbrock 1405 out of the box. i don't think it makes a lot of difference what jet/rod combo you use to get there. 070" cruise step on the rod with a .098" jet may work, but .060" on the power side i don't think will work. just try different things. i have found that the timing curve on those mild engines can trick you. i wouldn't use a performance curve with that cam. i've been going thru this with a stock 440 and the closer i get to a factory curve the nicer and cleaner it runs.
Re: Carter carb tune settings [Re: DaveRS23] #3041739
05/12/22 09:41 AM
05/12/22 09:41 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
In my experience to old Carter Competition carbs that the Carterbrocks are based on are much better carb.
Re: Carter carb tune settings [Re: JohnRR] #3041773
05/12/22 11:56 AM
05/12/22 11:56 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the older sand cast carbs are better in my opinion.
Re: Carter carb tune settings [Re: lewtot184] #3041977
05/13/22 11:51 AM
05/13/22 11:51 AM
U.S.S.A.
U.S.S.A.
offtopic
