Re:Mopar Performance Six Pack Air Cleaner
[Re: SMILINJOE]
#3039399
05/03/22 02:16 PM
05/03/22 02:16 PM
Posts: 1,059 Ill
SMILINJOE
Ill
Purchased last year from Tommy the Chryco ended up not finishing the project. $750 shipped lower 48
All 383 motors
[Re: moparts]
#3040251
05/06/22 10:05 AM
05/06/22 10:05 AM
Posts: 7,504 DELAWARE
TONY_DAGOSTINO
DELAWARE
All 383-HP Motors: Bare Block, 2-24-65 Cast Date, 12-7 “B” Series, Standard Bore, Has Been Tanked $395, 2-13-67 Cast Date, Complete Less Intake Manifold, Turns Over $695, Complete Has Aftermarket Carb 12-4-69 Cast Date, “F” Series $1495, Bare Block, Factory .020 Over Bore, 4-17-70 Cast Date, “G” Series $395, Long Block (Heads Don’t Have Valves or Springs) 4-22-70 Cast Date “F” Series $795, Long Block, 9-29-70 Cast Date, “G” Series, Cast Crank $795, Bare Block, 9-29-70 Cast Date, “G” Series, Standard Bore $495, Short Block 11-12-70 Cast Date, “G” Series, Cast Crank, Standard Bore W/Balancer, Pistons NG $495, Check Out Our New Webstore at tonysparts.com 302-398-0821, contact@tonysparts.comTonys Parts Harrington Delaware 19952
Re: All 440 motors
[Re: TONY_DAGOSTINO]
#3040252
05/06/22 10:06 AM
05/06/22 10:06 AM
TONY_DAGOSTINO
DELAWARE
All 440-HP Motors: Complete Less Carb + Exh Mans, 1-24-68 Cast Date, D440, Turns Over $1795, Long Block, 6-4-68 Cast Date, E440, Standard Bore, Disassembled $1995, Complete Less Intake + Exh Mans, 1-18-69 Cast Date, E440. Turns Over $2495, Complete Intake To Oil Pan, 10-21-70 Cast Date, G440, Turns Over $1895, Complete Less Carb, 9-14-71 Cast, H440, Heads + Intake Off Of Motor, Turns Freely $995, Check Out Our New Webstore at tonysparts.com 302-398-0821, contact@tonysparts.comTonys Parts Harrington Delaware 19952
Re: For Sale - Big Block Engine - 2nd Quarter
[Re: budman1965]
#3041118
05/10/22 04:11 AM
05/10/22 04:11 AM
Posts: 1,104 Home of the Bluegrass
FJ6DynamicDuo
SOLD
For sale: NIB Doug's D451 ceramic coated headers. $750 new..... $650 shipped to lower 48. PM here Thanks
SOLD
"It takes a Mopar to catch a Mopar” 1971 Roadrunner 505"RB 4 speed FJ6 Sassy Grass 2017 Challenger Hellcat M6 FJ6 Green Go
[Re: moparts]
#3043767
05/19/22 10:39 PM
05/19/22 10:39 PM
Posts: 377 montana
BANDIT
montana
For Sale; Set of 1969 HP exhaust manifolds. Left is casting number 2843992, casting date is 81568. Right side is casting number 2806900, no casting date, heat riser is there, but it is stuck. They had been bead blasted, and have surface rust. $375.00 for the set. Thanks for the ad! Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.50@162. 4900 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.70@ 200mph
